Low sounding Dialog on Ps3 Blu Rays - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 08-19-2007, 11:29 AM - Thread Starter
Ulf05's Avatar
I have my PS3 connected via HDMI monster 1000 series cable to the back of my TV a Phillips 42' LCD 1080p.( no surround sound) Now when watching the TV the sound is great and it sounds like it should including dialogue levels. But as soon as I play a DVD or Blue Ray in the PS3 I have to jack the volume up to almost 85 to hear what anyone is saying. Backround noises in the movies sound great its just when anyone starts talking it I have to blast the volume even higher to attempt to hear what anyone is saying. I have tried both bitstream and Linear PCM settings in the audio options and get the same result mostly. Bitstream makes the dialogue seem a bit more louder but distorts it by sounding like an echo when anyone talks. Ive called sony and apparently some of the techs there have no clue because they hardly understood what I was talking about. They made me reset the PS3 to default settings and just change the audio to bitstream, that was all. I also called phillips and they couldnt help me because the TV is fine and said it has to do with the output device which would be the PS3 ARGHH!!!!!! any suggestions...ive googled this problem and it seems nobody has an answer to this. Are there other settings/options im missing?
Ulf05 is offline
post #2 of 12 Old 08-19-2007, 12:57 PM
MidnightWatcher's Avatar
Quoted: 37 Post(s)
Liked: 25
I think you meant "Blu-ray".
MidnightWatcher is offline
post #3 of 12 Old 08-19-2007, 01:07 PM
bommai's Avatar
Quoted: 194 Post(s)
Liked: 49
Don't you have a receiver? I have never tried hooking up my PS3 directly to the TV. Are you using HDMI? Make sure the HDMI audio setting is set to LPCM. Use the automatic HDMI audio setting. The PS3 should automatically choose just 2 channel.
I highly recommend getting a surround sound system. Bluray movies are inherently multi channel and I don't know how well a two channel downconversion works.
bommai is offline
post #4 of 12 Old 08-19-2007, 01:24 PM - Thread Starter
Ulf05's Avatar
No receiver just direct a connection from HDMI to the TV ...and yes it is set to LPCM and on the auto settings.
Ulf05 is offline
post #5 of 12 Old 08-19-2007, 04:41 PM
Maxx_75's Avatar
Sounds like a Dynamic Range Control issue.
"My ignorance amuses me." .......Manfred Powell
Blu-Ray = 381 HD DVD = 1
My Collection
Maxx_75 is offline
post #6 of 12 Old 08-19-2007, 06:52 PM
Garman's Avatar
Quoted: 1184 Post(s)
Liked: 506
The PS3 also has a audio output level you can increase... Make sure this is up all the way. Also make sure receivers outputs for each channel are calibrated correctly. What kind of make and model receiver are you using? If you
are just going straight to the TV without a receiver you might want to tweek the TVs output level if possible and make sure the Audio setting on the PS3 is turned all the way up.
MighNightWatcher: Ah that is all you have to say... You Troll! LOL Guy is looking for help not some smart ass comment.... Geez......
Dynaudio,Magnepan,Hegel, Musical Fidelity,Belles and KEF, etc...... Maybe New Belles Aria Int. Amp as far as equipment goes and for speakers the: Contour's 20's or Raidho next...
Charter Member - E.S.A.C. (Eastern Shore Audio Collective) http://www.esac.club/index.php
Kanso Audio Stand's http://kansoaudiofurniture.com/
Garman is online now
post #7 of 12 Old 08-19-2007, 07:05 PM
Ron Jones's Avatar
Quoted: 899 Post(s)
Liked: 895
It sounds like your TV may be using the right and left channels from a right-center-left set of audio channels, thus missing the center channel which contains most of the dialog. Make certain your PS3 is set to output only 2-channel stereo via HMDI or alternative run a separate audio connection to the TV rather than using the audio carried via the HDMI.
Ron Jones
Blog + Reviews + Articles: projectorreviews.com
Ron Jones is offline
post #8 of 12 Old 08-20-2007, 05:31 AM
JOHNnDENVER's Avatar
I'd try analog L/R analog for audio to the display.
JOHNnDENVER is offline
post #9 of 12 Old 08-20-2007, 03:06 PM - Thread Starter
Ulf05's Avatar
Im going straight to the TV no receiver,the ps3 has WAY to many audio settings for me to understand and when I call tech support I get someone who doesnt understand them either. Yeah its a lot of fun
and yeah after I posted the title under "BLUE RAYS" and then noticed my mistake I was half expecting to get some wise cracks heh
Ulf05 is offline
post #10 of 12 Old 08-20-2007, 03:08 PM - Thread Starter
Ulf05's Avatar
Would you know off hand what option that is in the PS3? There are about 14 different settings I can click on and they are kind of confusing. My TV is set to Stereo....I cant seem to find just a simple stereo option on the PS3.
Ulf05 is offline
post #11 of 12 Old 08-20-2007, 03:45 PM
Rich Davenport's Avatar
Under Sound->Audio Output
First select the connector, then the audio formats. I think there are two selections that you can't de-select. They may be greyed out. These are the only ones you want (Linear PCM 2 channel 44.1 and Linear PCM 2 channel 48K hz.)
http://manuals.playstation.net/docum...diooutput.html
Member of AVS FORUM folding@home team, (team #55280)
Rich Davenport is offline
post #12 of 12 Old 08-20-2007, 07:34 PM - Thread Starter
Ulf05's Avatar
Hey thanks man!!
Ulf05 is offline
Reply Blu-ray Players
