Pioneer to launch BDP-95FD Blu ray player - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 234 Old 09-11-2007, 01:15 PM
nelson57's Avatar
Originally Posted by zaRgbE View Post
That is correct.
Thanks guys. This helps me make more intelligent buying decisions.
nelson57 is offline
post #92 of 234 Old 09-11-2007, 02:46 PM
srbraith's Avatar
Im getting all pioneer elite components delivered and installed on the 22nd of sept.
the 1) 110FD plasma TV
2) the VSX-94TXH receiver
and 3) the BDP-94HD Blue-ray
would it be worth it for me to wait for the 95 blue-ray (I can still return the 94) or should I just stick to what I have and keep the 94 blue-ray?
The receiver is HDMI 1.3 and can decode all the DTS HD and the Dolby True HD stuff already...so will the 95 make things better?
srbraith is offline
post #93 of 234 Old 09-11-2007, 04:27 PM
nelson57's Avatar
My understanding is that unless a firmware update is released, the 94 cannot currently pass the DTS HD/MA through bitstream for your 94TXH to decode, while the 95 will be able to.
My dealer is going to allow me to swap my 94 for a 95 when they get them, because had I known the 95 was coming so soon I would have waited. Thats just my 0.2.
nelson57 is offline
post #94 of 234 Old 09-11-2007, 04:48 PM
joerod's Avatar
Quoted: 607 Post(s)
Liked: 491
Once the 95 comes out (soon) it will be easier to answer your question. On paper the 95 should be better but until we get hands on experience we can't say for sure...
My Sony 5000ES Review PART 2 FINISHED:
http://hstrial-jrodriguez996.homeste...=1462841668379
joerod is online now
post #95 of 234 Old 09-11-2007, 04:56 PM
RBFC's Avatar
Quoted: 82 Post(s)
Liked: 65
Originally Posted by nelson57 View Post
Thanks Lee. I guess the key here is what is actually doing the DECODING. So correct my understanding here if this is wrong:
If the PLAYER can truly do the decoding internally, than I would be able to use my analog connections and get either Dolby TrueHD or DTS-HD/MA. If the player sends bitstream out, than the RECEIVER must do the decoding, and therefore must be one that has HDMI 1.3 and the ability to decode these formats. Is this correct?
I also agree. You understand what's going on.
Lee
GoldenEar Triton One speakers (6, for front, side surround, and rear surround), GoldenEar SuperCenter XXL center channel, GoldenEar HTR7000 overhead speakers (4), JL Audio F113 x 2 (subwoofers), Krell Foundation pre-pro, Krell EV403 (front 3 channels), 2 x Krell S1500/4 (one for each side's 2 surround and 2 overhead speakers), OPPO 105D (Blu-ray, SACD, DVD-A), Calyx Audio DAC24/192, MacMini w/ 2TB drive (server), Purist Audio interconnects & speaker cables, Sony XBR-75Z9D monitor.
RBFC is offline
post #96 of 234 Old 09-11-2007, 05:03 PM
RBFC's Avatar
Quoted: 82 Post(s)
Liked: 65
Pioneer's site states that the VSX-94TXH receiver does decode DTS-HD/MA. In that case, it will accept the bitstream from the BDP-95HD player and decode it properly. So, yes, it will be worth it to have the 95.
Lee
RBFC is offline
post #97 of 234 Old 09-11-2007, 05:42 PM
BLT
BLT's Avatar
Hey guys what do you think the chances are for a firmware upgrade for the BDP 94 to decode DTS HD(not HR or MA)?
BLT is offline
post #98 of 234 Old 09-11-2007, 07:40 PM
Tolstoi's Avatar
Do you have any Fox BD movies? No TrueHD. No PCM. But there is DTS HD MA.
The only BD or HD DVD I have with only DTS HD is movies from Europe. DTS HD seam to be a lot more popular on European Titles.
Tolstoi is offline
post #99 of 234 Old 09-12-2007, 10:49 AM
HTMan34's Avatar
Originally Posted by Tolstoi View Post
I will not upgrade my BDP-HD1 until pioneers give us a bd 1.1 out of the box compliant player (not a promise of an upgrade).
I will be waiting for a 2.0 Pioneer Elite unit that decodes ALL the advanced audio codecs internally before I replace my HD1!
Go Celtics!
HTMan34 is offline
post #100 of 234 Old 09-12-2007, 10:52 AM
HTMan34's Avatar
I believe the HD1 and the 94HD will receive a FW update for DTS-HD HR sometime in October, right around the release of the 95HD, just like the HD1 received a TrueHD FW update right before the release of the 94HD...This of course is not fact from any source, just a prediction.
Go Celtics!
HTMan34 is offline
post #101 of 234 Old 09-14-2007, 12:04 PM
alwynwilliams's Avatar
Looking at the iminent release of the BDP 95FD ($1000) and the Samsung BD-P2400 (600) Looking at the specs on both units they seem to me very simular can anyone explain why one is woth so much more.
alwynwilliams is offline
post #102 of 234 Old 09-14-2007, 12:42 PM
rveras's Avatar
Pioneer ELITE components usually are more expensive because they are build with higher quality components, according to Pioneer.
rveras is offline
post #103 of 234 Old 09-14-2007, 01:48 PM
slimoli's Avatar
Quoted: 482 Post(s)
Liked: 227
The same difference between a Kia (Korea) and a Lexus (Japan).
I was so happy without HDR...
slimoli is online now
post #104 of 234 Old 09-16-2007, 12:01 PM
Well I have a lexus sc430 but I havent tried the other one
post #105 of 234 Old 09-16-2007, 07:00 PM
zaRgbE's Avatar
I have a Lexus. Best car I've ever owned. Not a single problem with it. Well worth the money.
zaRgbE is offline
post #106 of 234 Old 09-16-2007, 07:27 PM
Slim GoodBooty's Avatar
AS far as I know the 94 will never pass TrueHD or DTSMA as bitstream, no matter what firmware they make for it.
Slim GoodBooty is offline
post #107 of 234 Old 09-17-2007, 11:13 AM
nakenergy's Avatar
Well in this case I will go for a Kia since the Kia has the Reon chip which the Lexus does not.
nakenergy is offline
post #108 of 234 Old 09-17-2007, 11:57 AM
BaronVH's Avatar
All I can say is they really need to delay the thing to make it 1.1 compliant. I personally do not care one whit for the extra features, just give me the movie with the best audio possible and a good picture quality. However, Pioneer is catching heat for releasing the same player with just a few more features, and it would be a real boost to the Blu-ray camp to have a 1.1 player with the quality that Pioneer has to be out before the Christmas buying season.
BaronVH is offline
post #109 of 234 Old 09-17-2007, 12:02 PM
joerod's Avatar
Quoted: 607 Post(s)
Liked: 491
All signs point to an October release. I don't really care about their 1.1 specs. I plan to get the 95FD soon and just enjoy the movies...
post #110 of 234 Old 09-17-2007, 12:36 PM
tosehee's Avatar
Originally Posted by hippy fascist View Post
Seriously this is getting beyond a joke now.
The ps3 has no games so as soon as anyone releases a BD player that beats the ps3 and is 1.1 compliant I'm selling my ps3 and getting that.
Can we at least expect to see 1.1 players some time in the next 6 months?
+1
Speakers: Monitor Audio GR60, GRLCR, GR-10
Receiver: Pioneer VSX-92
Amp: (Still searching...)
tosehee is offline
post #111 of 234 Old 09-17-2007, 12:45 PM
joerod's Avatar
Quoted: 607 Post(s)
Liked: 491
Maybe the Denon unit in December???
post #112 of 234 Old 09-17-2007, 06:42 PM
zaRgbE's Avatar
Originally Posted by tosehee View Post
+1
What it is with these "+1" responses that are beginning to smear the threads? I mean, it isn't a poll. Can't the responder come up with a response that actually contains words and thoughts and contributes to the discussion? "+1" just doesn't cut it! LET'S STOP THIS UNSETTLING TREND.
zaRgbE is offline
post #113 of 234 Old 09-17-2007, 07:09 PM
joerod's Avatar
Quoted: 607 Post(s)
Liked: 491
+1 just kidding That was to easy, and lazy...
post #114 of 234 Old 09-17-2007, 07:33 PM
Gary Murrell's Avatar
I am ready for the 95FD also, bring it on, don't give a rats ass about profiles
-Gary
Gary Murrell is offline
post #115 of 234 Old 09-18-2007, 09:19 AM
joerod's Avatar
Quoted: 607 Post(s)
Liked: 491
October is almost here!
post #116 of 234 Old 09-18-2007, 12:46 PM
lrstevens421's Avatar
+1. Is magnolia or anyone doing pre-orders on this puppy yet?
Making the most out of what I got.
lrstevens421 is offline
post #117 of 234 Old 09-19-2007, 06:14 AM
kevinuk's Avatar
Sorry if this has been asked but do we know what the release date of this model will be yet?
Kevin
kevinuk is offline
post #118 of 234 Old 09-19-2007, 08:38 AM
clarkbar911's Avatar
Kevin
Chris with Pioneer said early October in another thread.
clarkbar911 is offline
post #119 of 234 Old 09-19-2007, 09:27 AM
kevinuk's Avatar
Thanks for that.
kevinuk is offline
post #120 of 234 Old 09-19-2007, 09:35 AM
dobyblue's Avatar
-Gary
I agree completely with you. Me likey, me wantey. Now.
dobyblue is offline
Reply Blu-ray Players
