Official PS3 FAQ Master Thread - Page 37 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #1081 of 4532 Old 12-11-2008, 07:22 AM
rawl316's Avatar
Originally Posted by rr330i View Post
rawl, can you run standard audio rca cables(red/white) from the DVR to the HTIB?
I would do that, and run optical from the PS3 to the HTIB.
The HTIB should be able to apply PLIIx to the rca inputs to give a surround sound.
Do you ever use the audio from the TV? or only the HTIB.
I don't ever use the audio from the TV. I guess the only time I might is if I were to use the upconverting dvd player that is built into the receiver.
another option is to buy the cable that converts the optical signal into a coax (I think). I do also have a plug for that.
rawl316 is offline
post #1082 of 4532 Old 12-11-2008, 08:13 AM
WhatHappend's Avatar
If that coax digital input is on a different input selection on the HTIB, you are set. If the two share the same input it is going to be no help.
I bet your DVR has a digital coax output on it (most cable DVRs seem to have them).
Optical to coax converters are pretty cheap.
WhatHappend is offline
post #1083 of 4532 Old 12-11-2008, 09:33 AM
Could you link me to one of IR optical audio switches you are talking about?
SPDIF or ADAT 4x1 Digital Audio Switcher $129
http://www.inday.com/da4x/da4x.htm
oh, and from what I understand, my crappy speakers wouldn't have much difference from bluray sound
I don't understand your comment. Bluray offers studio quality loss-less sound tracks. Only the best speakers and systems will be able to hear all the format has to offer.
If your HTIB has a passive sub-woofer, the speakers would be pretty much throw away. Have you ever said which HTIB system you bought?
post #1084 of 4532 Old 12-11-2008, 09:51 AM
Devil98's Avatar
Originally Posted by stubeeef View Post
OK, I have not done much research in quite awhile. Infact after reading some the last hour I see where I gave a stranger bad info (PS2's can play on PS3). I bought my PS3 over a year ago, it is the 80g that has some backward compatibility.
Anyway, my best friends wife called me to see which PS3 to get her huzband for Christmas, after reading some here and some at Sony, it seems the new 80 and 160g are the same. (Except of course the extra gigs!) Have I missed something?
Little help please.
For those wondering about buying one, I have had mine for over a year, it is awesome and the whole family LOVES it.
PS: can I record movies from a cable HD feed on to the PS3 HD? How?
I would consult the Sony website before you recommend buying a current production PS3. My understanding is that the current 80gb (no game bundled)and the new 160gb units have the perks of lower power consumption and quiter fans, but they are not backwards compatible. From what I could find, Sony was no longer planning to build backwards compatibility into new PS3s. That would be the reason I got a refurbed 80gb MGS4 package on ebay. A coworker just went through the same research, disappointment, and acceptance cycle, paying $500 on Amazon for a NIB MGS4 bundle. That appears to be the last production run with backwards compatibility. Good luck!
Devil98 is offline
post #1085 of 4532 Old 12-11-2008, 09:55 AM
rawl316's Avatar
If your HTIB has a passive sub-woofer, the speakers would be pretty much through away. Have you ever said which HTIB system you bought?
I bought the sony bravia 576.
rawl316 is offline
post #1086 of 4532 Old 12-11-2008, 09:57 AM
rawl316's Avatar
hmm, it never occured to me that they could be on the same input. I'll have to see if it is.
rawl316 is offline
post #1087 of 4532 Old 12-11-2008, 10:35 AM
bigbrain28's Avatar
Quoted: 43 Post(s)
They ARE on the same input. You only have ONE optical/coax input. You get 2channel BACK from the TV because that's what TV's output (Unless you have the ability to set the TV's spdif out to 'passthru', ie send OUT what it gets IN, you'll never get DTS, DD OUT of the TV into the HTiB).
Your only option for getting Surround from the DVR and the PS3 to your HTiB is to buy something like this; Monoprice SWITCH and plug the optical from the PS3 and the DVR into it, and then to your HTiB optical hole. This requires manual switching between sources, but is the cheapest way out for you.
bigbrain28 is offline
post #1088 of 4532 Old 12-11-2008, 11:31 AM
SaltwaterCat's Avatar
BTW, I have that switch and it works great.
A bad day fishing beats a good day at work!
SaltwaterCat is offline
post #1089 of 4532 Old 12-11-2008, 12:06 PM
rawl316's Avatar
thanks guys! I'll probably be purchasing that
rawl316 is offline
post #1090 of 4532 Old 12-11-2008, 02:48 PM
Tone-Loc's Avatar
I have pictures that I downloaded onto the PS3. My question is can I get them back off to a flash drive? If I sign on to my webmail via the PS3 can I attach one of the pics that is downloaded to the PS3?
Tone-Loc is offline
post #1091 of 4532 Old 12-12-2008, 08:04 AM
graphicguy's Avatar
Observation and questions....
I bought one of the first Panny 35s that came out. Had operational glitches that I couldn't live with and returned it. A friend of mine received a Panny 35 from his employer as a Christmas gift. He can't use it, so I bought it from him for $60 as a back up.
I have a PS3 as a BD player. Hooked up the Panny, too for comparison's sake.
While, the LPCM out of the PS3 compared to the bitstream from the Panny yielded similar results, the PS3 was louder.
But, the PS3's picture looked softer and the colors looked muted when compared to the Panny 35.
Anyone compare these two? Results?
Music so high you can't get over it....music so low you can't get under it!
graphicguy is offline
post #1092 of 4532 Old 12-12-2008, 08:21 AM
Hksvr4's Avatar
Quoted: 33 Post(s)
Liked: 37
Quick question,
I have music stored on my PS3 and it is plays through the receiver via HDMI. At almost all the time the music glitches. It almost like it skips like a CD but you won't hear it until you get close to the speakers.
Hksvr4 is offline
post #1093 of 4532 Old 12-12-2008, 08:30 AM
Pugnax555's Avatar
Originally Posted by Hksvr4 View Post
Quick question,
If it's a slight "ticking" sound then it was probably errors that were encountered when the disc was being ripped. Try cleaning the disc and reripping, and if you used something other than the PS3 to rip, see if the program has a "use error correction" option that can be enabled.
Pugnax555 is offline
post #1094 of 4532 Old 12-12-2008, 08:33 AM
Pugnax555's Avatar
Being a graphicsguy, I'm assuming you realize that the display device will need to be calibrated to each separate input device before you can really start doing output comparisons between the two.
post #1095 of 4532 Old 12-12-2008, 08:36 AM
Pugnax555's Avatar
Yes you can. Insert the flash drive. Find the pictures or folder you want to copy on the PS3 (folders are easier than single pictures obviously), press the Triangle button, then there should be a 'copy' option. Select that, choose the flash drive as the destination, then go. Same can be done with music and videos, too.
post #1096 of 4532 Old 12-12-2008, 08:52 AM
jpniner's Avatar
anyone know if a new ps3 Firmware update addresses the problem of the Nyko remote not being able to power on the ps3? I thought I read that somewhere but can't find confirmation.
Trying to decide on buying the Nyko to use now and later with a Universal
Or get the Sony and eventually the ps3toothfairy thing. The Nyko option is obviously cheaper so preferable.
jpniner is offline
post #1097 of 4532 Old 12-12-2008, 09:05 AM
graphicguy's Avatar
Yes....calibrated both following the recommendations here.
post #1098 of 4532 Old 12-12-2008, 09:09 AM
O1PewterWS6's Avatar
As long as you bought what they linked for the switch at Monoprice you will be satisfied. I also run the same setup, my DVR and PS3 to the switch into my one spot in my HTIB. Everything works great!
O1PewterWS6 is offline
post #1099 of 4532 Old 12-12-2008, 09:55 AM
SMG
SMG's Avatar
Hello, and thanks for a great FAQ. I read through it and didn't see my scenario covered.
I have a 1080P PJ connected via. HDMI, and would like to connect my Pioneer Plasma via. component video. I bought the sony multi-av component cable from Amazon, and hooked it up, but no picture on my Pioneer. I played around in the XMB, but didn't see how to make both outputs active.
This is crucial to my set up as the PS3 is my primary DVD player and I don't want to swap HDMI cables to watch a movie on my TV.
Please tell me some good news !
thanks,
Serv
SMG is offline
post #1100 of 4532 Old 12-12-2008, 10:01 AM
boblinds's Avatar
Quoted: 12 Post(s)
Liked: 40
Sorry, one of the braindead design decisions of the PS3 is that only one video output can be active. (The other one is that only one audio output can be active.)
boblinds is offline
post #1101 of 4532 Old 12-12-2008, 10:03 AM
bloomcounty's Avatar
Can/should information about the chroma upsampling feature be added to the FAQ?
Is there an option to turn this on/off in the menu somewhere, or is this something that is always on?
Has anybody used this or noticed a difference with it, bad or good?
For Blu-ray Discs, this feature is only available when playing discs that are recorded in BDAV format. BDAV is a Blu-ray Disc video format.
Is this the format that most/all Bluray movies are recorded in? If so, do you see an improvement in PQ since this feature has been added?
Thanks! Have a good weekend, everyone!
bloomcounty is offline
post #1102 of 4532 Old 12-12-2008, 10:07 AM
Do you have a BDAV disc to even worry about it. I would never want to disable that feature. I should only improve the picture. Since I don't have a Bluray burner and HD homevideo camera, it is a don't care for me at the moment.
post #1103 of 4532 Old 12-12-2008, 10:16 AM
thanks,
Serv
The FAQ post should be updated with this information. It is so basic that I don't think about it any more, but new purchasers will need to know.
The PS3 doesn't support simultaneous HDMI and analog video output or simultaneous HDMI, optical, or analog audio output. Only one output per Audio/Video selection at a time.
post #1104 of 4532 Old 12-12-2008, 10:16 AM
rawl316's Avatar
does someone mind providing a link to this? i would love to be able to use the harmony and program the remote to power on the PS3
rawl316 is offline
post #1105 of 4532 Old 12-12-2008, 10:20 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 3787 Post(s)
Liked: 4927
No. Commercial Blu-Ray discs are all BDMV. If the disc has menus or is copy protected then it is authored in BDMV.
BDAV is for owner produced content that has a simple playback structure and is not encrypted.
http://www.afterdawn.com/glossary/terms/bd-mv.cfm
http://www.afterdawn.com/glossary/terms/bdav.cfm
BDAV is primarily used for stuff burned to disc from HD camcorders. As such, motion adaptive color upsampling can help the image quality.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
post #1106 of 4532 Old 12-12-2008, 10:20 AM
No such firmware is ever expected.
How can we provide a link to something that doesn't exist.
post #1107 of 4532 Old 12-12-2008, 10:30 AM
Thanks, folks! Now I understand that it's if you have blurays you burned yourself and doesn't apply to regular movies (and so won't apply to me). Good to know!
post #1108 of 4532 Old 12-12-2008, 11:04 AM
jpniner's Avatar
I think the latest makes it possible to turn off, not on. so turning on is still an issue. firmware 2.5
If you plugged the Nyko USB into a nearby CPU instead of the ps3, would it work? That way the cpu is providing power to the USB hub.
jpniner is offline
post #1109 of 4532 Old 12-12-2008, 11:35 AM
stevec325's Avatar
The Nyko will not handle power - AFAK.
I use the PS3ToothFairy. It allows both power on and off. The IR2BT device works like this, too - so I understand. These features were available both before and after 2.5x, although there was some issues (resolved) back in the the 2.4x range.
I can recommend the PS3TF 100%.
I am also using a Harmony One remote and switching activities to/from the PS3 is effortless and flawless.
-steve
My HT Setup - updated 12/25/2012
"...and all the science, I don't understand. It's just my job, five days a week."
stevec325 is offline
post #1110 of 4532 Old 12-12-2008, 12:11 PM
hullabal00's Avatar
Hi
I'm getting this message when I try to play Deception blu-ray disc on the ps3:
WARNING: This player is not equipped with the latest firmware and is unable to play this disc. Please visit your manufacturer's website and follow their instructions on how to install the firmware on your player.
For more information on Blu-ray and firmware updates please visit www dot foxbd dot com/cs (Sorry, they won't let me post the url)
I believe I have the latest ps3 system update at 2.53 and I have been able to play other movies i.e. Tropic thunder, iron man, etc. Any help would be greatly appreciated.
hullabal00 is offline
Reply Blu-ray Players
Blu Ray Players , Playstation 3 160gb System , Sony Blu Ray Disk Remote For Sony Playstation 3
