Blu-Ray Player Good at Upconverting SD - AVS Forum | Home Theater Discussions And Reviews
Old 12-28-2007, 07:53 AM - Thread Starter
jet757f's Avatar
Im looking for a good all around Blu-Ray player such as the Sony BDP-S300 or the Panasonic BD30 that is good at upconverting Standard DVDs and also has excellent picture quality. I am open to suggestions. I want to compare to a Toshiba 35 that I have 30 days to return so want to get the best comparision. The Toshiba has been just "ok" to me. Im using this on a Sony KD-36XS955 HD screen.
jet757f is offline
Old 12-28-2007, 08:18 AM
Moderator
Moderator
PooperScooper's Avatar
Quoted: 286 Post(s)
Liked: 4058
They'll look the same as the A35. Your TV is your "weak link" as people tried to explain in the HD-DVD player forum.
larry
And the pantaloon duck, white gooseneck quacked: Webcor, Webcor
PooperScooper is offline
Old 12-28-2007, 08:39 AM - Thread Starter
jet757f's Avatar
larry
Ok that is fine but I would like to satisfy my own curiosity and the only way to do that is also get a Blu-Ray Player as a comparision.
Im just asking which one is rated best for upconverting
standard DVDs and also excellent picture quality on BR DVD playback.
One may look better than the other on my screen.
Otherwise I may just go back to the OPPO 981 which did a great job.
jet757f is offline
Old 12-28-2007, 12:38 PM
rboster's Avatar
Quoted: 900 Post(s)
Liked: 750
If you run a search using upconverting or upconvert or upconversion or "best" as a single search work...title search only for this forum you'll find the other threads that have asked that same common question.
Retired Moderator
FS: APC J10 Home Theater Conditioner/UPS back up $100: http://www.avsforum.com/forum/211-ac...y-back-up.html
rboster is online now
Old 12-28-2007, 12:53 PM
joerod's Avatar
Quoted: 607 Post(s)
Liked: 491
I'd get the Panny 30K and call it a day.
My Sony 5000ES Review PART 2 FINISHED:
http://hstrial-jrodriguez996.homeste...=1462841668379
joerod is online now
Old 12-29-2007, 12:48 PM - Thread Starter
jet757f's Avatar
I ended up getting the PS3 and its looking very good to me. I have been testing Blu-Ray and SD dvds and so far Im impressed. Im going to hookup the Toshiba A30 again and see if there is a big difference.
jet757f is offline
Old 12-30-2007, 09:08 AM
suffolk112000's Avatar
Hmmmm... I was thinking you said you had an a 35 in your first post.
Domino's donÂt fall all at once, they fall one at a time...
suffolk112000 is offline
Old 12-30-2007, 09:54 PM - Thread Starter
jet757f's Avatar
Sorry you are right. I had the Tosiba HD-A30 that I was comparing. I ended up returning it today. If froze on me last night which is not a good sign.
I am now using the PS3 which so far has been flawless.
jet757f is offline
Old 12-30-2007, 09:57 PM
pdqgp's Avatar
Some will disagree, but I bought the inexpensive Samsung P1400 and am running the latest firmware v1.2 and love it.
It's a bit slow to respond to opening and loading, but other than that, we've had zero issues with it.
It does up convert SD DVD's very, very well. Not Blueray quality, but it sure makes watching old DVD movies a whole new experience on a nice Panny Plasma
Enjoying every Pixel in Life
pdqgp is offline
Old 12-30-2007, 10:05 PM
fpconvert's Avatar
Same result here. Only no firmware update/no issues.
fpconvert is offline
