OFFICIAL "HELP ME CHOOSE A PLAYER" THREAD: Can't decide? Start HERE - Page 561 - AVS Forum | Home Theater Discussions And Reviews
 3653Likes
post #16801 of 19722 Old 07-10-2014, 12:35 PM
Vampidemic's Avatar
Quoted: 33 Post(s)
Liked: 48
Originally Posted by kghaddon View Post
My daughter lost the remote for my Micca Player, so, I am now in the market for a BluRay\DLNA player to replace my PS3, Roku and Micca players with one box.
Important...
  • DLNA compatibility with a broad range of file types.
  • Excellent 2D Blu Ray.
  • Excellent Audio Quality (my Micca sux)
  • Intuitive Operation.
Not Important...
  • 3D
  • 4K
I would suggest you look at the Sony players such as the BDP-S5200. They have a reputation for good DLNA and overall reliability which is hard to beat in that price range. However, you should clarify your 'Audio Quality' criteria. Are you using HDMI to output your audio?
When using HDMI, audio will either be bitstreamed or decoded by the player. If all the audio channels arrive at their destination and you don't have the player applying processing (such as dynamic range controls) you should get identical 'sound quality' when comparing players. Unless you are using analog, you should not expect changing your player to impact audio quality at all. If you need analog outputs you should specify that and number of channels; most current players do not have analog outputs.
Vampidemic is offline
post #16802 of 19722 Old 07-10-2014, 06:33 PM
afrogt's Avatar
Quoted: 1438 Post(s)
Liked: 983
Originally Posted by bobby2478 View Post
I bought a Samsung BD-F5900 last year, and it had TOSLINK Optical audio output. I was looking recently at replacing another older blu-ray player and I see now that on the new Samsung BD-H5900 they replaced the TOSLINK with Coaxial digital audio. I looked at ALL of the entry level blu-ray players (regular price $99-$130) and NONE of them appear to have TOSLINK Optical audio any longer. You have to step up to the 4k upscaling ones that are in the $150-$200 range.
Has anyone else noticed this too? Considering through last year EVERYONE had TOSLINK on their entry-mid range offerings, it's pretty dumb that all the sudden they stopped including it as an option. It's not like the cost of a TOSLINK port would be much different than a Coaxial port.
Are there any $99-$130 blu ray players that still offer TOSLINK/Optical?
If you use a AV Receiver i'm pretty sure it has optical and digital coax inputs. Now you'd have a reason to use the coax inputs. the sound is the same as optical.
I don't see this as a big deal unless one has a soundbar that only take optical inputs.
Afro GT
afrogt is online now
post #16803 of 19722 Old 07-12-2014, 12:53 AM
robbynaish's Avatar
Hi guys,
the LG 740 is much more better of the 730? From details seems the same, but the cost is much much more
thanks
Ale
robbynaish is offline
post #16804 of 19722 Old 07-12-2014, 10:04 PM
eljr's Avatar
Quoted: 1193 Post(s)
Liked: 9050
blu-ray player HDMI in Analog audio out
I need a recommendation on an inexpensive Blu-ray player with HDMI input and analog RCA right left audio output to run through a two channel system.
I want to steam through a laptop.
ELJR's "listening" blog.
eljr is offline
post #16805 of 19722 Old 07-12-2014, 10:41 PM
jake9's Avatar
Quoted: 20 Post(s)
The cheapest one I'm aware of is the Oppo BDP-103 at $499. I own one and I think it's bargain for all the features it has.
jake9 is offline
post #16806 of 19722 Old 07-12-2014, 11:19 PM
lawrence99's Avatar
have you thought about just putting an internal BD drive into your laptop?
you would still need software to play blu ray movies but its also only 49 bucks .
http://www.amazon.com/Panasonic-UJ24...blu+ray+player
Eldon Tyrell:
"The light that burns twice as bright,
burns half as long. And you have burned
so very very brightly, Roy."
lawrence99 is offline
post #16807 of 19722 Old 07-13-2014, 05:07 AM
eljr's Avatar
Liked: 9050
yes, this one is pretty good (i have it in a different system)but i am looking for one cheaper if possible.
eljr is offline
post #16808 of 19722 Old 07-13-2014, 06:20 AM
Jaukh's Avatar
Need a Great PQ NAS DLNA player
In search of a new BD player. My current Samsung BD-C6500 is going south. The video display (TV) is a Samsung UNC-55C8000XF, the audio receiver is a Yamaha HTR-5140 (yup - upgrading it soon too).
We are creating a Digital Video Library of all our DVD's and BR's (1000+).
Reading back a few hundred posts I could not find a current, good answer.
So here are the requirements:
  1. DLNA via hard wired ethernet (not WiFi) NAS
  2. can read from Linux (ubuntu) DLNA server
  3. MKV, AVCHD files supported
  4. better-best audio/video quality
  5. audio 5.1, 7.1, …, separate output (coax/ToS)
  6. basic video conversion in case display (TV, projector, …) can't
  7. stackable, nothing on the top surface
the don't cares:
  1. WiFi
  2. internet streaming (this device will NOT connect to the internet)
  3. up converting
  4. extensive network file navigation (only reading one file)
and the unacceptable:
  1. anything Microsoft
The Oppo BD-P103 is a great fit but don't need all it's features or the extra $$.
Jaukh is offline
post #16809 of 19722 Old 07-13-2014, 09:40 AM
hernanu's Avatar
Quoted: 682 Post(s)
Liked: 1218
The suggestion of a bluray drive either through USB or in the laptop seems good, since you're ultimately going to display through it.
I have two oppos and an Alienware with a bluray drive, all three perform well.
hernanu is offline
post #16810 of 19722 Old 07-13-2014, 09:53 AM
BillP's Avatar
Quoted: 277 Post(s)
Liked: 223
Sorry, but I don't think you'll find a stand-alone BluRay player for less with an HDMI input.
BillP is offline
post #16811 of 19722 Old 07-13-2014, 10:08 AM
eljr's Avatar
Liked: 9050
ok thanks
how about a aVR then that has stereo analogue output ? Not too expensive.
40-60 watts
eljr is offline
post #16812 of 19722 Old 07-13-2014, 11:35 AM
mdavej's Avatar
Quoted: 2277 Post(s)
Liked: 992
Most BD players have at least optical or coax audio outputs. Adding cheap coax/optical to RCA converter will accomplish your goal without needing to buy a new AVR or expensive BD player.
Have you considered other way to display content from a laptop, like a direct cable connection, Chromecast or DLNA?
mdavej is online now
post #16813 of 19722 Old 07-14-2014, 04:57 PM
epsilon72's Avatar
Well, I'm back to this thread after I found out that the player I decided on (Panasonic BDT360) displays pop-up ads. That is *absolutely* unacceptable - what in the world is Panasonic thinking??
Anyway, here's my original post...I'm basically looking for a player that can decode DD+ and DTS HD and send it as LPCM to an older receiver that can't accept blu-ray bitstream audio formats (Denon 2307ci)
I'm having a hard time trying to find a blu-ray player that will work as well as the PS3 does with my older receiver.
I have an older Denon receiver that will accept Dolby Digital and DTS bitstream over HDMI, but not Dolby Digital TrueHD or DTS HD MA bitstream. Right now I have an older PS3 that decodes the HD DD and DTS formats and outputs them as 5.1/7.1 LPCM over HDMI, which my receiver *does* accept.
I am having a very difficult time finding a player that has onboard Dolby Digital TrueHD and DTS HD MA decoding, which can then be sent to my receiver as 5.1/7.1 LPCM multi channel. Are there any new players that support this, or do I need to look at older models? I'd prefer something below $200 but if anyone has any suggestions above that, I welcome them as well.
epsilon72 is offline
post #16814 of 19722 Old 07-14-2014, 06:41 PM
hernanu's Avatar
Quoted: 682 Post(s)
Liked: 1218
Maybe if you can find one available, an older Sony (790?).
Otherwise, at double the budget you can get an Oppo 103.
hernanu is offline
post #16815 of 19722 Old 07-16-2014, 12:56 AM
MrGlasspoole's Avatar
Liked: 0
Blu-Ray Player with 7.1 out decision
Hello from Germany,
hopefully it's ok to start my own thread for my question.
I'm looking for a Blu-Ray Player with 7.1 analog out.
I like good stuff but I'm not somebody who can spend money
like some people here who spend more on a player then others
on a car. I also don't believe into snake oil and would not
spend 100$ on a RCA cable.
What I have is this:
CD: Pioneer PD-8500
DVD: Denon DVD-2930 / Denon DVD-3910
HD-DVD: Toshiba HD-XE1
And I narrowed the Blu-Ray choice down to:
Denon DBP-2012UD
Denon DBP-2010
DVD-3800BD
OPPO BDP-83
LG BD390
Samsung BD-F7500
I don't need 3D and the cheaper the better.
If there is one BR-Player that does something better then from
what i have and i can get rid of one of the old players it's ok.
If the new player is only for BR then it's also ok.
Would be nice to see how other would rang my Players for:
CD playback
SACD playback
DVD-Audio playback
DVD-Video upscaling
I don't know the US label for the Pioneer PD-8500 but it
has Burr-Brown PCM63P-J DACs (like Accuphase DC-91).
Thanks for help.
MrGlasspoole is offline
post #16816 of 19722 Old 07-16-2014, 03:36 AM
BillP's Avatar
Quoted: 277 Post(s)
Liked: 223
Actually the mods will likely move your query to the Official Help Me Choose a Player sticky thread at the top of the page.
You list very old models, which will be very slow to load and may have problems playing new BluRay releases. Check out the Denon and Oppo websites to get information on the current models. Personally, I would stick with Oppo and Denon, but they will run you about US$500 for their entry level universal models.
BillP is offline
post #16817 of 19722 Old 07-16-2014, 07:09 AM
Liked: 0
Yes they are not the newest except the Samsung.
And even used they are not what i would call cheap.
Euro converted to dollar:
Denon DBP-2012UD 380$
Denon DBP-2010 200-250$
DVD-3800BD 340-400$
OPPO BDP-83 340-400$
LG BD390 95$
Samsung BD-F7500 180$ (new)
A new Oppo or Denon with 7.1 is to expensive for me.
post #16818 of 19722 Old 07-16-2014, 09:02 AM
hernanu's Avatar
Quoted: 682 Post(s)
Liked: 1218
DVD-3800BD 340-400$
LG BD390 95$
I have an Oppo BDP-83 which I bought four years ago. It has performed flawlessly over that time and does all that you ask for, then some (network media play from NAS, etc).
For DVD upscaling the HD-DVD player you have would come close to or match the Oppo.
So you're left with the audio (CD, SACD, DVD-A). I've used the 83 in all of those both with analog 7.1 and with HDMI. It does the job very well.
Just my observations, and it's still going strong.
hernanu is offline
post #16819 of 19722 Old 07-16-2014, 10:32 AM
fits79's Avatar
Quoted: 46 Post(s)
Hi.
Does anyone has to suggest me a CHEAP 3d bluray player without the cinavia protection?
And if i buy one 3d bluray player with no cinavia protection and install it the latest firmware then it would add the cinavia protection?
fits79 is offline
post #16820 of 19722 Old 07-16-2014, 10:43 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 3404 Post(s)
Liked: 2658
Originally Posted by fits79 View Post
Hi.
All current players have Cinavia. It is required by licensing.
Older players are available that do not have Cinavia.
Sometimes yes, sometimes no. Sony has done that, but OPPO has said their pre-103 models will not have Cinavia in new firmware.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #16821 of 19722 Old 07-16-2014, 10:48 AM
fits79's Avatar
Quoted: 46 Post(s)
I just want to know some cheap 3d BLURAY models that doesn't support cinavia
fits79 is offline
post #16822 of 19722 Old 07-16-2014, 11:00 AM
wmcclain's Avatar
Liked: 2658
State your price range, and confirm that you understand these will be used players.
-Bill
post #16823 of 19722 Old 07-16-2014, 11:00 AM
Liked: 0
So the BDP-83 upscaling is as good as the HD-XE1 and DVD-2930
and CD/SACD/DVD-A as good as the 3910?
post #16824 of 19722 Old 07-16-2014, 11:26 AM
Super Moderator
teachsac's Avatar
Quoted: 861 Post(s)
Liked: 1397
Hi.
Panasonic DMP-BDT350 does not have Cinavia and has 7.1 analog outs. You'll have to hunt for one of these.
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #16825 of 19722 Old 07-16-2014, 11:43 AM
hernanu's Avatar
Quoted: 682 Post(s)
Liked: 1218
I have a Toshiba HD-A35; I think the upscaling on the Oppo is slightly better than the A35 and to me that's saying something. So if the HD-XE1 is similar to the A35, I can tell you that for me, yes it is.
As far as the DVD-2930 vs. the BDP-83 on audio disk play, I haven't done a comparison - you'd have to search comparisons or hopefully someone chimes in who has done it. Suffice it to say that for me and in my system, it has done great with all three formats.
hernanu is offline
post #16826 of 19722 Old 07-16-2014, 11:59 AM
Liked: 0
The 3910 has better sound/DACs then the 2930.
I can't find much when it comes to Oppo vs the old Denons.
But thanks for your opinion.
post #16827 of 19722 Old 07-16-2014, 12:50 PM
hernanu's Avatar
Quoted: 682 Post(s)
Liked: 1218
Here's an old comparison of the BDP-83SE (and some mention of the stock 83) and the 3910.
The SE model was the 83 with ESS 32 SABRE DACs, so if you can find that, it may fit what you want more.
hernanu is offline
post #16828 of 19722 Old 07-16-2014, 02:29 PM
fits79's Avatar
Quoted: 46 Post(s)
-Bill
I don't mind if it was used 3d bluray player without cinavia.
I can give until 100 euros.
So what do you suggest me?
And if i do a firmware update to any old 3d bluray player is there any chance to added cinavia protection?
fits79 is offline
post #16829 of 19722 Old 07-16-2014, 02:33 PM
wmcclain's Avatar
Liked: 2658
I've already told you yes, there is a chance. It depends on the player model.
-Bill
post #16830 of 19722 Old 07-16-2014, 02:47 PM
fits79's Avatar
Quoted: 46 Post(s)
And another question is if i buy a used 3d bluray player for country it was other region that mine(region2) it can play the bluray movies of my country or not?
And what 3d bluray players do you suggest without cinavia protection?
A LOT OF THANKS FOR ALL.
fits79 is offline
Reply Blu-ray Players
1080p , bd-30 , Blu Ray Players , blu-ray , blu-ray 3d , blu-ray dvd hardware player mp4 usb playback , blu-ray players , bluray player , control , counter , Dts , dvd player , dvd-a , flac , hdmi input , Lg Bd 390 Network Blu Ray Disc Player , lg blu ray , mkv , multichannel analog , Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Panasonic , philips blu ray , Pioneer Elite Bdp 62fd , Pioneer Pdp 5080 Hd , Plasma Hdtv , player , quality , S390 , sacd , samsung bd f7500 , samsung blu ray , samsung uhd , slow , smart , Sony Bdp S5100 3d Blu Ray Disc Player With Wi Fi , sony bdp-s6200 , Sony Blu Ray Disc Player Bdp S790 , subtitle sizes , Toshiba , usb , video quality , wifi , zoom
