Dell laptops as Blu-ray players via VGA. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-03-2007, 07:49 PM - Thread Starter
Steve Dodds's Avatar
I'm getting a new laptop and thought I may as well get one with a Blu-Ray drive to dip a toe in the HD water.
The model that suits my needs beat is the Dell 1520. However, it has no HDMI or even DVI output, being limited to S-Video or VGA.
So, can I get the hi-def info out to my scaler/receiver/projector via the VGA output, and if so will it be at full resolution?
Steve Dodds is offline
post #2 of 7 Old 11-03-2007, 08:10 PM
counterpoint's Avatar
No receiver I know of supports VGA, but projectors generally do support it. How do you plan to output the audio to your receiver? And I highly doubt it will output full resolution. Seems like a flawed strategy to me.
Gear: Pioneer Elite KURO PRO-151FD, Yamaha RX-A860, Custom HTPC, Emotiva XPA-5, Sony BDP-S6500, [Rocket RS850 Sig, RSC200, RS250 MKII], (2) MFW-15.
Currently testing out the HSU VTF-15H MK2.
counterpoint is offline
post #3 of 7 Old 11-03-2007, 08:33 PM
grommet's Avatar
No PC based HDM playback application will allow content to pass via VGA, unless the protection has been removed using most likely illegal tools. Thank you, DRM and HDMI.
grommet is offline
post #4 of 7 Old 11-03-2007, 08:51 PM - Thread Starter
I have a scaler that accepts VGA and outputs it as HDMI. My projector accepts VGA too.
However, if it is not going to work, I may look at one of Sony AR series laptops with HDMI out.
It does beg the question of why on earth you would include a hi-def player on a laptop that can't output HD.
post #5 of 7 Old 11-04-2007, 12:05 AM
steven975's Avatar
simple answer: more money
steven975 is offline
post #6 of 7 Old 11-04-2007, 01:30 AM
You still have the benefit of watching high resolution video on the laptop.
post #7 of 7 Old 11-04-2007, 05:15 AM
RXP
RXP's Avatar
Use AnyDVD HD to remove the HDCP protection, then you'll be able to watch over VGA.
RXP is offline
Reply Blu-ray Players
