OFFICIAL "HELP ME CHOOSE A PLAYER" THREAD: Can't decide? Start HERE. - Page 612 - AVS Forum | Home Theater Discussions And Reviews
post #18331 of 18346 Old 08-26-2015, 03:20 PM
tvperson's Avatar
I'm looking for A bluray player can fastward with subtitles at 2x playback speeds not 1.5x speeds. I have Panasonic 220 model not have 2x fast ward with subtitles. I know some bluray player expert can answer this reply Soon?
tvperson is offline
post #18332 of 18346 Old 08-26-2015, 03:52 PM
Super Moderator
teachsac's Avatar
Quoted: 240 Post(s)
Liked: 250
Originally Posted by mdavej View Post
Panasonic will play at 1.5x speed with audio, but I've never tried it with captions. Ask in one of the Panasonic threads to confirm.
Pretty sure the last Panasonics to have that feature were the X20/500 series. I know my 230 doesn't do audio at 1.5 speed.
S~
tvperson likes this.
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself
teachsac is online now
post #18333 of 18346 Old 08-28-2015, 12:42 PM
toshiba5's Avatar
I am moving into a new home and trying to get my Home Theater going after being out of it for 12+ years. Recently picked up a Samsung JS8500 for primarily sports and movies, so I wanted to see what would be a good blu-ray player to go with the TV. I have an old Kenwood Sovereign Receiver with a 7.1 Definitive Technology setup, but that received was pre HDMI so I am not sure how compatible it is going to be with everything now a days anyways. Would like to keep it under $250, but if I going to be missing out on a key feature I can adjust a little. Thanks for the help!
Peter L.
toshiba5 is online now
post #18334 of 18346 Old 08-28-2015, 03:01 PM
mdavej's Avatar
Quoted: 1401 Post(s)
Liked: 699
First thing you need to decide is if you really need lossless 7.1, in which case you'll need an old player to go with that old receiver ($400 range, slow, less compatible), or if you can live with lossy 5.1 (better than DVD quality audio), in which case many newer, less expensive players ($100 range) will work fine.
mdavej is offline
post #18335 of 18346 Old 08-28-2015, 03:14 PM
toshiba5's Avatar
I am ok with the 5.1, because the room it is going into I am not sure if I would be able to have all the speakers anyways! Hopefully someday I will update the Kenwood receiver. Do you have a specific player you would recommend? Thanks Again!
Peter L.
post #18336 of 18346 Old 08-28-2015, 04:41 PM
Rich86's Avatar
Quoted: 93 Post(s)
Liked: 45
There are very good used blu-ray players out there with 7.1 analog audio outputs that can be had inexpensively (I would advocate Panasonic & Sony models). However, using analog audio connections can be an issue for the lfe channel analog audio as all players output analog lfe audio about 10db depressed. Does your Kenwood receiver permit adjusting the analog audio lfe channel input upward by up to 10db? If yes, a Panasonic DMP-BD55 or DMP-BD85 might serve your purpose. The Sony BDP-S550 or BDP-S1000ES are also good choices. These are not 3D models and only the Panasonic DMP-BD85 is capable of streaming video programming off the internet, if either of those features matter to you in a blu-ray player. All the models listed are free of cinavia processing, in case that matters to you.
A long-time audio/video addict!
Rich86 is online now
post #18337 of 18346 Old 08-29-2015, 08:27 AM
toshiba5's Avatar
I did not get the Kenwood Receiver from my brother's house yet, but I am pretty sure that it did have and adjustments for the lfe channel.
Also, I just found a Panasonic DMP-BD30 that he was not using, is/was that a pretty decent Blu-Ray player? Or worth upgrading some something different.
Peter L.
post #18338 of 18346 Old 08-29-2015, 12:16 PM
mdavej's Avatar
Liked: 699
That's pretty much exactly what you need, and an excellent player. Anything much newer than that won't have analog outs and probably won't decode all formats to 5.1. Newer players initially load discs faster and have newer/better/faster streaming apps, which you probably don't care about anyway.
So keep the Panny until you upgrade your AVR, then buy a new, cheap player to go with it at that time.
mdavej is offline
post #18339 of 18346 Old 08-29-2015, 12:29 PM
toshiba5's Avatar
Thanks!!
Peter L.
post #18340 of 18346 Unread Yesterday, 04:03 PM
thxbest's Avatar
Quoted: 59 Post(s)
Cheapest Blu ray player with 7.1 analog multichannel ouput
I am looking for a used Blu ray player with 7.1 analog multichannel output to connect to AVR 7.1 analog input to get the new surround formats (Dolby True HD - DTS-HD Master etc.)
I need a list of players that could do this job, looking for a good used one in the second hand market.
Thanks for advise.
thxbest is online now
post #18341 of 18346 Unread Today, 05:01 PM
Rich86's Avatar
Quoted: 93 Post(s)
Liked: 45
Thanks for advise.
Here are a few suggestions:
Panasonic dmp-bd55 & Panasonic dmp-bd85
Sony bdp-s550, Sony bdp-s1000es
and the best option by far . . Sony bdp-s5000es (but pricey even used . .)
Oppo players also have analog outputs, but finding one priced decently might be difficult.
Your best shot for availability and a decent price is probably a Sony S550.
Be sure your AVR 7.1 unit can INCREASE the analog LFE input channel by up to 10db, as that signal is depressed by about that much by all blu-ray player analog outputs.
post #18342 of 18346 Unread Today, 05:31 PM
thxbest's Avatar
Quoted: 59 Post(s)
Thank you for the post.
Which one can handle DVD-A and SACD?
post #18343 of 18346 Unread Today, 06:21 PM
Super Moderator
teachsac's Avatar
Quoted: 240 Post(s)
Liked: 250
None of them. Sony will do SACD. You'll need an Oppo or other universal player for that. you might scroll through the classifieds for a look.
post #18344 of 18346 Unread Today, 06:35 PM
thxbest's Avatar
Quoted: 59 Post(s)
Sony will do SACD
Which one?
post #18345 of 18346 Unread Today, 08:16 PM
Super Moderator
teachsac's Avatar
Quoted: 240 Post(s)
Liked: 250
Any Sony will do SACD.
post #18346 of 18346 Unread Today, 09:00 PM
gentlejax's Avatar
Quoted: 18 Post(s)
BEST SMART DVD player with analog outs?
since changing all my equipment out I cant use the HDMI outputs of my Panny 330 so I am putting that one elsewhere and I Am looking for the best dvd /blue ray player with netflix and built in wireless. was looking at the older sony 590
gentlejax is online now
Reply Blu-ray Players
Blu Ray Players , blu-ray , blu-ray 3d , blu-ray dvd hardware player mp4 usb playback , blu-ray players , bluray player , control , dvd player , Lg Bd 390 Network Blu Ray Disc Player , lg blu ray , mkv , Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 93 Blu Ray Player , philips blu ray , Pioneer Elite Bdp 62fd , Pioneer Pdp 5080 Hd , Plasma Hdtv , player , quality , S390 , samsung bd f7500 , samsung blu ray , samsung uhd , Sony Bdp S5100 3d Blu Ray Disc Player With Wi Fi , sony bdp-s6200 , Sony Blu Ray Disc Player Bdp S790 , subtitle sizes , Toshiba , video quality
Gear in this thread - S790 by PriceGrabber.com
