Samsung BDP1400 Disussion Thread - Page 13 - AVS Forum | Home Theater Discussions And Reviews
post #361 of 12886 Old 09-27-2007, 06:05 PM
kevinca1's Avatar
Dts Ma Audio At True Hd At Last!!!!!! Wholly Molley Does It Sound Good.
kevinca1 is offline
post #362 of 12886 Old 09-27-2007, 06:13 PM
th8ter's Avatar
After reading this whole thread today I had to run up to CC and pick one of these thangs up. It is updating the FW as I write this. Can't wait to hear DTS Master HD and Dolby True HD. I always thought I would go HD DVD first but I guess not.
th8ter is offline
post #363 of 12886 Old 09-27-2007, 06:16 PM
kevinca1's Avatar
Try Xmen 3 if you have it.
kevinca1 is offline
post #364 of 12886 Old 09-27-2007, 06:18 PM
th8ter's Avatar
I bought POC for kids but I will get that tomorrow. Just grabed POC as I was walking out should have looked around more probably.
th8ter is offline
post #365 of 12886 Old 09-27-2007, 06:22 PM
kevinca1's Avatar
Pirates is a great choice also. Make sure you pick uncompressed audio.
kevinca1 is offline
post #366 of 12886 Old 09-27-2007, 06:34 PM
th8ter's Avatar
How long does it take to download the update via cat5? It seems like it is taking forever.
th8ter is offline
post #367 of 12886 Old 09-27-2007, 06:37 PM
kevinca1's Avatar
if i remember right around 20 minutes maybe
kevinca1 is offline
post #368 of 12886 Old 09-27-2007, 06:53 PM
th8ter's Avatar
I am not getting any sound through my Onk 905 hooked up through HDMI. Tried Bitstream and PCM, picture is fine any suggestions?
th8ter is offline
post #369 of 12886 Old 09-27-2007, 06:55 PM
kevinca1's Avatar
you using hdmi correct to and out of the reciver?
kevinca1 is offline
post #370 of 12886 Old 09-27-2007, 07:01 PM
th8ter's Avatar
Yes, it is working on my Dish DVR. I can't figure this out and I am usually pretty good at this stuff I am wondering if something is wrong with the player.
th8ter is offline
post #371 of 12886 Old 09-27-2007, 07:04 PM
kevinca1's Avatar
did you go into setup and digital input and select hdmi 1 2 0r 3 for dvd or what inptu you have
kevinca1 is offline
post #372 of 12886 Old 09-27-2007, 07:11 PM
th8ter's Avatar
Yes the 1400 is set up for HDMI3 for video and audio.
th8ter is offline
post #373 of 12886 Old 09-27-2007, 07:18 PM
kevinca1's Avatar
there are any things it can be, You may need to resest reciver and try that, i screwed one of the setups up and had to reset it,
kevinca1 is offline
post #374 of 12886 Old 09-27-2007, 07:44 PM
th8ter's Avatar
Don't know what I did but it is working now. Thanks for the input.
th8ter is offline
post #375 of 12886 Old 09-27-2007, 07:45 PM
kevinca1's Avatar
Great Enjoy.
kevinca1 is offline
post #376 of 12886 Old 09-27-2007, 08:56 PM
Toe
Toe's Avatar
Quoted: 1992 Post(s)
Liked: 2284
I assume the 1400 passes bitstream for all sound formats? (TrueHD, DTS-MA, etc.....)
Toe is offline
post #377 of 12886 Old 09-28-2007, 01:40 AM
Blu-ray Reviewer
Moderator
Ralph Potts's Avatar
Quoted: 1133 Post(s)
Liked: 3604
Greetings,
You assume correctly...
Ralph C. Potts
Blu-ray Reviews
AVS Forum
My Home Theater
My DVD/HD DVD/Blu-ray Collection
Follow me on Twitter @RalphAVSreviews
Ralph Potts is online now
post #378 of 12886 Old 09-28-2007, 02:37 AM
zero_zep's Avatar
Quoted: 20 Post(s)
Ok look I'm NOT trolling...I've been looking for a BD player and I just want to know if this player can decode the codecs. I ask because I'm using just a 2.0 system with a reciever that cant decode the new stuff. So I need a player to do it.
zero_zep is offline
post #379 of 12886 Old 09-28-2007, 03:31 AM
rveras's Avatar
The 1400 only decodes Dolby Digital, Dolby Digital Plus, Dolby Digital True HD, DTS & DTS-HD-High Resolution Audio. DTS-HD-Master Audio is bitstream only.
Ok this is the last time I'm going to answer this. Maybe we need a sticky to report what each player decodes. Ahhh..... people don't read it after anyways.
rveras is offline
post #380 of 12886 Old 09-28-2007, 06:19 AM
Toe
Toe's Avatar
Liked: 2284
Originally Posted by placidman View Post
Greetings,
Toe is offline
post #381 of 12886 Old 09-28-2007, 08:28 AM
kemiza's Avatar
Liked: 92
Has anyone compared the sound of the decoder inside the player vs. the decoder inside a receiver via bitstream?
Panasonic TC-P50ST60 plasma HD television, Onkyo TX-SR805 and PIONEER ELITE VSX-47TX receivers, Klipsch RB-75(2 pair) and RB-61 bookshelf speakers, Klipsch RSW-10, RSW-12(2), Velodyne HGS-12, HGS-18 subwoofers, OPPO BDP-103, PS3 80G, PIONEER DV-525 dvd player, Klipsch RS-42 surrounds, Klipsch RC-52 center channel
kemiza is offline
post #382 of 12886 Old 09-28-2007, 09:42 AM
billymerritt's Avatar
Quoted: 35 Post(s)
Liked: 27
Yes, from my take on this, the DTS_HD master sounds better bitsream with 1400 vs. PS3 inside player, but not a lot to me, sort of the difference in DD+ and DDTrueHD. I think a lot depends on each individual movie even some standard DVD's in DTS and DD sound great. A lot more evaluation needs to be done before I can say it's a huge improvement, but this is so subjective, who knows.
My receiver is the Onkyo 705.
Bill
billymerritt is offline
post #383 of 12886 Old 09-28-2007, 10:01 AM
CraigW's Avatar
Well remember the PS3 is only giving you dts-core even if decoded in the PS3.
CraigW is offline
post #384 of 12886 Old 09-28-2007, 01:57 PM
uw69's Avatar
Who all is trying to get the 5 free movies with the 1400?
I miss the rosewood sides on the old Pioneer Elite equipment!
Blu-ray - 576
HD DVD - 81
uw69 is offline
post #385 of 12886 Old 09-28-2007, 02:04 PM
priesteria's Avatar
Can this player also do some kind of interactive thing, PIP ?
(255,0,0)
priesteria is offline
post #386 of 12886 Old 09-28-2007, 04:49 PM
TrevorS's Avatar
Th BD-P1400 is BD-ROM Profile 1.0. PiP is BD-ROM Profile 1.1.
TrevorS is offline
post #387 of 12886 Old 09-28-2007, 05:24 PM
Big Lar's Avatar
Hi folks, great info in here Quick question, anyone running an Infocus PJ with 1 of these thru the M1 port?
I have an str-dg910 sony receiver and just got done with about an hour of sony on the phone, as well as another hour with level2 samsung, and both of course want to shed blame... I get a/v with a comcast box on all ports of hdmi in the receiver, but no audio with the 1400. Video is fine, as well as optical out, but no A/V with the samsung?
Thanks in advance.
Larry
Big Lar is offline
post #388 of 12886 Old 09-28-2007, 05:36 PM
Gary Murrell's Avatar
anyone know how to get rid of the BS auto-off crap on this player?
-Gary
Gary Murrell is offline
post #389 of 12886 Old 09-28-2007, 06:46 PM
davcole's Avatar
Quoted: 69 Post(s)
Liked: 48
Has anyone tested the TrueHD bitsream in the receiver against the decoding to PCM done in the player?
Thoughts?
davcole is offline
post #390 of 12886 Old 09-28-2007, 07:52 PM
th8ter's Avatar
Just got finished watching X-Men with DTSMHD. The sound is very clean coming trhough my speakers. I noticed that dialogue from center channel sound like they were right in the room with you. I had to pump up the bass about 2 db on DTSMHD. I look forward to trying DTHD. Can anyone suggest a good disk to try? Kevinca1 thanks for the headsup on X-Men you were right.
th8ter is offline
Reply Blu-ray Players
