Is there a better option than the PS3? - Page 8 - AVS Forum | Home Theater Discussions And Reviews
post #211 of 213 Old 01-17-2008, 08:43 PM
jus711's Avatar
There is a difference, a true digital coaxial cable is thicker, has better shielding, and is set to at least a 75 ohm impedance, all due to its function of carrying a digital signal.
Standard analog rca cables don't necessarily have to have these qualities. However, in most applications they'll do the job.
jus711 is offline
post #212 of 213 Old 01-17-2008, 09:05 PM
jmpage2's Avatar
Quoted: 12 Post(s)
Liked: 80
I've done some research and you are correct, while a twisted pair coaxial cable will work for digital, what is recommended is a solid copper core cable with 75 ohm resistance, similar to a subwoofer cable.
For those not adverse to doing things on a budget, a good RG6 cable with some F-RCA ends would probably do a fine job.
jmpage2 is offline
post #213 of 213 Old 01-18-2008, 06:20 AM - Thread Starter
Jim01's Avatar
Thanks for the help but it turns out it's a moot point. I checked my receiver and it actually has 3 optical inputs, so I am all set
Jim01 is offline
Reply Blu-ray Players
