AVS Sony PS3 FAQ (PS3 used as a Blu-ray player) - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 693 Old 01-25-2008, 08:42 PM
Rob9874's Avatar
Originally Posted by Steve Schauer View Post
Under Video Output Format (HDMI), what are RGB, Y Pb/Cb Pr/Cr and Auto for?
RGB: A colorspace used by the PS3 to output video levels at a desired range. This colorspace is mostly designed for PC monitors. This is the desired colorspace for use in the PS3's XMB interface and also for video games because they are encoded in sRGB.
Y Pb/Cb Pr/Cr: Another colorspace for use with displays that accept Y Pb/Cb Pr/Cr input. If your display supports it, this is the desired colorspace when watching DVD, Blu-rays or AVCHD videos.
Auto: Just like it sounds, it automatically selects between RGB or Y Pb/Cb Pr/Cr colorspaces depending on the source of the video. Selecting Auto will most likely result in the PS3 using RGB Levels for the XMB interface and Video Games, and Y Pb/Cb Pr/Cr for DVD and Blu-ray discs.
OK, I'm doing something wrong. When I go into display settings, under Video Output settings, I choose HDMI, but I don't see anything asking about RGB or Y Pb/Cb Pr/Cr. Just asks if I want automatic or custom, which selects which resolutions I want. Nothing about RGB.
Rob9874 is offline
post #92 of 693 Old 01-25-2008, 08:54 PM
chris0's Avatar
Ok, go to Settings, select Display and then just wait a minute...look over what's listed on the screen.
If what you quoted is confusing you can blame Brandon, he wrote it.
Pics from my TV here and here.
chris0 is offline
post #93 of 693 Old 01-25-2008, 09:23 PM
Rob9874's Avatar
I don't think it's confusing, I'm just not seeing the options. Here's where I go:
Settings
Display Settings
Video Output Settings
I see choices for HDMI, component, composite, and AV Multi.
I choose HDMI.
The next screen over says "automatic" and "custom".
I choose custom, and it asks which resolutions my TV supports I choose 480, 720, and 10801 (automatic selects the same thing).
Then the next screen over is the summary of those choices. Nothing about RGB.
Under the Display Settings, I have options for if I want my RGB to be full or limited, as well as the Super White. But I want to make sure I have everything set correctly, and can't find the option for selecting RGB or Y Pr/Cr.
Rob9874 is offline
post #94 of 693 Old 01-25-2008, 09:39 PM
shabre's Avatar
Originally Posted by geko29 View Post
AFAIK, Sopranos Season 6 part X (forget if it's 1 or 2) is the only title to have just a PCM track. And no, it's not a stereo track. And yes, that's a BIG problem for people who don't have the ability to play back multichannel PCM. Nothing like a dramatic TV show with no dialog......
Also, Elton John 60th birthday bash. No standard DD or DTS. Big disappointment for a concert disc to have to listen in 2 channel stereo, or have my Pioneer 1015 matrix the 5.1
shabre is offline
post #95 of 693 Old 01-25-2008, 09:48 PM
chris0's Avatar
Now I get what you're looking for. Don't go to Display, go to BD/DVD Settings.
chris0 is offline
post #96 of 693 Old 01-25-2008, 10:20 PM
SirDrexl's Avatar
Well, to be fair, the PS3 will downmix the track to stereo, so you won't lose the dialogue. It doesn't just play the L & R channels.
Rich Davenport, you can apparently re-download the games as many times as you want to the same PS3, even after replacing the hard drive. You are limited to 5 PS3s though. I believe this is to account for multiple systems in a family and/or system failures, but of course some use it to share with their friends.
SirDrexl is offline
post #97 of 693 Old 01-26-2008, 12:51 AM
Rob9874's Avatar
Thanks!!!
Rob9874 is offline
post #98 of 693 Old 01-26-2008, 07:22 AM
Rich Davenport's Avatar
I looked in the manual (I know, cheating) and found a backup/restore utility under Settings -> System Setting. I assume it will backup and restore games. Am I right?
Manual Entry
Member of AVS FORUM folding@home team, (team #55280)
Rich Davenport is offline
post #99 of 693 Old 01-26-2008, 09:06 AM
jsganz's Avatar
Originally Posted by dj_james View Post
I am so fed up with my bdp 1200. The PS3 just seems like its the only player that plays all the discs without problems. should i buy one or wait til bluray is stable??? any feedback is definately appreciated!
I went with the PS3 (40GB) for that very reason. I didn't feel like consantly updating the firmware to play new releases. The updates on the PS3 are mainly just for adding new features and are especially easy with the wifi capabilities. I've rented (from Netflix) and played many new releases without any problems. Bluray stability is here using the PS3.
jsganz is offline
post #100 of 693 Old 01-26-2008, 09:12 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Yep, I have never had an issue of any kind. I don't know why anyone would buy a stand alone and continue to upgrade or suffer through playback issues.
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
post #101 of 693 Old 01-27-2008, 02:06 AM
yourgrandma's Avatar
My goodness. I really hate to be the guy who asks the question for the 29,576,734,680,153rd time, but the answers always seem to come from somewhere else.
Would I be correct if I were to state that the PlayStation 3 WILL NOT output ANY 7.1 tracks?
From what I can tell, it downmixes anything with 7.1 in it to 5.1, right? If this is the case, wouldn't that put a fairly quick end to the argument over how good of a BD player it is?
I have one, but my AVR lacks HDMI. I was planning on upgrading, but from the sounds of things, ther would be no reason to do so, if I can get better sound from a DVD.
Onkyo TX SR805 | DVD-1920 | Optoma HD70 | PlayStation 3 | Definitive Technology ProTower 400 | Pro Center C2 | BP2x | Pro Monitor 100 | Klipsch RSW-10
yourgrandma is offline
post #102 of 693 Old 01-27-2008, 08:16 AM
I found this in the manual:
*1 A device compatible with Linear PCM 7.1. Ch. is required to output 7.1 Ch. audio from the HDMI OUT connector.
*2 The system does not support output from DTS-HD 7.1 Ch.
DTS-HD 7.1 Ch. audio is output from 5.1 or a lower channel.
Which implies it does 7.1, just not for DTS-HD 7.1.
There is also mention in this thread on how to limit 7.1 to 5.1 if your receiver doesn't support it.
post #103 of 693 Old 01-27-2008, 09:14 AM
dave1216's Avatar
Quoted: 97 Post(s)
Liked: 59
Well I bought the 40G PS3 at BB with the 20% coupon yesterday. I thank everyone in this forum for all their help in deciding on getting a PS3. Hooking it up and using the Wifi to get a system update was easy. Setup seemed automatic with my 52Xbr4. Last night I watched Cars and played Need for Speed Carbon. Cars looked fantastic. I could get my face right next to the screen and not see any artifacts. Can't do that with cable. Need for speed was awesome. Don't know what the refresh rate is, but the graphics are fantastic. We will play this alot.
One question...can I use a universal remote to control the DVD functions?
dave1216 is offline
post #104 of 693 Old 01-27-2008, 09:29 AM
You'd need a USB IR receiver for it.
post #105 of 693 Old 01-27-2008, 09:40 AM
Look on page one of this thread for "remote".
post #106 of 693 Old 01-27-2008, 01:32 PM
ldavis's Avatar
Rich,
That is what I was questioning in an earlier post. In the table on the orginal post, it shows TrueHD7.1 output at 5.1 (only LPCM output at 7.1). I cannot find that anywhere else and I asked how that was known. Also on DTS-HD, I am guessing that DTS-HD is unsupported and is output as the 5.1 Core, but I asked from some confirmation on that. If that is the case, it seems likely the the DTS 7.1 issue would be rectified if/when DTS-HD HRA and MA are supported.
ldavis is offline
post #107 of 693 Old 01-27-2008, 01:45 PM
It's strange that multiple threads on the same sites seem to have differing veiws on whether the DTS HDM issue is hardware or firmware related. Obviously, I hope it's firmware, but I don't know enough to make a guess.
post #108 of 693 Old 01-27-2008, 08:09 PM
dj_james's Avatar
finally picked up the 40 gb, got to watch my "war" disc that i've been sitting on for a month. funny how easy it was.. .
dj_james is offline
post #109 of 693 Old 01-27-2008, 08:20 PM
moshock's Avatar
I don't think that Audio Compatibility Chart is very accurate.
Under Bitstream (TOSLINK) it lists 'DTS' for DD TrueHD 7.1/5.1 and 'Yes' for DD+. That is simply incorrect. For any discs with those TrueHD/DD+ codecs, you will only get regular DD 5.1 playback via Bitsream (TOSLINK). It is not capable of giving you those higher resolution audio codecs.
Now, I previous HD-A2 I had did transcode the higher resolution audio codecs into DTS; however, my new 40GB PS3 does not.
moshock is offline
post #110 of 693 Old 01-27-2008, 11:54 PM - Thread Starter
Steve Schauer's Avatar
You're right moshock, thanks. Any Dolby downsampling will be to DD not dts. DTS downsampling will be to dts. I'll update the chart.
Steve Schauer is offline
post #111 of 693 Old 01-28-2008, 05:44 AM
NOLAGT's Avatar
Best buy wouldn't take my 20% off. Register lady had to call the manager....manager couldn't get off there fat rump and come look so said uhhh the ps3 isn't on it. I asked them if its not a BR player why does it ONLY come with a free movie....and 5 more free when you buy the damn thing!
Who can I call? I am going to call reward zone today....I want my 80 bucks!
NOLAGT is offline
post #112 of 693 Old 01-28-2008, 06:00 AM
RaiderRodney's Avatar
I didn't get the discount either...told me it didn't apply to the PS3 because it is considered a gaming console even though it plays BD
RaiderRodney is offline
post #113 of 693 Old 01-28-2008, 07:13 AM - Thread Starter
Please post these kinds of experiences in the Special Deals thread. Thanks.
post #114 of 693 Old 01-28-2008, 08:04 AM
Sevenfeet's Avatar
Quoted: 93 Post(s)
Liked: 116
I believe it's hardware. I posted several days ago in the other thread that my opinion was that the Silicon Image SiI9132 HDMI transmitter chip found in the PS3 lacks the I2S audio bus features found in their SiI9134 chip that is normally sold to CE manufacturers looking to make full featured BD players. I looked at a similar chip from a Silicon Image competitor and it has I2S as well for HDMI 1.3 audio compatibility. The 9132 is marketed to graphics card and PC board manufacturers where bitstreaming of HD audio seems to be less a requested feature.
Bottom line is that although the graphics side of the 9132 appears to support key HDMI 1.3 technologies, the 9132 only supports HDMI 1.2 on the audio side. But that still gets you the ability to pass the uncompressed HD audio 7.1 streams that the PS3 already pre-processed (and your receiver would have had to do anyway). This kind of backward compatibility for HD audio was built into the HDMI standard so that owners of receivers dating back to HDMI 1.1 would still be able to hear the codecs as intended. Owners of pre-HDMI receivers still get a properly mixed Dolby Digital 5.1 over optical as a worst case scenario. In many ways, this backward compatibility is far better designed than the Dolby Digital 5.1->Dolby Surround deal a decade ago.
Sevenfeet is offline
post #115 of 693 Old 01-28-2008, 09:14 AM
Silverbull271's Avatar
I need some help.....I have the Sammy LNT5271F (AMAZING SET)
I have a ps3/hdmi....picture looks AMAZING
Thing is this.....when i press info button during playback, it says its running in 24hz.....i went into ps3 settings....its set to 1080P .....how can,(if) change this settings to 60hz? I looked all over, and there is no option for this....i even just downloaded latest ps3 system update
I had read in previous thread that this can be done
Any help would be greatly appreciated
Silverbull271 is offline
post #116 of 693 Old 01-28-2008, 11:14 AM
xradman's Avatar
Great chart. I think you should add that currently PS3 does not correctly handle 4:3 SD contents in Blu-ray. These are often extra features and rather than showing them pillar boxed, PS3 stretches them into 16:9 ratio. What's interesting is that HD 4:3 contents on Blu-ray and SD 4:3 contents on SD DVD are correctly framed.
Addicted to shiny round discs with HD content
My Home Theater
My Movie Collection
BDP-83 EAP (second group)
xradman is offline
post #117 of 693 Old 01-28-2008, 11:36 AM
AarDee's Avatar
Look in Settings -> BD / DVD Settings -> BD 1080p 24 Hz Output (HDMI)
And set it to Off
Aimez-vous basketball?
AarDee is offline
post #118 of 693 Old 01-28-2008, 11:41 AM
agentalbert's Avatar
I have an SACD question about the 80gb PS3. I realize it only outputs via HDMI and that there are no analog outputs. And this then requires a receiver or processor that can accept copy protected audio via HDMI. But I think I read that the PS3 converts the DSD to PCM? Is that right? If so, that sorta nullifies the advantage of sacd, doesn't it?
agentalbert is offline
post #119 of 693 Old 01-28-2008, 12:06 PM
Rob9874's Avatar
I have another question about the video output settings. I have a Sony KP-51WS520, rear projection HDTV. Should set the video output to RGB? And also, since the TV is only 1080i, should I turn the 1080p/24 fps to "off", instead of "automatic".
Rob9874 is offline
post #120 of 693 Old 01-28-2008, 02:21 PM
ruffhyder's Avatar
When is the best time to buy a PS3? I've heard that they just reduced the manufacturing cost to half... I'm not in a hurry but would like one ASAP. Should I wait or jump into the 40GB one now (that's the one I want)? Do you think that will discontinue this model since the 120GB/160GB's are coming out? Thanks!
ruffhyder is offline
Closed Thread Blu-ray Players
