Samsung BDP1400 Disussion Thread - Page 429 - AVS Forum | Home Theater Discussions And Reviews
post #12841 of 12886 Old 10-15-2011, 01:12 PM
mr.kludge's Avatar
Quoted: 99 Post(s)
Liked: 115
Originally Posted by sptrout View Post
I had one of the first 1400's off the boat and it was connected via analog to my Denon. The original firmware (v0.X or something like that) did not handle MA, but in a few weeks they released what should have been the first public firmware (v1.0) and it decoded MA.
You sure it was not just decoding the core DTS 1.5Mbps stream? I pretty convinced now that it is just like the Sammy BD-UP500 where you can set the track to the DTS-HD, but it just decodes core. It would be very hard to tell.
mr.kludge is offline
post #12842 of 12886 Old 10-15-2011, 02:40 PM
sptrout's Avatar
You may well be correct. I no longer have any of the equipment mentioned previously, and the first thing I replaced was the Denon AVR so I could move up to HDMI and full HD audio capabiliy in the AVR (got sick of the poor bass management in the P1400). I dumped the P1400 a couple years ago.
Based on a very quick scan of some of the many comments in this thread, the only upgrade made to this model was to add MA via bitstreaming back a few weeks after it was released. It has been over 4 years now so my memory is likely fading away.
sptrout is offline
post #12843 of 12886 Old 10-20-2011, 03:15 PM
Cougar360's Avatar
Okay so lincoln lawyer and american psycho and stargate anniversary edition and t2 skynet edition will al not play on my player anyone else with this problem?
Cougar360 is offline
post #12844 of 12886 Old 10-20-2011, 05:50 PM
mr.kludge's Avatar
Quoted: 99 Post(s)
Liked: 115
Are you running the latest firmware, 2.5? If you are relying on the Ethernet/Internet upgrade process it won't be detecting the latest. You may need to download the file and burn a disc.
However, those are not discs that I am aware of that need updated to the player. I have had issues with a couple Sammy loaders developing a condition where they will no longer read some Liongate titles, but mostly older releases all you mention except for Am. Psycho are somewhat recent.
post #12845 of 12886 Old 10-21-2011, 01:56 AM
Cougar360's Avatar
They all played before but now since I upgraded from 2.3 to 2.5 t2 and stargate now will not play and lincoln lawyer I'm not sure if it ever played
post #12846 of 12886 Old 10-21-2011, 05:57 AM
mr.kludge's Avatar
Quoted: 99 Post(s)
Liked: 115
Hmmm. I don't have access to an operational p1400 at the moment so I can't test for you, but there might be an issue with Lionsgate and the 2.5 firmware. Did you try downgrading to the older firmware to see if that resolves the issues with all the titles? Do you happen to have the 2.4 download? I didn't grab that one, unfortunately.
post #12847 of 12886 Old 10-21-2011, 10:13 AM
Cougar360's Avatar
I don't have a way to downgrade on my firmware
post #12848 of 12886 Old 10-21-2011, 10:31 AM
mr.kludge's Avatar
Quoted: 99 Post(s)
Liked: 115
All you do is re-load the disc for the older firmware versions. However if you have been dong the online downloads you won't have the images or discs. Perhaps someone on the thread has those and you could try. I always download and burn a disc, that way I can go back if I have to. The Sammy firmware updates (at least for the older players) are all inclusive on the firmware so you can replace it with an older version. Sammy will tell you this is not possible, but I have done it many times without ill effects. It is suspicious that this happened after you updated, but the only issues with Lionsgate that I am aware of is whatever condition happens to the loader to make it not like some Lionsgate titles. Someone else on the thread will need to test one or all of these for you. I will double check Am. Psycho, Stargate and T2 when I get a chance on the BD-P5000 (they share similar BD code). When I rented Lincoln Lawyer I don't recall any issues.
post #12849 of 12886 Old 01-02-2012, 09:45 AM
rich123's Avatar
Jurassic Park BD works fine with latest firmware
rich123 is offline
post #12850 of 12886 Old 01-02-2012, 10:34 AM
westgate's Avatar
my sylvania (funai) bdps' hdmi output stopped working so i broke out the 1400 and have been using it again. still loads slow but otherwise seems ok.
have a new panny ordered,should have by next thurs or fri.
westgate is offline
post #12851 of 12886 Old 01-17-2012, 08:53 PM
hrob's Avatar
Originally Posted by laddieluv View Post
>>Having owned the stellar (I loved it!) 1400 from 7/07 to 2/11, I can tell you that I also made discs and updated firmware that way.
I also went "backwards" twice. Once during the "Avatar" fiasco. And one other time that I don't remember right now. My point is that both times went smoothly. It's just like any other FW update: the machine asks you if you want this number FW or that number FW on the screen. You just click the one you want. It absolutely recognizes it, but WILL NOT refuse the update. It just "thinks" it's a FW update. Doesn't care which direction you go.
My 1400 "died" on 2/5/11 because my DVR malfunctioned and caused my 1400's demise. Purchased two Sammy C5500's. So "cheap" compared to what I paid for my (treasured) 1400. And WOWZER. Do they load quickly.
Although I adored my 1400 (early adopter, ya' know. ), I was able to do a "load of laundry" by the time the movie loaded. With the C5500, it loads so quickly in comparison that I barely have time to grab my snack and sit down. LOVE it.
So good luck.
There are so few 1400 owners left. Sigh. And yes. I still get the updates from this 1400 board. 'Cuz it makes me remember a really "good" time in my life. - Arleen J
Samsung UNB7100 55" LED HDTV; Onkyo SR 600 SS; Samsung BD-C5500 BD Player (LR Home Theater)
Samsung LNC530 40" LCD HDTV; Samsung BD-C5500 BD Player (Downstairs Office/no additional sound system)
268 BD titles and counting
Recent Additions: "Crimson Tide" "Unknown" "The Lincoln Lawyer"
Still have mine. Got it in Oct of 2007. Cost 499 new (found receipt and manual). Still runs well. No plans to upgrade anytime soon. My receiver won't support the latest HDMI standard for 3D, and that's what I'd want to upgrade to.
But like everyone else I've had to upgrade firmware from time to time.
hrob is offline
post #12852 of 12886 Old 03-02-2012, 06:37 PM
rich123's Avatar
There's a new firmware ISO_BDP1400_XAA_111202_01_WEBSITE.iso (Version 2.6) on Samsung's web site. Perhaps it will work better?
rich123 is offline
post #12853 of 12886 Old 03-03-2012, 09:08 AM
hansangb's Avatar
Wow, I really didn't think I'd see another update for this unit! thanks for the info.
Hansang
hansangb is offline
post #12854 of 12886 Old 03-17-2012, 08:48 PM
Xerowarp's Avatar
Wow, glad to see the thread is still alive, kinda like my trusty 1400. I'm happy there's a new FW however, I haven't needed an update in ages. Everything seems to play great. I do realize I just jinxed my player. Haha...
Xerowarp is offline
post #12855 of 12886 Old 03-18-2012, 06:49 AM
laddieluv's Avatar
>>to see this thread going.
Sadly, I had to "retire" my 1400 on 2/5/11. It "died" when my DVR malfunctioned and "kildit."
However as an early adopter of BD (7/07), I have such a "soft spot" in my heart for the 1400 that I still subscribe to this thread.
Hang in there, 1400 users. You're a "rare" breed. And, IMO, special.
303 BD titles and counting
Recent Additions: "Drive" "Ides of March" "The Descendents"
laddieluv is offline
post #12856 of 12886 Old 03-18-2012, 10:35 AM
mr.kludge's Avatar
Quoted: 99 Post(s)
Liked: 115
And it got a new firmware update in January, which I could say the same for my BD-UP5000, hasn't seen new code since the middle of '10.
post #12857 of 12886 Old 03-23-2012, 01:08 AM
Cougar360's Avatar
Dose anyone know if this update made it so that i can play t2 Lincoln lawyer and American psycho again cuz after i went from 2.3 to 2.5 all that was lost
post #12858 of 12886 Old 03-23-2012, 08:17 AM
mr.kludge's Avatar
Quoted: 99 Post(s)
Liked: 115
Give 'er a try and let us know. If you have been downloading the images and burning update discs then you can always go back. If not you will be stuck at the latest release. I forget which but some of the players don't update to the latest through the network port anymore so best to do the disc updates. I never trusted the online and have always done disc or usb updates on all my players and keep the updates backed up on disc or laptop.
post #12859 of 12886 Old 03-27-2012, 05:34 AM
jeff1967's Avatar
Quoted: 35 Post(s)
Liked: 448
I heard that samsung released an update for the 1400 on this board. My 1400 has been retired to a comfortable closet for about 2 years and is considered my emergency back up player. So I figured go ahead break that baby out and update her.
When I connect via cat 5 I get a message that its up to date on firmware. I found the new firmware on the sammy website. My question is this: Doesn't Samsung put the updates on the server anymore? I never had to update via cd in the past that I can remember. Have you folks been able to update directly?
Panasonic TC-P55ST50 Plasma 55"
Oppo BDP-203 Blu Ray, Toshiba A30 HD DVD
Onkyo RZ-900 Receiver (7.1 Config)
Klipsch R28F, RC500, RS400, RB600, SW10 Sub
Cisco Explorer 8642HDC HD DVR
Mac Mini/PS3/Wii, Harmony Smart Control
jeff1967 is offline
post #12860 of 12886 Old 03-27-2012, 09:07 AM
mr.kludge's Avatar
Quoted: 99 Post(s)
Liked: 115
A couple years ago the network updates for the older players started doing this. I can only surmise that the servers used for the network/Ethernet updates are different or pointing to a location they are no longer updating. Always best to download and burn a disc anyway so you have it for backup in case you need to roll back. With the bd-up5000 this has been nessisary to play new Disney bds and manny new DVDs as well since Samsung broke the Disney code when they updated for avatar.
post #12861 of 12886 Old 07-30-2012, 06:13 AM
jeff1967's Avatar
Quoted: 35 Post(s)
Liked: 448
Well my 1400 is officially gone (to the yard sale gods in the sky). Had been retired a long time ago but I was holding it as a backup player. Now that decent players are under $100 I no longer felt the need to keep her around (plus, my Oppo has been a rock star champ!). Good luck to whoever shells out the few bucks to give 'er a new home. Who ever is still hanging around this thread please turn off the lights when you leave. smile.gif
jeff1967 is offline
post #12862 of 12886 Old 07-30-2012, 06:16 AM
Dozer42's Avatar
Oppo rocks. I got fed up with my 1400 long ago and replaced it with a Panny. Donated the 1400 to someone who can love it. Wish I could afford the Oppo Blu-Ray, but it's not the right time for that. Maybe once I get my sanity back.
Sports? Yes! Racing and Skydiving, because other sports like tennis, football and soccer only need one ball!
Dozer42 is offline
post #12863 of 12886 Old 07-31-2012, 06:35 AM
swarm87's Avatar
Quoted: 140 Post(s)
Liked: 105
am i the only one who still uses this dinosaur? man i need to save up for an new player
pcm=potato
bitstream=patato
swarm87 is offline
post #12864 of 12886 Old 08-02-2012, 04:44 AM
jordandk's Avatar
I still have mine too, it's working and rock solid in the bedroom. Just moved it in there for a couple of months ago. Using my HTPC in the livingroom now.
jordandk is offline
post #12865 of 12886 Old 08-02-2012, 02:18 PM
innuss's Avatar
Quoted: 39 Post(s)
Liked: 29
I fired up mine today in my office & it still is humming along:)
innuss is offline
post #12866 of 12886 Old 09-22-2012, 10:22 AM
Xerowarp's Avatar
My 1400 is connected to my Sansui G-8000! Rocking sound thanks to built in decoding from the 1400. I've yet to have a single problem with a disc. I can't remember what FW i'm currently on. It was the one you had to use to get Avatar to work right. I think it's 1.9 or 2.0?? Still lovin' my 1400!biggrin.gif
Xerowarp is offline
post #12867 of 12886 Old 09-24-2012, 02:53 PM
swarm87's Avatar
Quoted: 140 Post(s)
Liked: 105
with avengers coming out id upgrade to the latest 2.6, almost a year old but better to be safe
http://www.samsung.com/us/support/owners/product/BD-P1400/XAA
pcm=potato
bitstream=patato
swarm87 is offline
post #12868 of 12886 Old 09-24-2012, 07:28 PM
Xerowarp's Avatar
I'll be at Walfart to pick up my copy at midnight. I'll you know if it plays.
Xerowarp is offline
post #12869 of 12886 Old 09-24-2012, 11:06 PM
Xerowarp's Avatar
Avengers plays great! Pretty fast load for the 1400. All menus work. smile.gif
Xerowarp is offline
post #12870 of 12886 Old 09-26-2012, 07:15 PM
laugsbach's Avatar
Quoted: 169 Post(s)
Liked: 223
WOW...eek.gif This thread is still going and on the first page....brings back some great memories. smile.gif
I wonder where Barney DaPurple1 & Smarty-pants have run off to?...back in the format war this was such an entertaining thread. cool.gif
I am amazed that a new release like The Avengers plays on the 1400 without a FW update...how long did it take to load?
laugsbach is offline
Reply Blu-ray Players
