PS3 DVD upscaling - does it work with DVI (HDCP) TVs - AVS Forum | Home Theater Discussions And Reviews
Old 05-24-2007, 11:55 AM - Thread Starter
Danny1's Avatar
I know that FW 1.8 now enables the ability to upscale SD DVD with the use of HDMI. I have a 3-yr old Sony Grand Wega TV that only has a DVI-HDCP connector. I assume a HDMI-DVI cable should work, but before I run out a get such a cable - I was wondering if someone can confirm this with me. Lastly, all the features, such as BTB, WTH etc - would this functions be enabled as well?
Danny1 is offline
Old 05-24-2007, 01:07 PM
walra4's Avatar
it does work if youd like pics just let me know i have a 3 year old sansung hdtv 1080i monitor with dvi i use a hdmi to dvi connector in the back of the tv
walra4 is offline
Old 05-24-2007, 03:03 PM
ethanj's Avatar
I have a front project with DVI and upscaling works fine with HDMI-DVI cable. I'm able to see BTB now with FW 1.8.
ethanj is offline
Old 05-24-2007, 05:38 PM
LejfK's Avatar
HDMI stopped working for me a few updates ago (I'm using a Benq 7800, which has dvi-hdcp). Still can't use it with 1.8. I'm using an hdmi/dvi cable for my Dish 942 and Denon 2910 just fine--only the PS3 won't work with it anymore. I switched to component when the problem arose. I think the PS3s have gotten more sensitive with the handshake issue, and the results vary between display devises.
Spongebob quote - "But Squidward, we already played babble like an idiot."
LejfK is offline
Old 05-24-2007, 07:13 PM
cawgijoe's Avatar
It should work.
However my Sony 34XBR800 with HDCP compliant DVI does not work via that input with the PS3. I've tried everything suggested here and by Sony with no luck. I'm using Componet.
It's a compatibility/handshake issue.
cawgijoe is offline
