HD-DVD or Blu-Ray - AVS Forum | Home Theater Discussions And Reviews
Closed Thread
post #1 of 70 Old 12-22-2007, 02:29 PM - Thread Starter
sawkx81's Avatar
Hey all!
Here is the deal.
I purchased a samsung 1080p DLP TV, and i am now looking at either a Blu-Ray or HD-DVD player to go nicely with my new purchase.
I am having trouble because it seems that both have their pluses and minus'.
I was looking at the Sony BDP-S300 or the Samsung BDP1400, both on sale for 299.99, and both with 1080P24Hz output.
But i don't know about the HD-DVD players only one I saw was the Toshiba HDA-30 which was also 299.99 but seemed to only have the 1080p without the 24hz, should I be looking at anything in particular?
I have also heard that the Blu-ray player's picture is better than HD-DVD, this could be biased so i am looking for some insight, preferably before these sales run out
thanks!!
sawkx81 is offline
post #2 of 70 Old 12-22-2007, 02:43 PM
KBI
KBI's Avatar
Originally Posted by sawkx81 View Post
Hey all!
Here is the deal.
thanks!!
As long as both films are encoded the same they will look the same.. PQ/AQ. Choose which one you feel will win the format war.. Or just buy both like many have.. Check to see which format supports the majority of the films you like.. I'm going BR cause of the Horror Genre which lacks on HD DVD..
The #1 spot for gaming headphones/headsets/Mic mods/DH 5.1/links & more.
http://www.facebook.com/?ref=home#!/...494101?sk=info
KBI is offline
post #3 of 70 Old 12-22-2007, 02:48 PM - Thread Starter
sawkx81's Avatar
thanks for the response, that makes sense.
I saw alot of titles I enjoy on both sides of the fence. I heard paramount just got exclusive rights from HDDVD for something like a 100 million for 18 months, but anyways there are alot on bluray i like as well,
I am also not a big gamer, I play madden and the baseball series games on my PS2 and thats it, so should I just stick with a standalone player, and if so which BR player would e the better fit, the samsung to go with my samsung tv or the sony while it is on sale?
thank you
sawkx81 is offline
post #4 of 70 Old 12-22-2007, 02:52 PM
Gordon Shumway's Avatar
Get a cheap HD player when the next sale hits and get a PS3 for your Blu...you should be fine...whatever you do, don't get analysis paralysis.
...or you could just wait until one format "wins' and that will just mean less cabling to hook up, less shelf space to free up for two machines, and you won't have to buy two machines per room that you want to watch HDM at any given time.
Gordon Shumway is offline
post #5 of 70 Old 12-22-2007, 03:00 PM
ABCD's Avatar
My suggestion would be to make a list of the 20 movies that you cannot live without, and then from the studios you can determine whether you should buy BR or HD-DVD.
But if it is a tie, then of course buy HD-DVD because I can't think of any corporation that has done more to harm consumer's fair use rights than Sony.
ABCD is offline
post #6 of 70 Old 12-22-2007, 03:00 PM
Gmaxx's Avatar
If you want to enjoy all the movies you have to get both. I got a ps3 for blu and an HDA2 for HD DVD. The HDA2 is "only" 1080i but since my tv does a good job deinterlacing the PQ looks identical. So for you I say buy a cheap HD DVD player and a ps3. DO NOT buy the samsung. Read the thread about it if you want to know why.
Gmaxx is offline
post #7 of 70 Old 12-22-2007, 03:38 PM
ikeb's Avatar
Quoted: 16 Post(s)
i wound up buying a bd30 and an a30 because you really have to have both. Some movies are BD and some are HD-DVD (a few are both). The situation really stinks, but that's the way it is.
ikeb is offline
post #8 of 70 Old 12-22-2007, 03:48 PM
John Moschella's Avatar
And lets see... HD DVD is backed by none other than Microsoft. Lesser of two evils ...
John Moschella
John Moschella is offline
post #9 of 70 Old 12-22-2007, 04:18 PM
The_Dark_Knight's Avatar
And how have they done that exactly?
I've had no problems with Sony taking away my rights and I've been buying their products for 30 years.
The_Dark_Knight is offline
post #10 of 70 Old 12-22-2007, 05:33 PM
ditch-digger's Avatar
does your dlp even support 24..??
what model..
ditch-digger is offline
post #11 of 70 Old 12-22-2007, 05:40 PM
summerkl's Avatar
Lots of good comments here:
1 - don't get caught up in the analysis paralysis
2 - get both if you can because eventually it'll drive you nuts that you can't get access to a particular movie.
3 - on the blu-side, I wound up going for the PS3 because of all the hardware update concerns of the various machines. I love that it updates wirelessly and the recent 40gb version seems to have solved any fan noise concerns.
4 -on the HDDVD side, I went for the A2 because it was the right price. It has turned out to be very solid.
At the end of the day, I just want to watch the movies - the last 5% of audio or video resolution seemingly would cost another $1000. I think my choices which were based on a few days of reading the various forums is the practical solution for high quality enjoyment.
summerkl is offline
post #12 of 70 Old 12-22-2007, 06:37 PM
Tedd's Avatar
Quoted: 929 Post(s)
Liked: 342
What summerkl said.... Bang on! Couldn't have said it better myself.
"Analysis Paralysis" I like that
And dlp is 60 Hz refresh, right?
Tedd is offline
post #13 of 70 Old 12-22-2007, 06:37 PM
jwv651's Avatar
Buy both and ENJOY!!!!!!!!!!!!!!!!!!!!
Joe V.
jwv651 is offline
post #14 of 70 Old 12-22-2007, 07:10 PM
geko29's Avatar
Just had to quote what is quite possibly the most informative, useful first post in recent history. Kudos summerkl!
Silence is Golden. Duct Tape is Silver.
geko29 is offline
post #15 of 70 Old 12-22-2007, 07:39 PM
Walt O's Avatar
While current encodes are very similar, Blu Ray has the potential to look better in the long run. Blu Ray has been selling 70% of all discs, even after Paramount and Dreamworks went HD DVD exclusive, and rumors are circling that Warner may dump HD DVD early next year. I would say either buy Blu or wait for CES (which is only two weeks away). If you pick up a Samsung BDP 1400, you will still be within your return window when the CES announcements are made. They are $299 now and are getting good reviews.
Walt
Attorneys are like magicians; our shows are expensive and most people have no idea how we did it.
Walt O is offline
post #16 of 70 Old 12-22-2007, 07:57 PM
wallijonn's Avatar
If you apply for a Sony Style CC they'll give you a $100 credit in a month or two, bringing the price of the 40GB PS3 down to $299. It's interest free for 18 months so you could pay the minimum for the first two months and when the $100 credit comes in pay it off in full. They charge tax. Free overnight shipping.
The deal will expire 31 December 2007.
wallijonn is offline
post #17 of 70 Old 12-22-2007, 08:00 PM
wallijonn's Avatar
Don't state as fact highly contentious sales figures or appeal to rumour. (There's a separate thread for that.) He's a newbie, afterall.
post #18 of 70 Old 12-22-2007, 09:46 PM
isaidme's Avatar
Dont waste your money buying both, that doesnt make sense.
You will have wasted your money by doing so. There will only
be one format time its all said and done as it should be. Buy
the HD-DVD if you cant afford the Blu-Ray but pick a side and
go with it. I chose Blu-Ray because there is easily double the
titles I want to own.
isaidme is offline
post #19 of 70 Old 12-23-2007, 08:19 AM
YMark's Avatar
I did exactly what summerkl did. I picked up an A2 for $99 at Walmart and yesterday picked up a 40GB PS3 for $299 on Sony's card deal. The Sony Stylestore also threw in a second controller. So for $400, I have both formats covered. Not a bad deal IMO.
Mark
YMark is offline
post #20 of 70 Old 12-23-2007, 08:24 AM
Walt O's Avatar
"Don't state as fact highly contentious sales figures or appeal to rumour. (There's a separate thread for that.) He's a newbie, afterall."
He asked for an opinion. I shared my opinion based on everything I currently know, and stated that a rumour was a rumour. There is nothing contentious about published sales figures.
Walt
Walt O is offline
post #21 of 70 Old 12-23-2007, 08:31 AM
BZiggyZ's Avatar
Get both and don't look back.
BZiggyZ is offline
post #22 of 70 Old 12-23-2007, 08:32 AM
ccotenj's Avatar
Liked: 101
Originally Posted by isaidme View Post
Dont waste your money buying both, that doesnt make sense.being able to watch ALL hdm doesn't make sense?
be one format time its all said and done as it should be.maybe. maybe not. there's probably just as good a chance there will be "no" format. and the money won't be 'wasted' it's not like the "losing" players are going to suddenly destroy themselves. also, it's not like you are going to have the same player for the rest of your life. Buy
go with it."picking a side" of a ce component hardly seems to make sense to me. I chose Blu-Ray because there is easily double the
the last sentence makes sense. if you are going to buy ony one, buy the one that has the most movies available that you want. although keep in mind that as new releases come out, that ratio of "desired movies" may well change...
- chris
ccotenj is offline
post #23 of 70 Old 12-23-2007, 08:33 AM
Michael Mullis's Avatar
These threads should be banned, they really should.
There is enough actual FACT and information out there that someone could gather without having to post this question which inevitably turns into a format war.
You posted this in a Blu-ray forum sawkx81. What answer did you think you were going to get here?? Blu-ray advocates are never going to suggest HD DVD to you here.
Just like if you posted this same question in the HD DVD section you would be extremely lucky if anyone there suggested you go with Blu-ray.
Here is what you do sawkx81. Look at the current available movies. Look at the studios that support each format. Look at the players. Does a $299 player that is profile obsolete bother you? Or do you need to spend the extra $100 to be current? Are you ok with Universal, Paramount, and Warner as your movies (DO NOT LISTEN to anyone who floats a Warner rumor either way. They are wrong and don't know what they are talking about, because no one know what and when Warner will change it's mind)?
Or hey, can you afford both? Can you afford a $199 A-3 and a $399 Playstation 3? Do you have an Xbox 360 already? Do you have enough money to buy one of the dual format LG or Samsung players? Dual format gives you the ability to step back and let everyone else fight it out while you simply enjoy the movies.
Go look it up, think for yourself on this one, and don't ask for opinions in a format specific forum.
Michael Mullis is offline
post #24 of 70 Old 12-23-2007, 08:33 AM
joerod's Avatar
Quoted: 607 Post(s)
Liked: 491
Both!
My Sony 5000ES Review PART 2 FINISHED:
http://hstrial-jrodriguez996.homeste...=1462841668379
joerod is offline
post #25 of 70 Old 12-23-2007, 08:37 AM
cash70's Avatar
Find a good deal and get one of each. Always ask for "open box" items. That is how I got my BD-P1200 and A2. Then enjoy all the movies sales going around right now on both sides. That way you don't have to worry about who is releasing what movie.
cash70 is offline
post #26 of 70 Old 12-23-2007, 02:32 PM
Walt O's Avatar
What Walmarts are still selling HD players for $99? Everytime I go there they want $298.
Walt
Walt O is offline
post #27 of 70 Old 12-23-2007, 02:52 PM
oblio98's Avatar
Go for both. Think about it, in the past most of us have paid more for things like VHS HiFi machines, regular DVD players, and other stuff we've accumulated. You can get an great HD-DVD player for under $300 and a Panasonic BD player for just over $400, so for just over $700 you get both quality machines, (at least) 10 free discs (5 of each), and you are covered no matter what happens in the future.
And the best advice is to ignore all "rumors". These things always surface at an important sales juncture, and mostly are created to hurt the sales of the oppositions stuff. Both ways. They all do it. There are no "saints" - except of course the consumers who buy the stuff!
[Early Adopter]
oblio98 is offline
post #28 of 70 Old 12-23-2007, 03:22 PM
Walt
None
post #29 of 70 Old 12-23-2007, 03:48 PM
OneTruMag's Avatar
Wow! A lot of posts here w/o anyone recommending the Samsung BD-UP5000. I'm happy with the PS3 & a Toshiba A35 myself but since the OP's apparently only interested in playing HD discs and not all the other things the PS3 brings to the party, the BD-UP5000 is the way to go. Heck, he even has a Sammy TV.
PURPLE and lovin' it!!
Hi-Res Audio is worth a kidney ... or a kid
OneTruMag is offline
post #30 of 70 Old 12-23-2007, 06:34 PM
ccotenj's Avatar
Liked: 101
well, there aren't a lot of 5000's out in the wild yet, so it's probable that not a lot of people have hands on experience with them yet.
- chris
ccotenj is offline
Closed Thread Blu-ray Players
