Official PS3 FAQ Master Thread - Page 130 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #3871 of 4532 Old 05-20-2011, 06:42 PM
PlatinumSV's Avatar
Quoted: 171 Post(s)
Liked: 90
Hello all,
I just picked up another PS3 (320Gb). I have the output set to bitstream but my processor says Multi. I called tech support and we unchecked all the LCPM in the audio setup, which worked. Now the guy told me that even though you selected bitstream, the ps3 will output the highest resolution that your Pre-amp can handle and if its capable of handling a higher pcm signal than DD or DTS than it will. I speaking of strictly games. Is this true.
PlatinumSV is online now
post #3872 of 4532 Old 05-21-2011, 04:46 AM
bushy81's Avatar
Originally Posted by PlatinumSV View Post
Hello all,
I have no idea myself but im definitely going to try it when I get home. Sounds interesting.
bushy81 is offline
post #3873 of 4532 Old 05-29-2011, 06:55 PM
snyper99's Avatar
Quoted: 23 Post(s)
I just signed up for Netflix through my PS3 and when i play movied that show (5.1) i get (2.0) what gives?I have a Yamaha RX-V663 and have the input audio option set to auto.I have all the audio options checked on my PS3.
snyper99 is offline
post #3874 of 4532 Old 05-29-2011, 08:47 PM
nelgsta's Avatar
PS3 audio can be tricky...
nelgsta is offline
post #3875 of 4532 Old 05-30-2011, 12:09 AM
WhatHappend's Avatar
Originally Posted by snyper99 View Post
I just signed up for Netflix through my PS3 and when i play movied that show (5.1) i get (2.0) what gives?I have a Yamaha RX-V663,i have all the audio options checked on my PS3.
On the PS3 Netflix player you have have to select the 5.1 audio stream (English Dolby Digital Plus 5.1). The 2.0 (English Stereo) is the default selected audio stream.
The selection is under "Audio and subtitles" in the same menu that starts the movie steaming (there are actually at least 3 different UIs for the Netflix plugin on the PS3, so I am assuming you have the most common one).
WhatHappend is offline
post #3876 of 4532 Old 05-31-2011, 07:25 AM
crakarjax's Avatar
Quoted: 56 Post(s)
What ??!?!? I don't remember seeing this menu... do you have to select 5.1 every time you play a title, or does it remember your preference? To think, I could have had better audio this whole time!
crakarjax is offline
post #3877 of 4532 Old 05-31-2011, 02:06 PM
The menu only shows up for titles that have 5.1 audio or available subtitles. Look at title "Shoot First and Pray You Live", it is HD and has 5.1 Audio.
After you select it for one 5.1 title is seems to stay for me. Once and a while I have had to reselect it.
Image attached
post #3878 of 4532 Old 05-31-2011, 04:45 PM
snyper99's Avatar
Quoted: 23 Post(s)
Image attached
I did that and I still got 2.0,ill mess with it again later on and see what happens.
snyper99 is offline
post #3879 of 4532 Old 06-01-2011, 08:18 AM
Are you using HDMI for the audio? I just tried all three combinations of PS3 HDMI audio settings and all 3 worked. I enabled only DTS over HDMI and the PS3 transcoded the DD+5.1 to DTS, I enabled only DD5.1 and PS3 converted the DD+5.1 to DD5.1, and I enabled only PCM multi-channel and PS3 decoded DD+5.1 to PCM 5.1 channel.
Do you get multi-channel sound from Bluray,PS3 Games and DVDs? When you press "Display" on the PS3 does the netflix overlay display show the audio as "Audio: English / 5.1 (PRIMARY)"?
Did you try to play the title that I mentioned?
post #3880 of 4532 Old 06-03-2011, 03:57 PM
snyper99's Avatar
Quoted: 23 Post(s)
Ok,I got it now.I was under the impression that since the movies were in HD they would come in 5.1 as well.BD's play in 5.1 as well as games.Guess Ill just have to keep using PLIIto get 5.1.
snyper99 is offline
post #3881 of 4532 Old 06-04-2011, 05:11 PM
crazybarry's Avatar
Hi,
I've had my PS3 for awhile with no issues watching Blu-ray movies. Today I put in a Blu-ray movie and the video is shaking. I tried it with a couple of Blu-ray movies (True Blood Season 3 and Inglourious Basterds) and both had the same behavior. I then tried it with a DVD and no issues. Any suggestions??
Thanks in Advance,
Barry
crazybarry is offline
post #3882 of 4532 Old 06-04-2011, 06:08 PM
caiobl's Avatar
Originally Posted by crazybarry View Post
Hi,
Thanks in Advance,
Barry
Try to change the hdmi cable. Or the hdmi port on the receiver or tv. It worked for me a while back.
caiobl is offline
post #3883 of 4532 Old 06-06-2011, 10:10 AM
pacemaker's Avatar
Quoted: 30 Post(s)
Hi Guys
first time poster here so be gentle
can some kind person confirm or correct me on the following
I would love to own a PS3 and use it for bluray/video playback but when i last borrowed one it appeared that you could only set the output to 24Hz for Bluray?
it would not do the same for 24fps vidoes on my Network meaning they badly stutter
is this still the case as it renders a PS3 useless as media centre?
pacemaker is offline
post #3884 of 4532 Old 07-03-2011, 12:44 PM
devo235's Avatar
Is there any easy way to watch a Region "B" encoded Blu-Ray disc from Europe on a NA playstation 3?
I ordered a few discs that I thought were "ABC", but turned out to just be Region "B" locked.
I recall that there was a fairly stright-forward way to do this about a year or so ago, but after all the newer firmware updates, I wondered if this was still possible.
If anone has any info/links to info, they would be much appreciated, thanks.
devo235 is offline
post #3885 of 4532 Old 07-03-2011, 01:49 PM
drhankz's Avatar
Quoted: 78 Post(s)
Liked: 65
Go to a region "B" Country
No way I know of
drhankz is offline
post #3886 of 4532 Old 07-03-2011, 02:57 PM
Electric_Haggis's Avatar
Quoted: 24 Post(s)
Seems like there never will be either.
Best thing is to grab a Kogan...
http://www.kogan.com.au/shop/category/blu-ray-players/
or better still, an Oppo....
http://www.oppodigital.com/
Electric_Haggis is offline
post #3887 of 4532 Old 07-05-2011, 10:56 AM
LuV2SPD's Avatar
No way I know of
There might be a PC software that can convert it for you.
LuV2SPD is offline
post #3888 of 4532 Old 07-05-2011, 10:58 AM
drhankz's Avatar
Quoted: 78 Post(s)
Liked: 65
Your suggestion might be possible but there is no
way it would play it AS IS.
drhankz is offline
post #3889 of 4532 Old 07-05-2011, 11:19 AM
Wryker's Avatar
Quoted: 134 Post(s)
Liked: 52
last option would be to use a decrypting program (ANYDVD, DVDFAB, etc) to rip it as an image and mount it on your PC and watch it that way or burn it to a blank BD-R.
"..where you will never find a more wretched hive of scum and villainy."
Wryker is offline
post #3890 of 4532 Old 07-05-2011, 07:18 PM
lchiu7's Avatar
Quoted: 12 Post(s)
Sort of what I did. I ripped the movie I could not play, re-encoded them to save on space and muxed back with the original audio. I then output AVCHD format and burnt to a DL DVD and the PS3 played it fine. So the video got compressed to about 7GB allowing for 2G of audio. I also experimented with not re-compressing the video which created a much larger file of course. But using MultiAVCHD which cuts up the .ts streams at 4G chunks with seamless branching, the AVCHD folder could be copied to a USB drive formatted FAT32 and again the PS3 played that fine.
That's what I have also but the Oppo isn't region free out of the box. I had to purchase a region free hardware kit to make that work. But it does work well and the Oppo now can play all region BD and all region DVD's.
lchiu7 is offline
post #3891 of 4532 Old 07-08-2011, 02:17 PM
gvn
gvn's Avatar
I have a PS3 and purchased a Samsung plasma that came bundled with the Samsung BD-D5500. Is there any reason to keep the Samsung player?
gvn is offline
post #3892 of 4532 Old 07-08-2011, 02:51 PM
crakarjax's Avatar
Quoted: 56 Post(s)
The 3D capabilities of the player are probably better than the PS3... if I recall, the PS3 cannot do HD audio and 3D output at the same time? Then again, the difference will probably not be noticeable unless you have a great audio system.
post #3893 of 4532 Old 07-08-2011, 06:04 PM
upstate-avfan-da's Avatar
Quoted: 83 Post(s)
Liked: 41
I think this is correct. Not enough in the ps3 to handle lossless with 3d.
Bit by the upgrade bug, limited by the WAF
upstate-avfan-da is offline
post #3894 of 4532 Old 07-09-2011, 02:57 PM
gvn
gvn's Avatar
Cool, thanks guys.
gvn is offline
post #3895 of 4532 Old 07-11-2011, 06:01 AM
ral b's Avatar
I want to buy a PS3 for my nephews, the problem is that they have a 29 inch Sony crt TV in their bedroom. I am worried they might not be able to play FIFA 11 and other games the have been bothering me for. Is this a non-issue or do i have to get an lcd or plasma hdtv for them as well ?
ral b is offline
post #3896 of 4532 Old 07-11-2011, 07:58 AM
Quoted: 83 Post(s)
Liked: 41
Sony has a regular adapter for older sets. Look up PS3 AV Cable. Although with this output will be 480i to match the tv, to really get the most out of it an upgrade to an LCD should be considered. You can find cheap 32" sets that do 720 or 1080.
post #3897 of 4532 Old 07-11-2011, 08:26 AM
centauro74's Avatar
Yeah, I bought a 26" vizio led tv for $175 from amazon seller, the tv was like new and has great PQ.
centauro74 is online now
post #3898 of 4532 Old 07-11-2011, 08:54 AM
LuV2SPD's Avatar
I have a problem with my PS3.
I have both PS3 controller and PS BD remote. By pressing the PS button on either one turns on the PS3 right. Lately by pressing the PS button I get no response. The 4 red lights on the PS3 controller flash about 10 seconds when I press the PS button but the PS3 won't turn on. So, I turn on the PS3 manually, connect the PS3 controller with a USB and I'm able to navigate and play with the controller while the PS BD remote still not functioning. As soon as I unplug the PS3 controller it stops working. Sony tech support suggested to reset the PS3 controller so I did and it still didn't work. My PS3 signs in to the Network automatically and I noticed that my PS3 doesn't sign in automatically when I power it on. I turn off my PS3 and turn it back on again and it does sing in to Network automatically. As soon as the PS3 signs in to Network the PS3 controller and PS BD remote work fine. Am I having some kind of PS3 Network adapter failure?
LuV2SPD is offline
post #3899 of 4532 Old 07-11-2011, 11:29 AM
crakarjax's Avatar
Quoted: 56 Post(s)
Have you tried pairing the controllers with the ps3 while not signed in?
post #3900 of 4532 Old 07-11-2011, 02:51 PM
LuV2SPD's Avatar
Yes, during the PS3 not being signed in I tried pairing but nothing happens. Only after turning it off and on, sometimes more then once makes the PS3 sign in automatically.
LuV2SPD is offline
Reply Blu-ray Players
Blu Ray Players , Playstation 3 160gb System , Sony Blu Ray Disk Remote For Sony Playstation 3
