Samsung BDP1400 Disussion Thread - Page 25 - AVS Forum | Home Theater Discussions And Reviews
post #721 of 12886 Old 10-14-2007, 11:34 AM
Robert George's Avatar
Location: Trapped in time. Surrounded by evil. Low on gas.
I wonder whose fault this is. If the player is just sending the bitstream out, can it really be the source of this issue? Is it conceivable that the soundtrack on the discs are actually mis-flagged somehow?
Gotta be the player. I have the 1400 and a PS3 connected to a Denon 4308. Multi-channel PCM from the PS3 is fine. I can apply PLIIx for 7.1 processing normally. With the 1400, the same discs show up at the Denon as 7.1 discrete.
Robert George is offline
post #722 of 12886 Old 10-14-2007, 11:44 AM
wizzack's Avatar
Quoted: 104 Post(s)
Liked: 242
Got through 28 Weeks Later BD last night without a hiccup.
WHEEEEW!
The above post is 100% medically accurate
31 Days of Horror: 2014 2013 2012 2011 2010 2009 2008
wizzack is offline
post #723 of 12886 Old 10-14-2007, 01:08 PM
tai4de2's Avatar
Excellent data point -- thanks.
tai4de2 is offline
post #724 of 12886 Old 10-14-2007, 01:10 PM
dildatonr's Avatar
Quoted: 25 Post(s)
Originally Posted by tai4de2 View Post
Mine does this (example: The Terminator). I have the latest firmware -- on both the player and the Denon 3808.
ok this is just odd.
On most titles, the Terminator included. I get 5.1pcm to bitstream just fine and apply ultra2. But I watched Dracula the other night and it did not. My onkyo 875 saw it was 7.1 pcm.
It's really odd it's title slective to begin with. even odder that you have an issue with terminator but I don't.
I assume some of you have reported this to samsung right?
dildatonr is offline
post #725 of 12886 Old 10-14-2007, 01:16 PM
Toe
Toe's Avatar
Quoted: 1838 Post(s)
Liked: 2112
EVERYONE who is having this problem should report it to Samsung. Dont rely on everyone else to do it or they wont know how many people are being affected. If they think it is only a small amount, chances are nothing will get done. Give them a call and talk to a level 2 tech.
JVC CMD Vertical Banding: Affects all currently shipping lamp based JVC Projectors
http://www.avsforum.com/forum/24-dig...rojectors.html
PLEASE CALL JVC AND REPORT THE CMD BANDING IF THIS BOTHERS YOU
1-800-252-5722
Choose option 1, then 4 and have your serial# ready (located on back of unit or box).
Toe is offline
post #726 of 12886 Old 10-14-2007, 01:48 PM
dildatonr's Avatar
Quoted: 25 Post(s)
Absolutely agree.
post #727 of 12886 Old 10-14-2007, 04:57 PM
quinthoopachiefy's Avatar
I got the 1400 Friday and hooked it up to my 805 and sent the signal bitstream, I got the Dolby True lights to pop up and DTS MA to pop up. I have a problem though it is not diplaying the 96 KHZ like it should it is only displaying 48khz for the Frequency sampling rate. How do I fix this. I have tried a million different things and it's driving me crazy. I need help. Thanks.
quinthoopachiefy is offline
post #728 of 12886 Old 10-14-2007, 07:01 PM
steviec's Avatar
That is because the soundtrack is only 48 hz. as most are so it is correct!
steviec is offline
post #729 of 12886 Old 10-14-2007, 07:36 PM
Thank You, I didn't even think about that.
post #730 of 12886 Old 10-15-2007, 01:49 PM
th8ter's Avatar
Exchanged my 1400 for a new one at CC. I downloaded the new firmware. I have only watched one SD DVD but it played great! No stops. Watched Surfs Up, the player locked up one time restarted and it played the remainder of the movie after that. Watched Underworld last night it played great. The PQ and sound was awesome!
th8ter is offline
post #731 of 12886 Old 10-15-2007, 02:49 PM
billymerritt's Avatar
Quoted: 35 Post(s)
Liked: 27
After going through 2 1400's from CC I decided to try one from BB. Was not expecting much better bug free unit. I first done the firmware update without problems, then much to my surprise I played 3 Fox titles with DTS-HD-M and chapter skips with remote or via menu no hiccups or freeze start to finish. Tried V. Las Vegas TrueHD no glitches played perfect! What a surprise, this 1400 may be a keeper, but to soon to tell.
Bill
billymerritt is offline
post #732 of 12886 Old 10-15-2007, 04:38 PM
m1fuller68's Avatar
?...I'm watching "silver surfer" with my new 1400 and DTC-9.8...The receiver says DTS-HD but I'm only getting 5 channels to light up when I have a 7.1 setup. Any suggestions?
Edit...I just switched to X-men 3 with DTS-HD and all channels work and it sound fantastic. I wonder what I'm doing wrong with "Silver surfer"?????
m1fuller68 is offline
post #733 of 12886 Old 10-15-2007, 04:45 PM
lrstevens421's Avatar
Press the THX on your remote, Ultra2 cinema will give you 7.1.
Making the most out of what I got.
lrstevens421 is offline
post #734 of 12886 Old 10-15-2007, 04:59 PM
Charlie Tango's Avatar
The channel indicators on the DTC 9.8 show the number of INPUT channels. "Silver Surfer" is DTS HD 5.1. So 6 channels is correct. Either PLIIX or THX Ultra II will give 7.1 output channels.
X Men Last stand is DTS HD 6.1, so 8 input channels with light up.
Charlie Tango is offline
post #735 of 12886 Old 10-15-2007, 05:18 PM
m1fuller68's Avatar
Thank you....That worked...I learn more everyday..:
post #736 of 12886 Old 10-15-2007, 07:58 PM
Johnnyblaze's Avatar
I thought that "TG Daily" reported that Samsung Cancelled the production of the 2400???
Johnnyblaze is offline
post #737 of 12886 Old 10-16-2007, 08:50 AM
dude2006's Avatar
Quoted: 21 Post(s)
And your point is? This is the P1400 thread
dude2006 is offline
post #738 of 12886 Old 10-16-2007, 09:15 AM
shh1234's Avatar
Quick question to all the BD-P1400 owners.
Does this unit have a full size IEC connector for the power cable or does it use the smaller 'Figure 8' connector found in cheaper electronics.
Tried a Google search for back panel images of the BD-P1400 but none could be found, and also not shown in the owner's manual.
Thanks in advance for your help.
shh1234 is offline
post #739 of 12886 Old 10-16-2007, 09:20 AM
Blu-ray Reviewer
Moderator
Ralph Potts's Avatar
Quoted: 1083 Post(s)
Liked: 3432
Greetings,
Like the 1200 the 1400 does not have a detachable power cord. Sorry.
Ralph C. Potts
Blu-ray Reviews
AVS Forum
My Home Theater
My DVD/HD DVD/Blu-ray Collection
Follow me on Twitter @RalphAVSreviews
Ralph Potts is offline
post #740 of 12886 Old 10-16-2007, 11:02 AM
IBL8's Avatar
Is the 5.1 pcm problem universal or are there 1400's out there that don't exhibit this problem? I still don't see enough complaints from other receiver owners, mostly the Onkyo 805, 875, 905 people. There are a lot of Blu-ray movies with 5.1 pcm tracks, so if you have a 7.1 system and you can't add Ultra2 etc. to it then this should definitely be a priority fix for Samsung.
IBL8 is offline
post #741 of 12886 Old 10-16-2007, 11:20 AM
dildatonr's Avatar
Quoted: 25 Post(s)
For me it's an issue with some titles and not others. What's even weirder is some people have issues with some titles and other's don't.
For instance - Dracula exhibits this issue for me but Terminator does not. While an earlier poster said he had this issue with Terminator.
post #742 of 12886 Old 10-16-2007, 11:38 AM
dude2006's Avatar
Quoted: 21 Post(s)
I haven't tried it on that many movies but with the two that I did try I had the same problem, they were 300 and Departed
dude2006 is offline
post #743 of 12886 Old 10-16-2007, 12:53 PM
Bill Kelley's Avatar
Originally Posted by Bill Kelley View Post
After three weeks of endless problems with my first 1400 the replacement player from CC has worked flawlessly, even after downloading the firmware upgrade. I only have four days left with my 30 day purchase.
I've watch four movies witout a single problem sending the bitstream audio signal to my Onkyo 705 using Dolby True HD or DTS HD master.
I've decided to return the unit.
I bought a PS3 yesterday and giving it the complete run through. Watched Spider-Man 3 and the Dolby True HD worked great and the picture matches the 1400. I review DVDs and hi-def discs if you're wondering.
Bill Kelley is offline
post #744 of 12886 Old 10-16-2007, 01:59 PM
kharkar's Avatar
I had posted a separate query earlier to ask whether the 1400 can play DVD+R/+RW disks, but did not really get an overwhelming response from anyone. I looked at the specs and they say that it supports DVD-R/-RW, but don't specifically say that it doesn't support the +R/+RW. The majority of my disks are DVD+R, so I will appreciate if any actual user(s) can test/verify whether it can indeed play the +R/+RW disks. This will greatly help me in my purchase decision. Thanks in advance for your replies.
Yogi.
kharkar is offline
post #745 of 12886 Old 10-16-2007, 02:17 PM
Halfrican's Avatar
Ditto here Bill, after 3 weeks or forum searching, countless hours of tinkering, several HDMI cables, two exchanges, and many phone calls to tech support, I GAVE UP! The PS3 is also in my rack serving me well, I can now just watch the movie instead of waiting for the audio drops/freezes to occur.
REALLY hope Samsung resolves this issue soon so that I can re-purchase it or perhaps I'll just wait for the Denon Blu-Ray transport that is supposed to be released by year end.
Half
Halfrican is offline
post #746 of 12886 Old 10-16-2007, 02:25 PM
Cortiz's Avatar
Quoted: 79 Post(s)
Liked: 64
Spidey 3 is not out yet?????????
Cortiz is offline
post #747 of 12886 Old 10-16-2007, 02:36 PM
Humanoid1's Avatar
I was wondering the same thing. I live in the states and the release date is Oct 30.
Humanoid1 is offline
post #748 of 12886 Old 10-16-2007, 02:48 PM
T-smith's Avatar
Quoted: 52 Post(s)
reviewers always seem to get their copies a week or two in advance, its a good way to get the word out
I've been out of the game and away from the site for a few years but I'm glad to be back.
T-smith is offline
post #749 of 12886 Old 10-16-2007, 03:19 PM
Humanoid1's Avatar
So whats the word
post #750 of 12886 Old 10-16-2007, 05:07 PM
Rolls-Royce's Avatar
Quoted: 327 Post(s)
Liked: 501
Yogi.
Mine didn't want to play a DVD+R DL disc I have. You didn't specifically mention DL discs, so I don't know if this helps answer your question.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is offline
Reply Blu-ray Players
