Can I avoid controlling 2 Panasonic players with the same remote? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 11-24-2007, 10:14 PM - Thread Starter
Sebaz's Avatar
I had a Panasonic S52 DVD player and now I have a Panasonic BD30. The remote from the BD30 also controls the S52 -no surprise there- which makes the S52 turn on every time I press play on the BD30's remote, and opens the tray if I click open from the BD30's remote, and so on. Other than unplugging the S52, is there any other way I can program it and its remote to a different frequency or whatever that keeps the two machines separate?
Sebaz is offline
post #2 of 6 Old 11-24-2007, 10:24 PM
Jon Spackman's Avatar
No. sorry. The only thing you could do is setup a remote that has RF and assignable output so that dvd play is different than BD play...
Just enjoy HD in whatever form you can (Sat, Cable, D-VHS, OTA, HD DVD, or BD).
Jon Spackman is offline
post #3 of 6 Old 11-24-2007, 11:41 PM
Thunder18's Avatar
Quoted: 93 Post(s)
Liked: 55
I'm not entirely sure abou the BD30, but my BD10 has a menu option that allows you to change the remote code so that it won't affect other Panasonic devices.
Now I know for a fact that in my BR, the Panasonic HTiB and Panasonic DVD-recorder don't affect each other because the dvd-recorder had the remote code feature in the menu. You might check that out and give it a try. Panasonic does not seem to have the manual up for the 30K, otherwise I'd check for sure.
Thunder18 is online now
post #4 of 6 Old 11-25-2007, 12:34 AM
Quetzalcoatl's Avatar
Same question and he found the answer. Ask what page it is on in the manual.
http://www.avsforum.com/avs-vb/showthread.php?t=944487
The object of war is not to die for your country, but to make the other bastard die for theirs.
General George Patton
Quetzalcoatl is offline
post #5 of 6 Old 11-25-2007, 01:20 AM
podwich's Avatar
1) Press [setup]
2) Select setup, press OK
3) Selet "remote control code", press OK
4) Select code 1, 2, or 3, press OK
-Change the code on the remote-
5) While pressing OK, press and hold 1, 2, or 3 (corresponding to the previous selection) for more than 5 seconds
6) Press OK
-Found on page 26 of the BD30 manual (I had the same problem as you at first).
podwich is offline
post #6 of 6 Old 11-25-2007, 06:39 AM - Thread Starter
Sebaz's Avatar
Originally Posted by podwich View Post
1) Press [setup]
6) Press OK
Thanks. Maybe I should've looked in the manual first. Doh!
Sebaz is offline
Reply Blu-ray Players
