Pioneer Elite BDP-05FD & BDP-51FD merged threads - Page 79 - AVS Forum | Home Theater Discussions And Reviews
Old 06-22-2008, 10:49 PM
NemoZorro's Avatar
BTW, we should be happy that a Pio rep reports on this forum instead of ignoring it completely like most CE company reps do.
Chris releases information when he can and when he has time. He has a few more things to do than just answer our sometimes redundant questions!
Some of our questions may not be answered until someone actually gets a working production model - remember these players won't be released for another month or so.
NemoZorro is offline
Old 06-23-2008, 12:17 AM
Ruined's Avatar
Quoted: 263 Post(s)
Liked: 82
Originally Posted by cpcat View Post
You aren't "regenerating" anything by upsampling as the information isn't present in the first place. BD has 8-bit color for the forseeable future. "regenerating" by upsampling to 12 bits would be akin to saying it's possible to create HD from SD by upconversion which obviously doesn't work either.
If the banding happens to be an artifact coming off the disc or a problem inherent at the display you'll likely still see it. If you were to find a way to somehow "mask" it then you'd probably compromise somewhere else i.e. resolution.
Sure you could "regenerate", or better word "re-render" it. If the video processor is powerful enough it could sample the banded area and re-render it with a more natural gradient. Of course, it could also be a simple filtering trick by a low powered video processor. We won't know until its out.
Re: DVD upconversion, look at the difference between a DVD upconverted with Reon to 1080p vs. a DVD upconverted to 1080p with a poor upconversion circuit. Massive difference, and the same will apply here. Color upconversion is possible, but it will require a relatively powerful video processing solution to do well; yes, it won't be as good as true 12-bit but that is not possible with BD anyway. As for compromising resolution, remember that in most cases banding is not detail but rather an artifact; therefore it is not something we should look to preserve, and in highly stylized movies that have banding on purpose like Tron you can simply disable the circuit.
Ruined is offline
Centurion's Avatar
I've got 3 Pioneer Elite products.
Took each one of them apart, piece by piece and searched every component, but to no avail. I just could not find any gumbily goop anywhere.
Now, how am I going to put all these parts back together...hmmm...
Centurion is offline
Old 06-23-2008, 01:34 AM
b_scott's Avatar
Quoted: 37 Post(s)
hahahaha
b_scott is offline
Old 06-23-2008, 04:03 AM
DCIFRTHS's Avatar
Any info on the analog audio output processing options yet Chris?
DCIFRTHS is offline
Old 06-23-2008, 09:08 AM
DavidHir's Avatar
Quoted: 1702 Post(s)
Liked: 1320
Originally Posted by Pres2play View Post
Are you saying there's nothing new going from 8 bits to 12 bits? What other players do this?
I know for a fact my Panasonic BD30 is outputting 12 bit video; I'm fairly certain the PS3 does, as well.
The Pioneer is said to be the first unit to somehow utilize or upsample to Deep Color which is a separate process from going 8 to 12 bits.
DavidHir is online now
Old 06-23-2008, 09:24 AM
bferr1's Avatar
Quoted: 87 Post(s)
Liked: 92
Yes, both the BD30 and PS3 output 12-bit video, as reported by my Denon 3808 receiver. How their 12-bit differs from Pioneer's 12-bit is a mystery to me.
bferr1 is offline
Old 06-23-2008, 09:48 AM
b_scott's Avatar
Quoted: 37 Post(s)
possibly they may say they are outputting 12bit, and they COULD, if the source was 12bit (which it isn't). and then the Pio would be upscaling to 12bit, which would give it a better PQ.
b_scott is offline
Old 06-23-2008, 10:06 AM
ashmostro's Avatar
outputting in 12 bit mode doesn't necessarily mean there are twelve unique bits of color information. the data is probably not upsampled.
ashmostro is offline
Old 06-23-2008, 10:19 AM
bferr1's Avatar
Quoted: 87 Post(s)
Liked: 92
Let me rephrase then: what the differences in 12-bit video between the Pioneer, the Panny and PS3 translates into in the real world is beyond me. By the way, does anyone know if my Mitsubishi WD-65833 is a 12-bit television?
bferr1 is offline
Old 06-23-2008, 10:25 AM
Ruined's Avatar
Quoted: 263 Post(s)
Liked: 82
Based on what we have heard from initial demonstrations of the technology, the Pioneer offers an option that actually attempts to improve picture quality by reducing banding through the use of the deep color feature. Instead of simply outputting in 12bit like the PS3 & Panasonics do, Pioneer's technology attempts to work on the picture and make banded gradients appear to have smoother transitions. The feature of course can be disabled, and we don't know how effective it is - but it may offer a solution to reduce or eliminate banding on select titles with banding artifacts. Its not as good as true 12bit color encoded on the disc, but Blu-ray is limited to 8bit encoding.
To draw a parallel between DVD upscaling & color upscaling, the PS3/Panasonic do the bare minimum to upscale 8bit > 12bit; think of these as more "basic" color upscalers. On the other hand, the Pioneer offers the option to do significantly more post processing in order to improve the image and eliminate or reduce banding; think of the Pioneer as a more "advanced" color upscaler. Again, we won't know how effective it is until we see it on real world material with a production model. On test patterns, though, it did wonders with reducing banding according to insiders.
Also, your particular TV does support the 12bit feature.
Ruined is offline
Old 06-23-2008, 10:27 AM
b_scott's Avatar
Quoted: 37 Post(s)
anyone know why BD is limited to 8-bit? you'd think all this hurrah about HD formats wouldn't immediately cripple it right out of the gate for the next 10 years.
b_scott is offline
Old 06-23-2008, 10:29 AM
Ruined's Avatar
Quoted: 263 Post(s)
Liked: 82
It boils down to compatibility. When BD was released HDMI 1.3 was not yet available and most TVs did not support 12bit per color; and, in order to take advantage of it you'd therefore need two completely seperate video encodes on every Blu-ray disc, an 8bit one for older TVs/players and a 12bit one for newer TVs, players. It would add confusion and compatibility headaches for less knowledgable consumers. And for the record, HD DVD had the same problem. Both are limited to 8bit per channel, meaning banding artifacts can be introduced when downconverting a master with 10bit/12bit per channel if dithering is not used. Warner seems to be most guilty of using less advanced master downconversion methods which sometimes introduce banding artifacts in some of their Blu-ray discs.
So, our best bet is for companies like Pioneer to come up with color upconversion techniques that can reduce/eliminate banding without losing other important picture detail by sampling and re-rendering the banded gradients in each frame. This is most definitely possible, but it would require a relatively powerful video processor. We'll see if Pioneer got off to a good start with their implementation when this player is released with its optional color upconversion feature.
Ruined is offline
Old 06-23-2008, 10:34 AM
EWL5's Avatar
Any chance you guys could be talking about the color depth that is available on the newer high def camcorders? I think Sony's moniker is x.v. Color. That's the only way I know of to take advantage of the capability in the player and the TV (home movies). But you have to burn it to a Blu-ray structured disc first or watch it straight from the camcorder.
Pioneer broke my heart.
Denon broke my wallet.
Oppo broke my thinking.
EWL5 is offline
Old 06-23-2008, 10:47 AM
SubArctic's Avatar
Folks,
I've been following this thread for a while, but just recently started paying closer attention; I've just gotten a new TV and I'm turning my research focus to a blu-ray player, with a target purchase date of November or December.
I'm leaning towards purchasing one of these new Pio players (or perhaps waiting for the 2.0, depending on what other upgrades it has and the cost), and I have a few questions that I don't recall being asked or answered. Any help--including speculation or a "we don't know yet"--would be appreciated
1. I understand that the PQLS (sp?) anti-jitter feature is available only when used in combination with Pio Elite AVRs. But is this a proprietary technology? Or is it some sort of open source or industry standard we might see in other AVRs in the future?
2. The deep color feature intrigues me, but I won't be sold until people can actually play around with it--and preferably not until I can see it myself. But am I right in my understanding that there is no type of disc now conceived of (and therefore that will ever be read by these players) that actually has encoded deep color? In other words, am I correct that this feature is PURELY for up-conversion (or however you want to describe it) and not a future-proofing feature for discs that will eventually be mastered in deep color?
3. My new set is a non-elite Pio (5020). I don't regret not going Elite; the cost-benefit just wasn't there for me. But, I'm curious--will any of Pioneer's upcoming blu-ray players have any sort of picture, color, or color-space adjustments that would allow me to "compensate" for the lack of features/adjustments on my 5020?
Thanks for your time folks; sorry if any of these have indeed been asked and answered in the past or if they're ridiculous questions. I'm somewhat exhausted from my TV research, and it's a bit daunting to begin anew on another quest.
SubArctic is offline
Old 06-23-2008, 10:48 AM
shamus's Avatar
Quoted: 23 Post(s)
They could of mastered disc's at 12-bit and than made players downconvert it to 8-bit, kinda like 1080p/24, but they didn't.
Maybe they tested it and it didn't show much of an improvement?
Or maybe they didn't have time to implement it before going to war with the axis of evil HDDVD.
shamus is offline
Old 06-23-2008, 10:51 AM
bferr1's Avatar
Quoted: 87 Post(s)
Liked: 92
Thank you! I have been toying with the idea of canceling my preorder on the Pioneer 51 because I have too many questions like the ones I asked. Answers like yours really make the decision to keep the preorder in place a lot easier.
bferr1 is offline
Old 06-23-2008, 10:53 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2257 Post(s)
Liked: 2823
Or maybe they didn't want a 50% increase in movie file size on disc and bit rate for reading that off the disc when people couldn't see the difference.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is offline
b_scott's Avatar
Quoted: 37 Post(s)
well, they have 50GB to work with, i think they'd be ok.
b_scott is offline
Old 06-23-2008, 10:59 AM
EWL5's Avatar
Processing power may be more of an issue than storage size. I think most BD players (except possibly the PS3) would choke on 40Mbps video compared to 25Mbps.
EWL5 is offline
Old 06-23-2008, 12:05 PM
Ruined's Avatar
Quoted: 263 Post(s)
Liked: 82
To do a quality downconversion from 12bit to 8bit without visible artifacting in realtime no less would add significant cost to Blu-ray players. Being that they are expensive enough as it is and the impractical nature of dual 8bit/12bit encodes on each disc, they probably just settled on 8bit as the more practical standard.
Originally Posted by SubArctic View Post
Folks,
Unknown, but the Pioneer spokesperson here implied it was proprietary technology despite PQLS being based on an open feature of HDMI. We won't the answer to this for sure for a while most likely since Pioneer is the only company that has receivers out utilizing this feature of HDMI.
Correct, its purely color upconversion. You can't have a disc mastered in deep color since that would not comply with Blu-ray specifications.
Based on the screenshots there appears to be some options, unknown how many.
Ruined is offline
Old 06-23-2008, 12:16 PM
fxdm70's Avatar
I placed my pre order today with Jeff Haag... Very excited....
fxdm70 is offline
Old 06-23-2008, 12:32 PM
JoeInNVa's Avatar
It's because Blu-Ray shot low.
Arrive
Raise Hell
Leave
JoeInNVa is offline
Old 06-23-2008, 12:48 PM
Read the FAQ!
Liked: 2823
There have also been leaks here (our far flung correspondents) stating that studios have done tests with true 12 bit color all the way from capture to light coming out of the display and viewers can't tell the difference to 8 bit color through similar quality home theater hardware (with higher bit rate internal processing).
I.e., going to the effort to capture the content to that bit depth gains nothing.
Take such reports with a grain of salt as there's no way to vet them, but it makes sense that there are diminishing returns in video digitizing just as there are in audio -- beyond a certain point human viewers can't tell the difference.
Personally I think increasing the color gamut is more important. The xvYCC color space standard (also optional in HDMI V1.3) does just that. It may turn out that 12 bit color encoding shows best if the content is also captured (and stored, and processed, and transmitted, and displayed) in the larger color gamut.
I.e., it takes more "steps" to span the increased color gamut smoothly.
All of this is fun to talk about, but it's not really relevant to Blu-Ray. Wait 10 years and there will undoubtedly be a new disc format that replaces Blu-Ray.
--Bob
Old 06-23-2008, 01:13 PM
Ruined's Avatar
Quoted: 263 Post(s)
Liked: 82
I think that is true, but the conversion to 8bit needs to be done properly for it to be so. If a studio does a poor job of downconversion, some artifacts such as banding could be introduced into the picture. However, if done properly I doubt most could tell the difference between 8bit and 12bit.
This particular Pioneer feature looks like it really just aims to correct aforementioned master downconversion errors, but how good of a job it does and at what cost (if any) to the rest of the picture will be unknown until we see it in action ourselves.
Ruined is offline
Old 06-23-2008, 01:23 PM
b_scott's Avatar
Quoted: 37 Post(s)
--Bob
i'm a pretty firm believer that BD is the last physical disc medium. beyond BD is downloadable HD. and it's coming fast.
b_scott is offline
Old 06-23-2008, 01:47 PM
mrjktcvs's Avatar
Now read what a guy from Kodak says:
http://www.kodak.com/US/en/motion/hub/itp/onColor.jhtml
mrjktcvs is offline
Old 06-23-2008, 05:18 PM
Pres2play's Avatar
Quoted: 470 Post(s)
Liked: 260
I'm happy someone is trying to make some head way with Deep Color. From all the initial reviews on hdmi 1.3, that's one feature that didn't seem possible. If fact, many reviewers dismissed Deep Color and even advised against upgrading to the newer sets.
Pres2play is online now
Old 06-23-2008, 07:56 PM
cpcat's Avatar
Re: DVD upconversion, look at the difference between a DVD upconverted with Reon to 1080p vs. a DVD upconverted to 1080p with a poor upconversion circuit. Massive difference, and the same will apply here. .
I doubt you are seeing "massive differences" in simply scaling from 480p to 1080p. The differences likely lie elsewhere. For example, with the Tosh XA2 (Reon), upscaling to 1080p results in undefeatable edge enhancement (even with the EE setting at zero) compared to 480p. You can see this easily with SD test patterns. Additionally, most displays recognize the upscaled resolution as "HD" and incorrectly utilize HD colorspace. This is incorrect, but it does result in "more pop" in the image.
cpcat is offline
Old 06-23-2008, 08:32 PM
HTMan34's Avatar
Not unless internet speeds are a lot quicker than they are now and become available to the majority of people soon...which will not be happening for a long time. The average cable/DSL internet speed is way to slow for people to be downloading 50GB movies all the time to replace a disc. Sure fiber connections via phone companies are here but are still not all that fast and are not readily available to the majority of people. Some type of physical medium will be around for a very long time, especially when a lot of people like myself actually enjoy collecting movies and having that physical disc in hand!
Go Celtics!
HTMan34 is offline
