PS3 Firmware 1.8 Update Master Discussion Thread; POST ALL 1.8 COMMENTS HERE - Page 16 - AVS Forum | Home Theater Discussions And Reviews
Old 07-04-2007, 04:53 PM
Shaitan's Avatar
Ok, got a 512 meg Kingston DataTransfer usb flashdrive this morning for 10 bux. Transfered the update file and say by golly it actually worked. Noticed a huge pic improvement quality difference compared to how it was before the update. Colors are now more vivid. Sharper images too. Have not tried any non BluRay disks yet to see how the upscaling is yet.
So far I am pretty happy with the update. still can`t see the ability to choose a 16x9 aspect ratio within the PS3 Display settings tho. It outputs 16x9... but you`d think we`d get a choice for it, as well as the Letterbox and Pan and Scan.
Shaitan is offline
Old 07-04-2007, 06:21 PM
dutchca's Avatar
Not sure if I have an issue or not - here are the facts:
- PS3 connected to Hitachi 51F500 via Component cable
- Options checked off under the video setting menu are NTSC and 1080i
- Cross colour reduction is off
Under BD/DVD setings:
- DVD upscaler set to double scale (also tried normal)
SD DVD playback is remarkably better than pre 1.8 update. I am not sure if the signal is getting upconverted though. My TV recognizes the incoming source and it displays on the screen, for example when I start a BD it says 1080i. When I was playing the SD DVD it said 480i. On my progressive scan player the display says 480p when the disk starts.
Would my TV not register 1080i if the DVD (480i) were being upscaled with the PS3?
Is it being upscaled, but just not registering on the display (I don't think so, as the 480p player was producing a better picture IMO)?
Do I need an HDMI to DVI cable (no HDMI input on my TV) to take advantage of the upscaling capabilities?
dutchca is offline
Old 07-04-2007, 06:38 PM
cyberbri's Avatar
Liked: 53
Basically nothing will upscale over component cables. If it was upscaling, your TV would recognize that resolution.
cyberbri is offline
Old 07-04-2007, 06:54 PM
dutchca's Avatar
Will an HDMI to DVI cable overcome this limitation?
dutchca is offline
Old 07-04-2007, 07:11 PM
Jon S's Avatar
Quoted: 798 Post(s)
Liked: 259
it might work, it depends if HDCP is required over DVI.
If it's not a BIG screen, it's not a theater...
Jon S is offline
Old 07-04-2007, 07:38 PM
dutchca's Avatar
Can you expand a bit, please.....
dutchca is offline
Old 07-04-2007, 07:50 PM
oleus's Avatar
Quoted: 33 Post(s)
Originally Posted by kal View Post
I'm told that BTB/WTW are no longer being passed in firmware 1.82. I certainly don't see the BTB pluge in Casino Royale or on other test discs I've used.
Kal
wow, so no one with 1.82 is getting BTB? i figured it was just something with 1.82 and people with hdmi-dvi connections like me.
oleus is offline
Old 07-04-2007, 08:04 PM
Keenan's Avatar
Quoted: 2212 Post(s)
Liked: 2001
I'm getting it. RGB - Limited, Super White - On
PS3 feeding a Denon 3805 feeding a VP50 at 1080p/24 to a Mits CRT-RPTV at 1080i/60
HDMI>HDMI>HDMI>HDMI
Keenan is online now
Old 07-04-2007, 08:12 PM
dutchca's Avatar
Excuse my ignorance, but what is BTB/WTW?
Does your HDMI - DVI cable work for upconversion or does this HDCP thing interfere?
dutchca is offline
Old 07-04-2007, 11:30 PM
Shaitan's Avatar
I am using an HDMI to DVI cable just fine. My set supports HDCP.
"DVD upscaler set to double scale (also tried normal)"
What does this setting do? I tried it, and it cropped the side edges of my Fellowship of the Rings DVD picture. Turned it to Normal, and the DVD played like it Normally does sans the cropped edges. Thx.
Shaitan is offline
Old 07-05-2007, 02:16 PM
DAP
DAP's Avatar
No. The problem is not capability of the hardware, the problem is DRM. The current license agreement for DVD DRM prohibits standalone players from upscaling protected DVDs beyond 480p. This of course is totally absurd as PC players upscale to anything you want, and external upscalers are allowed to rescale to anything as well.
Using a HDMI to DVI cable won't help unless your DVI monitor handles HDCP, if it does not, you won't get any picture at all.
The absurd thing about this is that if you copy the DVD (in the process stripping the DRM), the DVD will be upscaled to any resolution you want on the component outputs of the PS3.
DRM does nothing to hinder the pirates, but does plenty to annoy the legitimate consumers.
DAP is offline
Old 07-05-2007, 05:49 PM
Bronco70's Avatar
I put copies of the GetGray disc in my PS3 and oppo971 today. Wanted a quick look at black and white levels at my current BenQ 7700 settings which I have not looked at since calibration some 1500 or so lamp hours ago. Yea, major videophile demerits for not tweaking in so long a time.
What I found: As expected the oppo passed BTB and WTW as usual. The PS3 did not. I know I did a check when fw1.80 installed and with RGB full range selected along with "super white" the result was both above and below video levels 16-235 were displayed. Seems the move from 1.80 to 1.82 reset the display parameters. Once I changed back to full RGB and super white: on, both BTB and WTW displayed.
BTW, the GetGray disc I have found to be the easiest, no-nonsense quick check on basic display set up. That respected other disc has needed an update to the menu navigation for so long. Does the eminent JK just like to torture us a bit?
Bronco70 is offline
Old 07-05-2007, 06:29 PM
Bronco70's Avatar
BTW and WTW translate into "blacker than black" and "whiter than white". With RGB there are two standards. Video level and PC level. In video the definition of the darkest black is 16 and the brightest white is 235. In PC level the range is 0-255. PC level displays beyond the range designed for consumer display devices. It all goes back to the design days of NTSC. Then there are the matching IRE numbers.
Basically on a display designed for NTSC, ATSC, BD, HDDVD etc. The display should only show Video 16-235 to be accurate.
The utility in viewing below 16 or above 235 has to do with setting black and white level for a display. It makes it easier.
Bronco70 is offline
Old 07-06-2007, 08:44 AM
jhstn58's Avatar
Is there a difference between HDMI cable and DVI cable vis a vis their abilities to transmit BTB or WTW, or 1080p/24 signals?
JimS
Rough business this movie business. I may have to go back to loan sharking for a rest.
jhstn58 is offline
Old 07-06-2007, 10:52 AM
mskeezer's Avatar
Was just about to update my PS3. I'm glad I found this before I did so. I just have a quick question about BTB and WTW. I'm running my HDMI cable to my Yamaha RX-V2600 then to my Infocus IN72 with YPbPr. Is the WTW and BTB problem only on RGB? Should I go ahead and run the update?
mskeezer is offline
Old 07-06-2007, 11:05 AM
ryoohki's Avatar
I'am getting it too..
Sanyo Z4, RGB Limited, YCB for BLuRay Video Output, SUper White ON, HDMI..
89+ Blu-ray Disc ;)
ryoohki is offline
Old 07-06-2007, 12:46 PM
JDEATON's Avatar
Quoted: 38 Post(s)
Liked: 26
I was hoping 1.82 would allow WMA Lossless audio streaming, but apparently not so. Sometime before the PS3 acquired networking capability, DirecTV's HD DVR (HR20) was upgraded to accommodate music and picture streaming. Interestingly, the DirecTV's HR20 will play WMA Lossless files, but while the PS3 will play WMA files it won't play WMA Lossless. The PS3 recognizes the WMA Lossless as WMA files but when selected comes up with The data type is not supported. Of course the PS3 will play WAV Lossless files but the DirecTV DVR does not. I was an audiophile long before I was a videophile, so compressed audio just doesn't appeal to me. Might there be a setting in the PS3 setup menu I'm missing that would allow the PS3 the play WMA Lossless files?
JDEATON is offline
Old 07-07-2007, 11:15 PM
Kage's Avatar
Quoted: 41 Post(s)
There is a glitch with firmware version 1.82. When I put a dvd in the ps3 to watch it on my tv and turn it off with the disc inside it , but later continue to watch the same movie with the disc already inside the ps3, when the movie is finsihed I press the eject button on the remote and I get this message that appears on my screen "Wrong disc inserted, please eject this disc and insert the right disc." This message always appears with dvds. Do you guys have this problem?
Kage is online now
Old 07-08-2007, 12:50 AM
splicesite's Avatar
Originally Posted by mustang5o View Post
I am still on 1.80 and I have been noticing a problem where my screen will flash and maybe go kind of green for a second. I have not been on this thread in a while so I apologize if this has been covered. I haven't done a lot of gaming lately but last I remember the only time I see this is when playing a BD. Should I be upgrading to 1.81 or wait for another update? Is this something more serious that might require service?
I have this exact same problem, with 1.82. Can anyone comment, is this a known issue? The PS3 is hooked to a Panasonic PT-AX100U projector via HDMI. The screen flashes green with a thin purple line through the picture for a split second, perhaps 0.1 seconds or so. This happens 8-10 times during BD viewing and is annoying. I havent seen this reported as a problem with the projector so I am assuming it is the PS3, I would appreciate any other confirmation. thanks
***EDIT*** looks like there has been pretty extensive discussion of this, duh.... guess it's chalked up to a HDMI problem? Any definitive solutions?
splicesite is offline
Old 07-08-2007, 01:53 PM
Jon S's Avatar
Quoted: 798 Post(s)
Liked: 259
I have had this problem since my first update... 1.50?
Jon S is offline
Old 07-08-2007, 06:10 PM
jayoldschool's Avatar
Quoted: 12 Post(s)
I just found out AVIs converted with PS3 Video 9 and transfered to an SD card no longer work. No idea what happened...
jayoldschool is offline
Old 07-09-2007, 01:22 PM
zeroendless's Avatar
Silly me plugged the unit though a switch outlet. I have the lamp light turned off and that shut off the ps3 while it's updating FW around 40%, my heart almost fell though the ground.
Who even programmed the ps3 fw updating progress deserved a big kudo. Nothing happened to my ps3, it was shown as update cancel on last attempt after a completed boot-up.
zeroendless is offline
Old 07-09-2007, 06:39 PM
Merrick97's Avatar
When I have my PS3 set to 1080p mode, I get a horizontal line that moves up my screen whenever I watch movies and in game menus. When I set the PS3 to 1080i or 720p, I dont get the horizontal line. I suspect that I dont have this problem in games because they are all rendered in 720p
HELP ME PLEASE!!!!
I have used several different HDMI cables including one from monoprice.
Blurays: 115
HD-DVD: 12- YES I will be keeping them so I can own a piece of history
Merrick97 is offline
Old 07-10-2007, 06:01 AM
surap's Avatar
Strange! My first suggestion would be that you checked if you have some ground loop problem. But when i see that you say that it only occurs when viewing 1080p im not certain where the problems can be.
surap is offline
Old 07-10-2007, 06:13 PM
Ron Jones's Avatar
Quoted: 899 Post(s)
Liked: 895
HELP ME PLEASE!!!!
Do you have any other 1080p source to test with your display? This may be an issue with the display rather than the PS3.
Ron Jones
Blog + Reviews + Articles: projectorreviews.com
Ron Jones is offline
Old 07-11-2007, 01:28 PM
mustang5o's Avatar
Quoted: 29 Post(s)
Please link where you found this extensive discussion. Funny thing is I have the same projector and was worried it was the PJ. I would much rather send the PS3 in if it needed service the the PJ I do plan to try different cables this weekend. Including moving the one I have on my Oppo DV-970 to the PS3. Maybe I will also try to disable 1080p output since the pj is only 720p anyway.
"Like a Ninja, only better!"
mustang5o is offline
Old 07-11-2007, 08:29 PM
Shaitan's Avatar
I am pretty happy with the 1.82 update. Any idea what the next update will bring for the PS3?
Shaitan is offline
Old 07-11-2007, 11:24 PM
krholmberg's Avatar
Quoted: 105 Post(s)
Originally Posted by spann-man View Post
Sorry if this has been addressed before, but I cannot get 1080P24 out of the ps3. Not sure if it is the HDMI switch that is limiting this or if it is the PS3? Display is JVC RS-1 and Switch is Monoprice 4-1 switch. I get judder with all BR discs I have tried. Starting to think the PS-3 was the wrong choice to eliminate judder from BR discs.
Also, for some reason (probably user error on my part) my pre/pro will only detect 2 channel audio out of the PS3 on movies but on games I get 5.1. Pre/Pro will only do 5.1 DD/DTS and non of the new formats.
I've got the same problem when using my PS3 with my RS1. The only difference is I'm using a different switcher. It's especially evident when watching credits at the end of the movies.
Krister
krholmberg is offline
Old 07-12-2007, 07:46 AM
DaViD Boulet's Avatar
Liked: 41
quick question (been out of the loop for a while): what does 1.82 do new/different versus 1.80?
thanks!
1080p and lossless audio. EVERY BD should have them both.
DaViD Boulet is offline
Old 07-12-2007, 08:42 PM
Ward216's Avatar
Quoted: 21 Post(s)
Same here & I have the same pj. It happens more often since the last update. Prior to that it was once, maybe twice with BD movies. Not present on the component video output, or 720p games over hdmi however. I'll try reverting back to 1080p/60, 1080i/60, 720p/60 this weekend and see if it still persists with any or all of these. I'm using the 1080p/24 setting currently. It may just be a flaw with the 24hz refresh rate.
-Ward
There's room for ALL of God's creatures...right next to the mashed potatoes!
Ward216 is offline
