OFFICIAL "HELP ME CHOOSE A PLAYER" THREAD: Can't decide? Start HERE - Page 643 - AVS Forum | Home Theater Discussions And Reviews
 178Likes
post #19261 of 19276 Old 09-07-2016, 08:31 AM
Selden Ball's Avatar
Quoted: 2506 Post(s)
Liked: 1200
Originally Posted by martynic View Post
I currently have a Samsung BD-5500 BD player and has served me OK over the years. Lately however...it takes a long time to load up certain BD's. Also, I'm not sure how well it will pass Atmos programming in bit stream mode.
Since I will be setting up my system for Atmos in the near future I am looking at possibly replacing the BD-5500. Keeping in mind that I do not crave great video quality, but do like good audio (since I watch a lot of concert discs), is there a decent player (low or mid tier) that will put out better audio than the older BD5500 and not take too long to load a disc?
Basically I am looking for a relatively inexpensive player that will do a good job with the newer audio formats, load up relatively fast, and do just an adequate job with video.
Is there such a player?
Originally Posted by hernanu View Post
All you need to support Atmos from a player perspective is to be able to bitstream. So any player that bitstreams should be able to handle it.
It won't necessarily improve on the player you already have, but it will give you better loading, maybe other features that you find valuable.
It's a pretty low bar, since I think they all should bitstream, the critical part is the receiver and what it does with the sound. So I think any current low priced player that won't fall apart immediately will do.
Good luck.
Unfortunately, many Atmos discs overuse the feature "Seamless Branching". The chipsets in some older players can't cope with that and generate random audio dropouts. I dunno if the Samsung BD5500 is one which has that problem. It's old enough that it might. However, all current generation Blu-ray players don't have that problem.
When bitstreaming over HDMI, you get a bit-perfect audio stream: what's on the disc is what goes into your audio equipment. So far as that's concerned, it doesn't matter which Blu-ray player you get. They'll all bitstream Atmos perfectly. (Note that I am not including Blu-ray gaming consoles: some can and some can't.) It's the other features of the player that would affect your decision: being able to play 3D, SACD, DVD-A or UHD discs will each add to the player's cost. If you don't need any of those formats, you can get the cheapest player available, typically under $50.
HDMI does have a tiny amount of jitter which some people claim they can hear. Whether that might be a problem for you is another thing that I dunno. Personally, I think that being able to listen to lossless audio with Atmos is far more important.
Selden
Selden Ball is online now
post #19262 of 19276 Old 09-07-2016, 03:21 PM
TomC1315's Avatar
Quoted: 128 Post(s)
Liked: 141
Should I bother upgrading my LG BD630?
My Marantz UD5007 is no longer recognizing discs (unknown disc or no disk reading) ... Marantz customer service suggested a disc cleaner (that didn't help) or having it serviced/repaired.
Firmware is up to date.
I've never been happy with the handshake between my UD5007 and SR5007 receiver ... it was never a surprise when I needed to power off one or both to get things going ... as a result of that, I'm no longer committed to the uniform Marantz look.
My first inclination was to see what Oppo has to offer ... the 103 looks great.
Audio is my primary concern as far as the HT is concerned, Blu-ray player included.
But ... as I'm reading up on Blu-ray/audio quality, I'm not sure where my upgrade $$$ should go.
I'm under the impression that analog connections and Audysssey room correction aren't compatible ... I'd much rather have an HDMI connection anyway.
Since the decoding is done in the AVR when using the HDMI connection, as far as audio is concerned, are all Blu-ray players (like the LG BD630 that I grabbed from the exercise room) basically the same?
Interestingly, the Oppo owner's thread, on the first page, seems to indicate that for DTS MasterAudio, the Oppo 103 can internally decode the material via analog or HDMI connection.
The two sources I'm concerned about with regards to the audio quality are (1) my classical music/opera DVDs and Blurays and (2) Hi-res digital audio from an iPad.
Finally, am I correct in assuming that the Oppo 103 has better internals and processing capability than my SR5007 receiver?
MartinLogan Motion 40s / 30 / LX16s
Marantz SR5007 / UD5007
Emotiva XPA-3
SVS SB13ultra
exercise room: MartinLogan LX16s / Dynamo700
TomC1315 is offline
post #19263 of 19276 Old 09-08-2016, 06:50 AM
Liked: 1200
You're right in that multichannel analog audio can't be processed. However, stereo can. I.e. D+M don't provide A-to-D converters on the multichannel inputs, but they do have a pair for the stereo inputs.
Nominally, yes: when bitstreaming, the same audio bits are sent from player to the receiver (or pre/pro). Some vendors claim to have lower jitter levels, though.
Most modern disc players can do that. Unfortunately, due to penny-pinching, many current generation players (including most of those from Sony and Panasonic) are limited to stereo decoders and don't provide multichannel decoders. Sony's top-of-the-line UHP-H1 BD player does have multichannel decoders. (Despite the name, it is not a 4K UHD player.)
I dunno without doing some research. Its D/A circuitry is supposed to be quite good, but the 105's is better. That's irrelevant if you're going to be using Audyssey, though. That requires analog audio to be redigitized in the receiver, so you might as well bitstream over HDMI.
TomC1315 likes this.
Selden
post #19264 of 19276 Old 09-09-2016, 05:56 PM
sd-hd's Avatar
Panasonic BD35 needs replacing
My Panasonic BD35 is nearly 8 years old. It has stopped playing most blurays, and those it does it freezes up after about 30 minutes. I am ready to get a new player. it is hooked up via HDMI to a pioneer Kuro 60" plasma screen, using only the attached factory speakers. so I don't need fancy sound capabilities. And i have a network jack by the TV, so I don't need wireless, though I assume most current players include that. It would be nice to have a player that can do apps for youtube or hulu, but my main requirement is a good HDMI output for a 60"plasma. Do I go with a modern panasonic such as the BD93 (I don't need 3D), or is something else better at this point? When I bought this 8 years ago, it seemed like this model or an Oppo were the best, but I haven't stayed up to date on things.
sd-hd is offline
post #19265 of 19276 Old 09-10-2016, 11:52 AM
Whitearrow's Avatar
Quoted: 54 Post(s)
Liked: 68
Help me AVS, you're my only hope!
I've just spent a frustrating hour going through players on Amazon and reading reviews, and I can't believe how hard this is.
I'm looking for a new bluray player for my living room. My old one is an LG that's being booted to a den.
My requirements are super simple:
-- Blurays look great in 1080p. I don't need 3D or 4K.
-- It loads blurays fast (30 seconds or less from closing the tray to starting the disc).
-- It is fully backward compatible with DVDs. I have a lot of DVDs, including many TV series, that won't ever be available on bluray. (Some of the reviews said dual layer DVDs can be a problem for some newer players?)
That's it. I don't even need wifi or apps (love my Roku), though I know it will probably be part of the deal. I just want a great disc player.
My budget is $150 or less.
Thanks for any suggestions!
valkenaar likes this.
Whitearrow is offline
post #19266 of 19276 Old 09-13-2016, 07:44 AM
Liked: 1200
It seems that you both have essentially the same requirements. Unfortunately, in the sub-$300 category, all of the manufacturers are cutting as many corners as they can, so if you get a new player, it's unlikely, but don't be surprised if you have to return it for mechanical problems. Here on AVS Sony and Panasonic players tend to have the best reputations. Sony players tend to have better streaming apps than what Panasonic players provide. Panasonic used to have more video scaling options than Sony when upscaling DVDs, but supposedly they've dropped some of those features. In either case, you should consider getting their second-from-lowest models. They typically sell for about $50 or so.
Whitearrow likes this.
Selden
post #19267 of 19276 Old 09-16-2016, 05:36 PM
Jben04's Avatar
Quoted: 46 Post(s)
So, i think my current Panasonic 3D Bd player (220) is close to its last legs... every so often ill loose the HDMI signal while playing a film,, very annoying...
So just looking for a few good different options (anything to keep clear of.) ..... just to replace what i already have ,and would prefer to stick with either Panasonic or Sony. Kinda need to have it 3D,,and have seen a few with 4k Upscaling .
As you can see from my sig,,i have it hooked up to the Denon X2100W AVR,, energy take classic 5.0 and a SVS PB1000
So far ive narrowed it down to either the Sony BDP 6500 or the Panasonic BDT270.
Just a add on,, a friend recommended me the Samsung UBD- K8500
LG 47LW5600 (3D) - Energy take classic 5.0 - SVS PB-1000 - Panasonic BDT220 (3D) - Sony BD S350 - Insignia NS BRDVD4 (Region Free) -
Denon AVR X2100W - Harmony One Remote.
Jben04 is offline
post #19268 of 19276 Old 09-18-2016, 07:47 AM
hernanu's Avatar
Quoted: 517 Post(s)
Liked: 928
Your TV is a 1080p display - the Samsung is a UHD (4K...) player, you'd be paying more for tech you can't use. So I'd stick to the other two models unless you're upgrading your display and maybe your receiver.
hernanu is offline
post #19269 of 19276 Old 09-18-2016, 10:00 AM
doubleroll's Avatar
I just picked up a Sony BDP-S6700 to replace an old S570 and seems to be fine. Streaming, 3D, 4K upscale, etc.
doubleroll is online now
post #19270 of 19276 Old 09-18-2016, 10:20 AM
Jben04's Avatar
Quoted: 46 Post(s)
Yup i was trying to plan on future proofing,, but the misses didn't like the idea of the Samsung either lol. ( she said and i quote " If you do get a new 4k Tv then just get a 4K blu ray player then " )..sounds fair to me !
Jben04 is offline
post #19271 of 19276 Old 09-18-2016, 01:24 PM
hernanu's Avatar
Quoted: 517 Post(s)
Liked: 928
Sounds positive to me, I'd say you just got pre-approved for a 4K upgrade.
I'd wait for a 4K player - you'll get a second wave of improved players in a few months, including the new Oppos. Getting a good 1080p player without spending a ton is a good strategy for now for your 1080p system.
hernanu is offline
post #19272 of 19276 Old 09-22-2016, 07:34 AM
IRollman's Avatar
Slot Load or Vertical Player
does anyone make a slot-load or similar Blu-Ray/ DVD player? I want to mount it vertically, not set it on a shelf. Application is in an RV, where horizontal shelf space does not exist.
Slot load, or something that grabs the spindle, like a DVD tray in a computer, would work.
IRollman is online now
post #19273 of 19276 Old 09-22-2016, 07:43 AM
Super Moderator
teachsac's Avatar
Quoted: 534 Post(s)
Liked: 619
Please refer to this post.
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Samsung UBD-K8500 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is online now
post #19274 of 19276 Old 09-22-2016, 09:44 AM
IRollman's Avatar
and....
Originally Posted by S_G7 View Post
Toshiba BDX5500 (includes vertical stand)
Toshiba BDX6400 (includes vertical stand, but hard to find and BDX5500 has a better rep)
Panasonic DMP-BBT01 (includes stand for vertical orientation, but very hard to find new or even used at this point)
PS3 Slim
PS3 Super Slim
PS4
Xbox One S (the new 4k version about to be released, not the older version which officially supports only horizontal placement)
All of the above have slot loaders with the exception of the PS3 super slim.
Moderator: Thanks for the redirect.
The Toshiba BDX5500 seems to be the only one available new, and it's $300. One would think that it wouldn't be that hard to find one - I can't be the only one in the world that needs or wants to mount it vertically. And no, I'm not buying a PS3/4 JUST for the video out. That's just plain stupid. And I'm not a gamer.
post #19275 of 19276 Old Yesterday, 07:21 PM
billj66's Avatar
Liked: 0
Why not? You can get one refurbed (PS3) for as cheap as $110 dollars, and they are very good Blu-ray players.
billj66 is offline
post #19276 of 19276 Old Today, 08:52 AM
IRollman's Avatar
Originally Posted by billj66 View Post
Why not? ...
1. A matter of principle. Yeah, I know, dumb, but there you have it.
2. I don't want to have a game controller as a remote. Too bulky and an unfamiliar interface for most.
3. I don't want a game console in the RV. I'd rather not have family glued to a console, I'd rather have them out and about. And no, the TV won't be on while driving, it's buried behind a slide.
Reply Blu-ray Players
bd-30 , Blu Ray Players , blu-ray , blu-ray 3d , blu-ray dvd hardware player mp4 usb playback , blu-ray players , bluray player , control , counter , Dts , dvd player , flac , Lg Bd 390 Network Blu Ray Disc Player , lg blu ray , mkv , multichannel analog , Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Panasonic , philips blu ray , Pioneer Elite Bdp 62fd , Pioneer Pdp 5080 Hd , Plasma Hdtv , player , quality , S390 , samsung bd f7500 , samsung blu ray , samsung uhd , slow , smart , Sony Bdp S5100 3d Blu Ray Disc Player With Wi Fi , sony bdp-s6200 , Sony Blu Ray Disc Player Bdp S790 , subtitle sizes , Toshiba , usb , video quality , wifi , zoom
