Will I benefit from a Blu-Ray player if my plasma is 720p/1080i instead of 1080p? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-16-2007, 08:16 PM - Thread Starter
tvstud's Avatar
I just baught a PIO 5080 plasma. It is 768 native resolution but can accept 1080p. Will I still benefit from the picture quality of a blu-ray player?
tvstud is offline
post #2 of 5 Old 07-16-2007, 08:23 PM
CommanderCool's Avatar
yeah i heard,some plasmas "accept" 1080p but i think it downscales,but yeah my lcd tv is 720p/1080i blu rays look amazing on,so yeah you will benefit from it
Xbox 360
Playstation 3 20gb
Samsung LN-S3251D
Logitech Z-5500
blu-ray!
CommanderCool is offline
post #3 of 5 Old 07-16-2007, 08:24 PM
Bunga99's Avatar
Liked: 39
Very Nice TV!!
Short Answer...HELL YES!!
Long Answer....
I posted this in another thread:
_______________________
I had a 42inch Westy LCD 1080P TV now I UPGRADED to a 768P 50inch Samsung Plasma. I personally feel that you will not be able to tell any difference between 1080P and 1080I/720P on anything 50inch and lower (might be a difference if your display is 60inch or bigger). My brother has a 1080P 56inch Samsung DLP and his Blu rays through the Ps3 looks just as good as my blu rays and 768P Plasma through my ps3. In some respects, I feel my plasma is better because it does not loose its viewing angle as easy and seems to have more of a picture tube type look/feel to it (more of a pop). I think you will see a huge difference even at 1080I or 720P when watching blu rays or hd dvds.
I sat 8'ft away from my 42in LCD and now Sit 8ft away from my 768P Plasma. I still feel the Samsung Plasma is superior in overal picture than the Westy but the resolutions seems to be the same. My brother seating postion in his living room is about 10.5 from his 56inch 1080P DLP.
PS...I have 20/15 vision (better than 20/20) LOL....but I am serious.
Thx,
Claude
__________________________________________
Longer Answer
You find more info in this thread....
http://www.avsforum.com/avs-vb/showt...9&page=1&pp=30
Bunga99 is offline
post #4 of 5 Old 07-16-2007, 08:44 PM
^^ lol,like i mentioned in another thread i wouldnt buy a westinghouse 1080p tv...lower quality tv,i think a higher quality 720p will look better
Xbox 360
Playstation 3 20gb
Samsung LN-S3251D
Logitech Z-5500
blu-ray!
post #5 of 5 Old 07-16-2007, 08:48 PM
DrPyro's Avatar
I'll second the "Hell yes" comment!
I run a pioneer 6070 and the pioneer 94HD bluray player, i haven't rented a DVD since i got the bluray player. I'm even going back and watching old movies (something I almost never do). It's really a significant increase in picture quality and sound quality (when using TrueHD or uncompressed PCM).
-DrPyro
I think IÂm addicted to placebos!!!
DrPyro is offline
Reply Blu-ray Players
