Official PS3 FAQ Master Thread - Page 150 - AVS | Home Theater Discussions And Reviews
post #4471 of 4495 Old 02-26-2014, 05:21 PM
Louis Bartay's Avatar
Quoted: 153 Post(s)
Liked: 539
Originally Posted by DVD Freaky View Post
So why is the PS3 outputting 5.1 when it should be only outputting 2-channel? When I push select when playing a Blu-Ray, it says 5.1. Dialogue for movies is pretty much impossible to hear, no matter what the volume level is. It is faint as can be. That was not the case with previous PS3 I had. I've been through all the settings and can only conclude the PS3 is not outputting the sound via 2-channel, as it should.
Tomorrow when I have time I will going to my settings on my PS3 Slim and look at what it takes to select 2.0.
Have you done a system"hard" reset? Not a restore settings on page 42 of the owners manual. http://answers.yahoo.com/question/index?qid=20130208162649AAR2TXQ
IIRC you have to "Save" new audio settings, are you sure you did this correctly.
DVD Freaky likes this.
Klipsch Cornwall I,C7,RS3-II
Klipsch Heresy II, KSB 1.1
Klipsch Sub 12" X3 Hafler P3000,P1000, DH330 DH110
Yamaha RX-V1900, T-1000,A-1000 Class A, GE-20 GEQ CDC-697
ReVox A-77 Mk IV Dolby, Nakamichi BX-100 PL-518X DL103R
Louis Bartay is online now
post #4472 of 4495 Old 02-26-2014, 06:51 PM
DVD Freaky's Avatar
Originally Posted by Quicksilv3r View Post
Like I said in a previous post to you, if you go into your PS3, go to the settings, select the sound setup or whatever it's called, and run the setup, it will detect you are using a TV and only give you options for 2 channel sound. Select that, and then go into your movie or game, and it should output in 2.0 sound and audio isn't clipped or impossible to hear because it's being mixed to 2 channels instead of 5.1 sound.
Yes I know, that's what I did. 2-channel sound is selected in the setup (automatically, via HDMI...I checked).. THEN, when I play a BD, the dialogue is incredibly faint, no matter the volume. I push SELECT on my PS3 controller and see that it's outputting 5.1 sound.
Exchanged my PS3 for a new one today and will test later tonight.
DVD Freaky is offline
post #4473 of 4495 Old 02-26-2014, 06:55 PM
DVD Freaky's Avatar
I did a restore settings previously and it didn't work. I called Sony Tech Support and they were incredibly clueless. I have exchanged the 3-week-old PS3 for a new one today and will test later tonight.
In the mean time, I will look into the hard reset option....thanks!
post #4474 of 4495 Old 02-27-2014, 07:43 AM
MCF34's Avatar
I have my PS3 connected to my SC-65 via HDMI and my SC-65 connected to my Panasonic VT-60 via HDMI. With the receiver off I am having no problem getting video to my tv, but I cannot get the sound to pass. I have checked all the settings on the recieved, PS3 and tv and I don't see an issue. The PS3 is set to pass both dolby digital and 2 channel stereo. The tv is set to tv volume instead of home theatre volume (in fact, when you turn off the reciever the tv automatically switches to tv volume). But no matter what I do I cannot get the volume from the tv. Any thoughts??
Jutter is gone..zipadeedoodah zipadeeday!!!
MCF34 is offline
post #4475 of 4495 Old 02-27-2014, 08:05 AM
Rudy1's Avatar
Quoted: 173 Post(s)
Liked: 146
Could it be that the PS3 is not passing audio to through to the TV because it is setup to do so for the AVR? Try going through the audio settings process on the PS3 with the AVR off and see what happens.
Rudy1 is offline
post #4476 of 4495 Old 03-03-2014, 11:06 AM
Ron Jones's Avatar
Quoted: 437 Post(s)
Liked: 416
I've updated the PS3 FAQ, Post #2 of this thread, to indicate the current firmware version is 4.55.
Ron Jones
Blog + Reviews + Articles: projectorreviews.com
Ron Jones is offline
post #4477 of 4495 Old 06-02-2014, 07:50 AM
nathan_h's Avatar
Quoted: 190 Post(s)
Liked: 109
Looked through the FAQ for every instance of "NATIVE" to see what settings I need to toggle to get the PS3 to output video in whatever format it is, on the disc (ie, no scaling, no alteration of color space, etc) but it appears this topic is not addressed.
Does anyone know? I am using an external scaler, and it tends to work best with native rate sources.
____________________
Build thread & current gear: "Nathan's Theater in Search of....".
nathan_h is online now
post #4478 of 4495 Old 06-02-2014, 04:32 PM
nathan_h's Avatar
Quoted: 190 Post(s)
Liked: 109
UPDATE: Looks like it is not possible. For example, a DVD is *always* converted to 480P.
But hopefully that is the only exception. So far, that appears to be the case.
post #4479 of 4495 Old 06-17-2014, 03:55 PM
whatupdet's Avatar
Quoted: 23 Post(s)
I'm running the latest firmware on my 320GB PS3 and I was just playing Dark Knight Rises blu-ray on my system through my Denon X1000 receiver and it was working fine for a while but every now and then it would glitch and lose audio/video. Has anyone had this happen before?
The disc is fine as I used it in my Sony blu-ray player without any problems, AVR is new and so is the HDMI cable; PS3 is only 2-3 years old.
whatupdet is offline
post #4480 of 4495 Old 07-06-2014, 05:03 PM
Ron Jones's Avatar
Quoted: 437 Post(s)
Liked: 416
DVDs normally stores video in 480i format but many HDMI chips do not support this format with only 480p being offered for Std. Definition.
Ron Jones
post #4481 of 4495 Old 08-12-2014, 02:38 PM
Liked: 0
For the average user (such as me) there is a lot of information in the PS3 FAQ that can seem very complicated. For those of us that don't have such an in-depth understanding of these settings what would the best settings (on the PS3) be for the following:
(NOTE: PS3 is connected directly to a HDTV through HDMI. For audio the PS3 is connected directly to a 5.1ch Home Theater System through a Optical Cable. The Home Theater system only supports Dolby Digital, and not DTS. Also keep in mind the PS3 is a Slim model. Not the Super Slim model.)
With the above in mind what are the best settings for:
-VIDEO SETTINGS-
BD/DVD - Cinema Conversion:
DVD - Wide Display:
BD/DVD Upscaler:
BD/DVD - Video Output Format (HDMI):
1080p 24 Hz Output (HDMI):
BD/DVD - Dynamic Range Control:
BD/DVD - Audio Output Format (HDMI):
BD - Audio Output Format (Optical Digital):
50 Hz Video Output:
-MUSIC SETTINGS-
Audio CD Import:
Crossfade Playback:
Output Freqeuncy:
Bitmapping:
Dynamic Normaliser:
-DISPLAY SETTINGS-
Video Output Settings:
Cross Colour Reduction Filter:
RGB Full Range (HDMI):
Y Pb/Cb Pr/Cr Super-White (HDMI):
Deep Colour Output (HDMI):
-SOUND SETTINGS-
Audio Output Settings:
Audio Multi-Output:
TGR49 is offline
post #4482 of 4495 Old 08-14-2014, 11:44 AM
Liked: 0
Wow, this forum is pretty dead. Could someone at least tell me what the best setting is for BD - Audio Output Format (Optical Digital)? I have heard people say the best choice is Bitstream. The problem is there are two Bitstream options. One for Bitstream (Mix) and one for Bitstream (Direct). What is the best setting and what is the difference between the two?
I need an answer to this ASAP please.
TGR49 is offline
post #4483 of 4495 Old 08-17-2014, 07:06 PM
Ace_of_Sevens's Avatar
PS3 version 4.6 3d playback issues
My ps3 has stopped working for 3d blu-rays. The last time I watched one and it worked was June 22nd, which is right before 4.6 came out, so I assume that's the issue. I can play 3d video games and watch 3d movies on Netflix, but not 3d blu-rays. When i try to play them, the ps3 puts out a 3d signal. It gets noisy and bright as it tends to do in 3d and interface options like pause float in front of the TV, but the picture itself is only 2d.
I have a 60 GB fat ps3 and a panasonic 55-inch vt60. The PS3 is hooked directly to the TV via HDMI. My girlfriend has a 120 GB slim ps3. I hooked it up and the 3d works fine on it. I don't have access to other fat ps3s or 3d TVs to test. The Google seems to give me no info on this issue. Can anyone tell me anyone about what's going on?
Ace_of_Sevens is offline
post #4484 of 4495 Old 08-17-2014, 07:20 PM
Mix will mix in things like menu sound effects and direct is just the movie audio.
post #4485 of 4495 Old 08-31-2014, 11:43 AM
taxman48's Avatar
Quoted: 88 Post(s)
Liked: 111
have the old ps3 player. 3d movies are good. I wanted to hook up optical for sound only. My receivers 3 optical inputs work> I checked by switching around 1,2,3 and still get sound so I eliminated the AVR. Can't seem to get a choice on receiver input that will let me assign PS3 to optical. Is t time to get a new player? thanks in advance
taxman48 is offline
post #4486 of 4495 Old 10-10-2014, 05:07 PM
Dave_A_Anderson's Avatar
Quoted: 25 Post(s)
Liked: 8
I assume that you want HDMI video to the TV and optical audio to the AVR. I ran that way since launch with my 60GB and a non-HDMI receiver(until last month). Did you set PS3 audio to optical via "Settings->Sound Settings->Audio Output Settings"?
Dave_A_Anderson is offline
post #4487 of 4495 Old 10-10-2014, 05:33 PM
taxman48's Avatar
Quoted: 88 Post(s)
Liked: 111
Dave: I think the PS3 was the culprit. Went into setup and changed output to multi output.. Using HDMI to Projector and Optical to receiver for audio.. Using DVR 1 for optical output since the BD HDMI does not allow for change of Optical output..Enjoying 3D, using the Panasonic glasses that a member recommended on another forum..the JVC glasses were about $120.. thanks for the help with the problem.. members like yourself make this the best site on the web for audio/video problems. What receive did u wind up getting?
taxman48 is offline
post #4488 of 4495 Old 10-10-2014, 05:55 PM
Quoted: 25 Post(s)
Liked: 8
Glad you have it sorted out. Yeah, if you want audio over both HDMI and optical you have to set it to multi. If your AVR supports HDMI audio in that's your best bet. On the older PS3s you might have to go into BD audio and change to LPCM output. That way the discrete channels are decoded by the PS3 and sent to the AVR as discrete surround channels. That's a step up over optical.
My new toy is a Denon AVR-X5200W. So far the lossless BD audio is sounding pretty awesome but I haven't had time to play much since my PS3 just came back from a 2week repair yesterday.
post #4489 of 4495 Old 12-12-2014, 08:50 AM
QuiGonJosh's Avatar
Quoted: 118 Post(s)
Liked: 64
How to output 1080p 4:3 content and use grey bars on plasma?
Anyone know of any settings on the PS3 or other Blu-ray player so that I can use the 4:3 grey bar function on my plasma when outputting HD? When I set the TV to 4:3, it puts the grey bars on, but squeezes the 4:3 image of say Star Trek: The Original Series, into the 4:3 frame and adds thin black bars between the image and the grey bars. Help?
QuiGonJosh is online now
post #4490 of 4495 Old 12-15-2014, 09:41 PM
Liked: 0
Exclamation help
okie, so i cant get my dualshock 3 ps3 controller to charge. I need help, please!
bringmethehorizon is offline
post #4491 of 4495 Old 12-26-2014, 08:06 AM
Liked: 0
So... when set to "Bitstream (Direct)" there will be no sounds in the menus?
Also, I've heard some people claim that setting this to "Bistream (Mix)" actually causes performance problems for the PS3. Has it ever been revealed if those claims are true?
And again, which setting is the better one? Direct or Mix?
TGR49 is offline
post #4492 of 4495 Old 01-07-2015, 12:47 PM
ToonMasterTim's Avatar
Quoted: 64 Post(s)
Liked: 66
Not to sound like a noob, but is there a way to get the PS3 to show all of the 4:3 picture when watching DVDs? I noticed a difference in my Panasonic BD player and the PS3. The PS3s upscaler is set to Normal, which is the most natural and recommended setting, and my TVs picture size is set appropriately, but there are a few columns of pixels visible when viewed on the Panny that aren't displayed on the PS3. I had read from another member that some players do this, particularly Sonys, so perhaps it isn't just limited to the PS3. Someone recommended setting the upscaler on the PS3 to Off, but that blows up the image, causing it to be blurry and distorted. I have dug into the settings on the PS3 and don't see any way to correct it. The resolutions the PS3 outputs are compatible with my TV, 480-1080p.
ToonMasterTim is online now
post #4493 of 4495 Old 01-07-2015, 05:36 PM
jd213's Avatar
The PS3's DVD upscaling is some of the best there is (there were comparison pics with various other upscaling technologies posted in this thread PS3 vs. HTPC DVD Upscaling Comparison PIX , but the pictures are no longer up [edit: pictures were re-upped in post #19 ), but it does indeed cut off some of the edges. So you'll have to turn the upscaling off and let the TV do it (some TVs do it better than others), or live with the small bits of missing picture.
jd213 is offline
post #4494 of 4495 Old 01-08-2015, 11:52 AM
Quoted: 64 Post(s)
Liked: 66
Thanks for pointing out that thread. I am happy with the upscaling from the PS3, I was just curious as to why it doesn't display those columns. No one seems to know.
post #4495 of 4495 Old Today, 12:56 PM
latreche34's Avatar
Quoted: 21 Post(s)
Liked: 26
PS3 and BD-R / BD-R DL Playback
I have several BD-R and BD-R DL discs that I burnt onto some home videos (m2ts) as Blu-ray format with menus, I have always a problem playing them back on the PS3 console, So had to buy a stand alone player for that purpose only, every firmware release of PS3 I go back and try with no luck, The PS3 recognize the disc and displays the jacket on the screen but when hit play it thinks a while and it comes back with an error code, Is there something wrong with the disc structure or just Sony enabling this in purpose to fight against piracy which in my case is not.
latreche34 is online now
Reply Blu-ray Players
Blu Ray Players , Playstation 3 160gb System , Sony Blu Ray Disk Remote For Sony Playstation 3
Gear in this thread - 160gb by PriceGrabber.com
