OFFICIAL "HELP ME CHOOSE A PLAYER" THREAD: Can't decide? Start HERE - Page 427 - AVS Forum | Home Theater Discussions And Reviews
 197Likes
post #12781 of 19442 Old 01-02-2012, 01:58 PM
UNICRON-WMD's Avatar
High all, I want to buy the best video quality Blu-ray player and DVD up-converter I can afford. I want the Oppo 93 but at the moment I can't talk the old lady in a $500 BD player.
So what are my options $300 or lass?
God loves me, but everyone else thinks I'm an a$$hole.
My small dedicated theater.
UNICRON-WMD is offline
post #12782 of 19442 Old 01-02-2012, 02:21 PM
Super Moderator
teachsac's Avatar
Quoted: 650 Post(s)
Liked: 950
Panasonic X10 series is excellent at both. I have both the Oppo93 and Panasonic X10. HArd pressed to tell the difference, especially with BD playback.
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #12783 of 19442 Old 01-02-2012, 02:46 PM
S~
What do you think of the Panny BDT210?
EDIT: If I look up Panasonic X10 I get TVs, not blu-ray players.
post #12784 of 19442 Old 01-02-2012, 03:20 PM
iamian's Avatar
Quoted: 49 Post(s)
Liked: 41
X stands for 1,2, or 3.
iamian is offline
post #12785 of 19442 Old 01-02-2012, 03:27 PM
fsmithjack's Avatar
You might want to repost in the official "Help Me Choose a Player thread" as the mods will lock this one.
http://www.avsforum.com/avs-vb/showthread.php?t=959985
You can also ask questions in the two player threads.
S~
I don't understand this forum. I guess its over my head. Thanks for the heads up though...
fsmithjack is offline
post #12786 of 19442 Old 01-02-2012, 06:42 PM
champer's Avatar
Originally Posted by Ken H View Post
No, size doesn't mean a BD player is better. In some cases a smaller unit may be more expensive because it's harder to get everything into a small package. Size also has nothing to do with 3D capability.
Again, size should not matter.
Since video quality is roughly the same for all BD players that are inexpensive (under a hundred or two), features and reliability would be key. If you don't need 3D, the major difference these days would be Internet capability.
For reliability, check the individual unit topics here at AVS you are considering. Also check CNET and see if Consumers Reports does a BD player survey.
As for Internet, all the different brands have different apps they offer. You'll have to compare the offerings and see which ones you prefer. The other difference in price would be due to a built in WiFi receiver, having to buy one, or Ethernet only.
if size doesnt matter with quality how come the bigger ones cost a little more.
SONY 32XBR6
SAMSUNG 46C6500
BD 40
HD DVD 28
champer is offline
post #12787 of 19442 Old 01-02-2012, 07:10 PM
ryder_78's Avatar
Okay, after perusing countless of threads here, I've narrowed it down to the Panasonic 110 and 65.
I do know the 110 is a 3D player and 65 does not do 3D. I'm not sure if I'm going to watch a lot of 3D content on the player so I can possibly forgo the 3D features(although my Samsung display supports 3D).
My other criteria is on upconversion of DVD. Is the quality of upconversion in the 110 comparable to the 65?
Thanks in advance for the help.
ryder_78 is offline
post #12788 of 19442 Old 01-02-2012, 07:27 PM
moxie1617's Avatar
The 110 is two versions of Unipher chip past the 65 so it does a better job of DVD upconversion. The 65 isn't that bad unless you watch a lot of anime or material with mixed cadences - it will produce a lot of jaggies. As one member reported, Charlie Brown's head looked like a stair case.
moxie1617 is online now
post #12789 of 19442 Old 01-02-2012, 07:30 PM
mdavej's Avatar
Quoted: 2126 Post(s)
Liked: 940
To add a little more to what moxie said, the 65 is also obsolete. It was replaced by the 75. The 110 has a lot more features that either the 65 or 75 including better interface, more/better streaming, DLNA and network shares. I don't use the 3D features on my 110 either, but I'm glad to have all the other features, and the net cost is almost zero if you sell the Avatar 3D disc you get with it. The 65 and 75 don't come with that disc.
mdavej is online now
post #12790 of 19442 Old 01-02-2012, 07:35 PM
ryder_78's Avatar
Sorry, it's a typo. It's a 75 that I"m comparing with the 110, not a 65.
Apologies for the confusion. Okay so it's a 110 then.
Cheers.
ryder_78 is offline
post #12791 of 19442 Old 01-02-2012, 09:45 PM
ryder_78's Avatar
Just wondering, anyone compared any of these players below?
Panasonic DMP-BDT110
Sony BDP-S370
Sony BDP-S380
I am interested to know which has the best DVD upconversion quality. Thanks.
ryder_78 is offline
post #12792 of 19442 Old 01-02-2012, 10:08 PM
snidely's Avatar
Quoted: 128 Post(s)
Liked: 31
Sony BDP-S370
Sony BDP-S380
We have 2 S370 decks. Since they are now about 2 year old models (380 is the same as I recall but w. built in wifi) they might be hard to find. We only use them for BlueRay and streaming so can't answer your question.
snidely is offline
post #12793 of 19442 Old 01-02-2012, 10:22 PM
mdavej's Avatar
Liked: 940
I have the 110 and 570 (which should be the same as the 370). The upconversion is better on the 110. I wouldn't expect the 380 to be any different.
post #12794 of 19442 Old 01-02-2012, 10:28 PM
ryder_78's Avatar
That's it. No more questions. The 110 will get the nod.
Thanks for the information. Much appreciated.
ryder_78 is offline
post #12795 of 19442 Old 01-02-2012, 10:35 PM
mystic_sniper28's Avatar
up-converting dvd is a fruitless pursuit given my experience with my sony bdp-s370 doon't matter if it's region 1 or region 2/4
unless you re-author dvd's to run at 24fps or 48fps (70mm imax) up-conversion will always be crap..
wouldn't matter which bd player you brought as this will effect all brands..
mystic_sniper28 is offline
post #12796 of 19442 Old 01-03-2012, 12:58 AM
iamian's Avatar
Quoted: 49 Post(s)
Liked: 41
Funniest. Post. Ever.
iamian is offline
post #12797 of 19442 Old 01-03-2012, 06:51 AM
Gretar's Avatar
I am wondering if I should get Panasonic - DMP BDT100 or Panasonic DMP BD75EGK?
I can get them for about the same price.
It is 100 NOT 110
Gretar is offline
post #12798 of 19442 Old 01-03-2012, 07:05 AM
Theresa's Avatar
Liked: 51
My Oppo 93 does a great job upconverting. Good DVDs look very good even on a 50" screen.
Theresa is offline
post #12799 of 19442 Old 01-03-2012, 07:48 AM
iamian's Avatar
Quoted: 49 Post(s)
Liked: 41
100? If you meant 110, most definitely. 75 has very limited functionality.
iamian is offline
post #12800 of 19442 Old 01-03-2012, 11:38 AM
jgroggel's Avatar
Help. I need to mount a Blu-Ray player behind a wall. I have all my other compontents back there with the remote sensors mounted under the sound bar. I need to purchase a Blu-ray player with an I/R jack. I do not want a $200 remote to work all the components so that can't be the solution. So far the Sony NSZ-GT1 with the I/R blaster is the only one I can find.
Jeff
jgroggel is offline
post #12801 of 19442 Old 01-03-2012, 12:19 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2688 Post(s)
Liked: 1921
Jeff
Welcome to AVSForum,
The OPPO BDP-93 ($499) has IR and RS232.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is offline
post #12802 of 19442 Old 01-03-2012, 12:30 PM
HDPERSON's Avatar
Quoted: 17 Post(s)
I have tried and return or kept the Sony S780, S580, LG 670, Panasonic 210, Panasonic 110 and the Samsung D6500.
I kept the Samsung D6500 for blu ray PQ, the best I ever saw.
I kept the Panasonic 110 for 3D in my study.
I kept the Panasonic 210 for DVD up conversion, using normal setting and +2 for detail clarity. Both the Panny and Samsung offer top DVD upconversion, but the Samsung is unbeatable for Blu Ray PQ in the Dynamic mode.
The Sony S780 16 bit processing didn't show any improvement and locked on several BDs. The S580 locked when I opened the draw.
HDPERSON is offline
post #12803 of 19442 Old 01-03-2012, 01:38 PM
mdavej's Avatar
Liked: 940
Jeff
I don't understand. You already have some sort of system for your other hidden components, so why not just move one of your blasters so it hits your new player as well? Even if you don't already have something, an add-on RF system is only $40, much less than the premium you'd pay for a high end player with IR jacks and RS232.
Are you sure that jack on the sony is an input? I don't think it is.
Another option is HDMI control where you just send all commands through your TV to your player over HDMI. Works great for me and it's free.
post #12804 of 19442 Old 01-04-2012, 10:49 AM
overboy's Avatar
Guys, blz?
I wanted a hint of you to buy a BD player base, but has built a good chip (engine) that is focused on image quality and do a good job of upscaling DVDs to 1080p
He must have support for 1080p/24 so I can enjoy the 5:5 pulldown this feature on my TV through 120Hz.
I do not need 3D or interactive ... Finally, I want a product "SERIOUS" with a chip that works well with robust upscaling 480p sources and delivered good image quality in BD movies in general.
Remember, it is basic, I do not want expensive solutions, such as have not had much time to research I have come here to ask for tips, I think what I need can be found in some products in these stores common technology out there ...
Best wishes and happy 2012 to everyone.
Thanks in advance!
overboy is offline
post #12805 of 19442 Old 01-04-2012, 01:41 PM
mdavej's Avatar
Liked: 940
The best option is one of the panasonics recommended many times in this thread. Don't worry about the additional features you won't use. You can't find a quality player without all those bells and whistles anyway unless you get an older, used player.
post #12806 of 19442 Old 01-04-2012, 01:49 PM
Alex solomon's Avatar
The Panasonic does not support 1080p/24 playback on burned BD-R discs if that matters to you.
I want to hear opinions from people who don't have a dog in the fight.
Alex solomon is offline
post #12807 of 19442 Old 01-04-2012, 02:20 PM
w1ngsmk's Avatar
Originally Posted by Jacob305 View Post
+ 1
Jacob
+ 2. OPPO BD93 is one of the finest, pricey, but you won't regret it's features for quite a while.
w1ngsmk is offline
post #12808 of 19442 Old 01-04-2012, 07:34 PM
overboy's Avatar
Who does better from the options below?
Sony BDP S380
LG BD550
Philips BDP 3200
Panasonic BD75
Please explain the reason for your choice!
overboy is offline
post #12809 of 19442 Old 01-04-2012, 09:18 PM
Stew4msu's Avatar
Sony BDP S380
LG BD550
Philips BDP 3200
Panasonic BD75
Does better at what?
Stew4msu is offline
post #12810 of 19442 Old 01-05-2012, 01:26 AM
in low end models you get what you pay for, they will the same or similar functions, like hulu, net flicks and so forth..
from what i've seen with the bdp 370 I would say 280 is going to be pretty multiregion out of the box assuming the dvd or bd disc has some form of region lock imposed on it
I would also consider toshiba bd player, bd has a key code switch to select what region you wish to play. dvd end select region play can also be though there is a multi region select option, as of yet there is no multi region select tab for bd section , though how many times you can select a, b or c before it becomes a perma lock situation is also unknown....
my opinion unless you're going to brand much what you own, I douby you will get the best optimization out of your setup,,
having an a mix of vendors can cause a mix of pains..
in order
tv's
sony
pansonic
toshiba
pioneer
lg
samsung
bd players
denon
oppo
pioneer
sony
toshiba
panasonic
jvc
lg
samsung
philips
Reply Blu-ray Players
bd-30 , Blu Ray Players , blu-ray , blu-ray 3d , blu-ray dvd hardware player mp4 usb playback , blu-ray players , bluray player , control , counter , Dts , dvd player , dvd-a , flac , Lg Bd 390 Network Blu Ray Disc Player , lg blu ray , mkv , multichannel analog , Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Panasonic , philips blu ray , Pioneer Elite Bdp 62fd , Pioneer Pdp 5080 Hd , Plasma Hdtv , player , quality , S390 , sacd , samsung bd f7500 , samsung blu ray , samsung uhd , slow , smart , Sony Bdp S5100 3d Blu Ray Disc Player With Wi Fi , sony bdp-s6200 , Sony Blu Ray Disc Player Bdp S790 , subtitle sizes , Toshiba , usb , video quality , wifi , zoom
