Does the pioneer HD1 do dts-hd? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 06-05-2007, 09:34 AM - Thread Starter
Jon Spackman's Avatar
Does it do dts-hd (not MA)?
Does it do 5.1 DD+, 5.1 TRUHD?
What can you do with the home media option (HD files?)?
Just enjoy HD in whatever form you can (Sat, Cable, D-VHS, OTA, HD DVD, or BD).
Jon Spackman is offline
post #2 of 7 Old 06-05-2007, 04:20 PM
madkaw's Avatar
Liked: 31
No, No and No. Not yet anyway. It will never do DTS HD but there is a firmware coming for DD+ and True HD. You can do alot with the media gallery but I find it no better than the HTPC in the living room. For me it is redundant technology.
ISF Certified Calibrator
CalMan Pro
Electronics Junkie
madkaw is offline
post #3 of 7 Old 06-05-2007, 10:04 PM
Paul Arnette's Avatar
Quoted: 32 Post(s)
Actually, the Pioneer Elite BDP-HD1 can do DTS HD. It cannot do DTS HD MA.
Paul Arnette is online now
post #4 of 7 Old 06-05-2007, 11:45 PM - Thread Starter
Does it decode DTS HD High resolution ( I know DTS MA is one step further that no players decode) or just DTS core ( I believe its called DTS HD)?
post #5 of 7 Old 06-06-2007, 07:12 AM
Quoted: 32 Post(s)
OK. I'm officially throughly confused with DTS and their advanced audio codecs. I thought DTS HD was the 'core' of DTS HD MA. Anyway, I watched Basic Instinct on BD last week, and my receiver decoded it as DTS Discrete, so perhaps it was just the 'core'. So, you're saying that DTS HD isn't the 'core' of DTS HD MA?
Man, we need about 12 more audio codecs, this just isn't confusing enough.
Edited to add:
Well, it does indeed look like DTS HD Master Audio and DTS HD High Resolution are two different HD advanced audio codes (lossless and lossy respectively).
From the above chart, it is reasonable to assume that the 'core' for both of these is the 1.5mb DTS Digital Surround 96/24. So, with that, I ammend my prior comment that the Pioneer Elite BDP-HD1 can decode DTS HD High Resolution. I don't know if it can or not, but I suspect madkaw is correct in that it cannot. I would also venture to say that no other current BD player can decode it either.
post #6 of 7 Old 06-06-2007, 07:57 AM
madkaw's Avatar
Liked: 31
Edited to add:
You are correct, HD and MA are two seperate codecs. I see no point in having two but good ol' dts is the fault of that.
The panny can do dts-hd but not MA. From what chris has expressed over in the pioneer forum is that the players will have to have a serious on-board computer to decode the MA internally. Even after the fully compliant players hit the market at the end of the year I suspect that there will be very few that will decode MA, most will send it bitstream to a receiver.
CalMan Pro
Electronics Junkie
madkaw is offline
post #7 of 7 Old 06-06-2007, 09:19 AM
Robert George's Avatar
Location: Trapped in time. Surrounded by evil. Low on gas.
Think of DTS-HD as the DTS equivalent of Dolby Digital Plus and DTS-HD MA as the DTS equivalent of Dolby TrueHD.
DTS-HD is still lossy like standard DTS, but is scalable to higher bitrates, ostensibly for better quality. DTS-HD MA is, of course, DTS's version of lossless compression.
The DTS "core" that is extracted from either DTS-HD or HD MA is standard DTS.
Robert George is offline
Reply Blu-ray Players
