DTS-MA or do I like gadgets? - AVS Forum | Home Theater Discussions And Reviews
Old 01-28-2008, 05:39 PM - Thread Starter
CrushedBeerCan's Avatar
I haven't seen many threads that people have actually heard with their own ears rather discerned the difference through specifications between lossless codecs and lossy codecs.
I have a non-hdmi AV switch and I plan on keeping it for a while. Is it worth the 400+ dollars to get a BD player that will do lossless (over analog) or not?
When going through Hell, keep going -- Churchill
UMC-200, DDRC-88A, Anthem MCA 50
GoldenEar Triton 5, GoldenEar SuperCenter XXL, GoldenEar SuperSat 3
SVS PB-2000 (dual)
Pioneer Kuro 5080
CrushedBeerCan is offline
Old 01-28-2008, 08:04 PM
Thundercleise's Avatar
It's only worth it if you don't plan on upgrading your receiver. If your plans involve a new receiver, get one that can decode the advanced codecs and pick a player that can bitstream it over HDMI. As for a difference, I can notice a difference between DD and Dolby TrueHD. It all depends on what you like and how good your hearing is.
Thundercleise is offline
Old 01-28-2008, 09:13 PM
Pyro2's Avatar
Can someone clarify whether all BD players can at least bitstream Dolby Digital, or is dependant on the media?
I haven't heard the difference between the two, but I am not yet convinced its worth shelling out the money for a new receiver that can decode the new formats. I am so far quite satisfied with Dolby digital. If anything, most content needs to put more mixing into the surround formats. Also, anyone know if the front channels compressed in Dolby Digital?
Pyro2 is offline
Old 01-28-2008, 09:27 PM
geko29's Avatar
Every Blu-Ray and HD DVD player ever made can bitstream both DD and DTS.
And yes, ALL channels are compressed in Dolby Digital, including the fronts. HIGHLY compressed in the case of SD DVD, less severely (but still pretty bad) on Blu-Ray/HD DVD.
Silence is Golden. Duct Tape is Silver.
geko29 is offline
Old 01-29-2008, 03:59 AM
thehun's Avatar
Quoted: 583 Post(s)
Liked: 470
Do a search with the name "Filmixer" and you might wanna listen what he has to say on that topic. He can actually compare all of the codecs to the original master he mixed himself. Now how many others here can do the same? None!
De sagittis Hungarorum libera nos, Domine!
The Hun
thehun is offline
Old 01-29-2008, 04:25 AM
ClevelandRob's Avatar
Yes. I am a gadget whore too.
Also... I'm not sure if you've realized this by now, but you are reading my sig.
ClevelandRob is offline
Old 01-29-2008, 04:41 AM
TheHDMan's Avatar
You are a gadget Whore. Start actually "watching" the movies and enjoying them and you won't notice any difference...
TheHDMan is offline
Old 01-29-2008, 05:10 AM
jpsomner's Avatar
Yes, you can hear the difference. How good are your ears though? Can you discern the difference between DD and DTS? If you can, then you will be pleased to know that, by the numbers, the difference between lossy vs. lossless is many times greater than DD vs. DTS meaning that you will hear the difference much easier. To me, the difference between lossy vs. lossless is actually similar to the difference in clarity, definition and depth of SDTV to HDTV. Of course, any audible difference is listener/system dependent.
For comparison of HDDVD and Bluray discs, including specific reviews of video and audio performance, try highdefdigest.com. They LISTEN to all the codecs and report how they compare with each other.
jpsomner is offline
