Samsung updates using an Apple Mac - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-23-2007, 05:51 PM - Thread Starter
lparsons21's Avatar
Quoted: 55 Post(s)
Liked: 25
Since I'm contemplating getting a BR player, I decided to download the iso update. But Samsung just list 'windows' as the OS. Will this iso extracted from the zip work with the mac disk utility?
I hope this hasn't been asked before, I couldn't find it if it was.
Lloyd
lparsons21 is online now
post #2 of 6 Old 05-23-2007, 06:22 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
It should. Just make sure you unzip it and burn it as an ISO image. I see no reason why this would not work.
ack_bk is offline
post #3 of 6 Old 05-23-2007, 07:01 PM - Thread Starter
lparsons21's Avatar
Quoted: 55 Post(s)
Liked: 25
Thanks. I got it and it burned just fine.
Lloyd
post #4 of 6 Old 05-23-2007, 09:07 PM
millerwill's Avatar
Quoted: 463 Post(s)
Liked: 261
I got the disc burned just fine with my mac, but then when I tried to do the upgrade in the 1200 the player said 'this disc cannot be played'. Then when I got home, I burned a disc on a PC; it also burned just fine but also worked in doing the upgrade.
Therefore just because you got the disc burned on your mac, it may actually not do the the upgrade. Will be interested to hear.
millerwill is online now
post #5 of 6 Old 05-23-2007, 09:12 PM - Thread Starter
lparsons21's Avatar
Quoted: 55 Post(s)
Liked: 25
It will be much later before you hear from me on this. I don't yet own a BR player. After I got the Samsung 1000 iso, I mounted it on the mac. Mounted fine and I could see files on it, which leads me to believe it will end up working.
BTW, did you burn it with the OSX Disk Utility or another program?
OTOH, the iso I downloaded for my Tosh HD-DVD A2 (gets here tomorrow), won't mount although it seemed to burn fine.
Lloyd
post #6 of 6 Old 05-23-2007, 09:56 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
I use Toast on my Mac. I would think that it would burn just fine as long as you have the option of burning an ISO image file.
ack_bk is offline
Reply Blu-ray Players
