AVS Sony PS3 FAQ (PS3 used as a Blu-ray player) - Page 10 - AVS Forum | Home Theater Discussions And Reviews
post #271 of 693 Old 02-21-2008, 04:35 PM
Cage123's Avatar
Originally Posted by SirDrexl View Post
The PS3 decodes it to PCM and sends that.
And receiving PCM is the same as TrueHD, it's just being decoded on the ps3 instead of my avr247 receiver(which isn't even capable of TrueHD, only multi-channel pcm) right?
Sorry, I'm still trying to understand how the whole audio thing works.
Cage123 is offline
post #272 of 693 Old 02-21-2008, 04:57 PM
iamrobk's Avatar
Exactly.
iamrobk is offline
post #273 of 693 Old 02-21-2008, 06:25 PM
JayMan007's Avatar
I know the 247 has multi-channel pcm because that's how I was using it with my hd-dvd. So what happens if a Blu-Ray movie ONLY has TrueHD on it, meaning there's no uncompressed sound option, what will my avr receive?
It should act the same way as the HD-DVD player.
TrueHD is a lossless codec which the PS3 will decode (think unzip) and send to the AVR as uncompressed (multi-channel PCM). As of now, it will not do that with DTS-HD MA. in this case, it will just use the DTS core, decode it, and send as PCM if thats how you have the PS3 configured... It can be configured to send DTS or DD5.1 as bitstream. There is a rumor that a future upgrade will allow for DTS-HD MA decoding. --thats about as far as my knowledge goes with this, as I just bought a PS3 a few weeks ago.
JayMan007 is offline
post #274 of 693 Old 02-21-2008, 07:13 PM
Cage123's Avatar
Cool, thanks for the help everyone.
Cage123 is offline
post #275 of 693 Old 02-22-2008, 08:23 AM
bplewis24's Avatar
Originally Posted by jeffk1965 View Post
How do you turn on and off the PIP on the PS3 when playing a profile 1.1 blue ray movie such as sunshine?
jeff
You should have to select the appropriate track on the BD.
Brandon
bplewis24 is offline
post #276 of 693 Old 02-22-2008, 02:55 PM
mindless's Avatar
I just received my PS3, and in the process of setting it up. I selected DD 5.1 & DTS 5.1 over digital optical, and HDMI for video. The Spiderman3 comes through only as 2 channel stereo. What am I missing??
I'm going outside to shovel snow while I wait for an answer.
mindless is offline
post #277 of 693 Old 02-22-2008, 03:16 PM
bgillyjcu's Avatar
OK...
I am very close to buying a PS3 since it can be had for only $299, it can be updated, DTS looks like it is in the words along with 2.0.
The Panasonic is great too...but not for $500.
MY QUESTION
Can I hook up the PS3 to output the video over HDMI and have it output the AUDIO over the optical output.
I have to do this for a couple months until I upgrade my receiver to one that accepts HDMI.
Video OUT HDMI to projector
AUDIO OUT Optical to receiver
Yes or no
Twitter @ Clefoodandbrews
bgillyjcu is offline
post #278 of 693 Old 02-22-2008, 03:37 PM
TheMoose's Avatar
Originally Posted by bgillyjcu View Post
OK...
MY QUESTION
Yes or no
Yes you can, I did that same thing for several months before getting the Denon 3808ci.
"Racing is........Life.......Everything before & after is just waiting"
TheMoose is offline
post #279 of 693 Old 02-22-2008, 04:48 PM
AarDee's Avatar
I'm going to wait til morning to shovel.
You probably have to set the BD / DVD Audio output to bitstream.
Aimez-vous basketball?
AarDee is offline
post #280 of 693 Old 02-22-2008, 08:10 PM
mindless's Avatar
Thanks- when I turned it back on, it output 5.1!!??
mindless is offline
post #281 of 693 Old 02-23-2008, 07:50 AM
Herb's Avatar
Quoted: 41 Post(s)
Hi everybody,
I just setup my new PS3 yesterday. While navigating the PS3 interface my projector says I'm getting 1080i, as expected. But when I watched the trailers that came on the sample disc, the picture cycled through black and then came up as 720p. This also happened with all three of the demo games I downloaded.
I'm using a Panasonic AE900.
Is there a setting I have wrong that is causing this?
Herb
Herb is offline
post #282 of 693 Old 02-23-2008, 08:12 AM
SirDrexl's Avatar
Originally Posted by Herb View Post
Hi everybody,
Herb
I don't know about the trailers, but it's likely that the demos are 720p. The PS3 won't automatically upscale them to 1080i (this has to be specifically programmed into the game). I'd say this is obviously the reason, but I wonder why the trailers wouldn't be 1080p. What disc is it?
BTW, you might want to try setting the PS3 to output in 720p, by unchecking 1080i/p and just checking 720p. Your projector is 720p native, isn't it? I find that 720p output from the PS3 looks a little better on my HD70 than 1080p. Also, having most things at 720p keeps it from handshaking as often, since the resolution isn't changing all the time. That's probably what it's doing with the black screens on yours.
SirDrexl is offline
post #283 of 693 Old 02-24-2008, 06:36 AM
AarDee's Avatar
Seems like the Audio Chart still needs to be updated. Is the OP still maintaining this FAQ?
AarDee is offline
post #284 of 693 Old 02-24-2008, 01:04 PM
hatchet's Avatar
I took the opportunity to mess around with my HT setup while the wife is out and the kids are occupied !
I seem to be missing something...
When I send my Onkyo TX-SR803 AVR bitstream audio from the PS3 watching Star Wars III: Revenge of the Sith, the PS3 display shows that it is playing Dolby Digital Multi-Channel 48kHz 448 kbps. In addition, the AVR screen lights up with the Dolby Digital logo even though it is a Dolby Digital EX track and my AVR supports that.
When I change the settings and send the AVR a Linear PCM track, the PS3 display shows up as playing Dolby Digital 5.1 Ch. 48kHz 448kbps and the AVR screen lights up PCM MultiCh.
Both settings sound good (bitstream definitely better/fuller) but what the PS3 displays seems backwards to me. What am I missing?
Wishlist - Emotiva amp, 2nd SVS sub, Panamax PC/SP...well, there is more!
hatchet is offline
post #285 of 693 Old 02-24-2008, 01:54 PM
SirDrexl's Avatar
That sounds normal.
I'm not sure why one says "multichannel" while the other says "5.1 Ch." but they both essentially mean the same thing (just with 5.1 being more specific). The DD indicator lighting up sounds normal because it's a DD track. Is there an EX light that isn't coming on?
In the second case, the PS3 is decoding the DD track itself and sending it as a 5.1 PCM track. The PS3 shows DD 5.1 because that is the track on the disc (as far as discrete channels are concerned), while the receiver shows PCM because that's what it sees. It just sees PCM audio; it doesn't know that it was decoded from DD. Perhaps the PS3 only displays "5.1" when it inspects the track for decoding?
Also note that the EX flag is discarded from the PS3 when the track is decoded to PCM. In the second case, you're just getting 5.1 discrete channels of audio without extracting the "extra" EX channel.
SirDrexl is offline
post #286 of 693 Old 02-25-2008, 03:31 PM
fjcruiser's Avatar
O.K. So if I'm reading this right the PS3 will do Dolby True HD 7.1 and 5.1, but only if used via bitstream and then with DTS decoding instead of the original Dolby? And then if you use it with LPCM it does it with the original Dolby but downconverts the 7.1 to 5.1? I think I read that right, but why is it that way? I want to go LPCM for the SACD at least, but I don't want my 7.1 soundtracks downmixed to 5.1., but with DTS HD HRA it get's downmixed.............BAHHHHHHBALLYHOOO....RATSAFRATSA...... ARRRRRRGGGGGHHHHHHHHH....I WISH THESE GUYS WOULD COULD JUST GET ALONG SO WE CAN JUST START BUYING STUFF!!!!!!!!!!!!!!!!!! DON'T THEY KNOW THAT MORE PEOPLE WOULD BUY THIS STUFF IF IT WAS ALL STANDARDIZED?!?!!?!?!?!??!?!?!
/rant off. Any of your help would be much appreciated
fjcruiser is offline
post #287 of 693 Old 02-25-2008, 03:48 PM
Beerstalker's Avatar
Liked: 24
Yes both True HD and DTS HR soundtracks will be sent out at standard 1.5mbps DTS if you have bitstream selected in the menu. If you have PCM selected then the PS3 will decode them and output them as LPCM. I believe that the 5.1 in parenthases means that this has been tested and it works with up to 5.1 channels. I do not think there have been any Blu Rays released with 6.1 or 7.1 TrueHD or DTS HR soundtracks so far, so nobody is really sure what will happen. (I do not think that the chart necessarily means they will be downmixed to 5.1, it's just saying that 5.1 has been tested and works).
Beerstalker is offline
post #288 of 693 Old 02-25-2008, 06:20 PM
fjcruiser's Avatar
Thanks Stalker. Then it's LPCM for me.
post #289 of 693 Old 02-25-2008, 10:57 PM
moshock's Avatar
After months, the audio table is still incorrect. Like, most of it.
moshock is offline
post #290 of 693 Old 02-25-2008, 11:06 PM
wittcap's Avatar
Just got my 40gb and COD4. I'm connected to my 50A2000 via HDMI and was wondering why it doesn't upscale the game to 1080p. The back of the game says it does support it, is there some setting I am missing???
wittcap is offline
post #291 of 693 Old 02-26-2008, 08:34 AM
jsganz's Avatar
I hooked an external HD to the USB port and the PS3 detected the HD but it said "No titles" even though there's a few movies on there. The HD is formatted FAT 32, but what type of files will the PS3 recognize? Apparently not what's on the HD now
jsganz is offline
post #292 of 693 Old 02-26-2008, 08:36 AM
jimwhite's Avatar
I think you need directories with specific names... ??
Jim White
St. Petersburg, FL
jimwhite is offline
post #293 of 693 Old 02-26-2008, 08:46 AM
Jay_Davis's Avatar
If you set bitstream on a True-HD disk it will output the hidden standard DD track (not DTS).
Jay_Davis is offline
post #294 of 693 Old 02-26-2008, 11:41 AM
SAIRUS's Avatar
if by going by that chart, then the PS3 can't do 7.1 TrueHD? Sad, I'm really close to getting a new receiver, but I might have to save up (was going to get an Onkyo 605).
I'm sooo blu right now.
SAIRUS is offline
post #295 of 693 Old 02-26-2008, 06:42 PM
seanoff's Avatar
press Triangle.
et voila
seanoff is offline
post #296 of 693 Old 02-26-2008, 06:46 PM
seanoff's Avatar
ugghh
The PS3 will decode the True HD on board and send the already decoded True HD to your amp as PCM. ie if the movie has 7.1 True HD the PS3 will send all 8 channels to your amp already decoded and the amp just amplifies the PCM signal.
seanoff is offline
post #297 of 693 Old 02-26-2008, 08:21 PM
sheldonison's Avatar
How do I pause my PS3 in the middle of a movie? I tried hitting the pause button, and then put the player in standby mode, but it "forgot" it was in the middle of the dvd when I took the PS3 out of standby.
Do I need to keep the PS3 on while the player is paused, until I complete viewing the disc? That seems like its power hungry, also, is it ok to keep the PS3 on continuously?
sheldonison is offline
post #298 of 693 Old 02-26-2008, 09:09 PM
SirDrexl's Avatar
You can't resume where you left off with the PS3, sorry. I'm not sure about the standalone players, but I believe the discs with Java won't resume on any player.
All you can do is see if it's one of the relatively few discs with bookmarking capability and use that.
Sairus, you'll probably want to get the 705 instead of the 605, since it will matrix lossless 5.1 tracks (the vast majority of surround tracks) into 7.1 with DPLIIx. The 605 will only do it for lossy tracks.
SirDrexl is offline
post #299 of 693 Old 02-26-2008, 09:59 PM
mph86's Avatar
This might be a dumb question but can the PS3 do uncompressed PCM?
mph86 is offline
post #300 of 693 Old 02-26-2008, 10:14 PM
chris0's Avatar
Yes, it plays those tracks just fine. When it internally decodes TrueHD it sends it over HDMI as uncompressed PCM. It'll be the same if/when it can internally decode DTS HD MA.
Pics from my TV here and here.
chris0 is offline
Closed Thread Blu-ray Players
