The Samsung LN-T4071F, LN-T4671F, and LN-T5271F have been added to the list.
Sony now has some competition for those looking for the true 1080P/24 5:5 pulldown feature (multiplies of the original frame). It has now officially been confirmed by a professional review published by Scott Wilkinson at UltimateAVmag.com that the Samsung LN-T4671F offers true 5:5 pulldown.
All 3 Samsung displays use the exact same instruction manual and the specs are exactly the same on each model accept the physical weight and size. The instruction manual has an error in it on page 29 it mentions that if you turn off Auto Motion Plus it also turns off 120HZ. If one reads the instruction manual one would think their display becomes a 60HZ display just like all the other 60HZ Samsung displays. According to the professional review the 120HZ Samsung is always native 120HZ even when Auto Motion is turned off. When auto motion is turned on it may once and a while improve 60HZ video by interpolating each frame but it also causes major artifacts in the picture once and a while. When auto motion is turned off 60HZ is frame doubled to 120HZ without the problem of artifacts at the cost of having a less smooth picture.
When Auto Motion is turned off and one is watching a BLU-RAY the set will repeat each 24fps frame until it reaches 120HZ. This Samsung offers true 5:5 pulldown and the image from BLU-RAY will look like 35MM or 70MM film instead a artificial smooth 60HZ video look.
Added to the list
Samsung LN-T4071F
Samsung LN-T4671F
Samsung LN-T5271F
Quote
The LN-T4671F includes a feature called Auto Motion Plus (AMP), which can be set to Low, Medium, or High, or it can be turned off.
If it's off, each frame in a 60Hz signal is simply doubled, and each frame in a 24Hz signal is repeated five times. In any event, the set's refresh rate is always 120Hz whether or not AMP is enabled.
Some Positive items from the review
The Samsung 120HZ models will decode 3:2 pulldown from 60HZ material.
Quote
In any case, with a 60Hz signal, the processor is said to determine the original frame rateconverting it back to 24fps using inverse telecine if it encounters 3:2 pulldown..
I really like the menu system, which is much better than the one in Samsung's earlier TVs. The picture controls are now the first things to appear when you press the Menu button, rather than being several layers deep.
All in all, the LN-T4671F is a fine LCD TV. It exhibits exceptional color and detail, the blacks are nice and deep, and the shadow detail is better than most LCDs I've seen
Real-World Performance
Pioneer created a Blu-ray demo disc to show off its Kuro line of plasmas, but that material is great for evaluating all types of displays, especially in terms of black level and shadow detail. The Samsung's blacks were certainly not on par with the Kuros', but no one should expect them to be, especially an LCD with conventional backlighting. Still, they weren't bad by any means, and
shadow detail was surprisingly goodthat is, once I had set the TV's brightness and backlight controls correctly. Colors were beautiful, and detail was razor-sharp.
Turning to
Pirates of the Caribbean: Curse of the Black Pearl on Blu-ray, the Samsung produced a smooth, natural image with exceptional color and detail. Shadow detail in night scenes was similarly excellent.
Negatives
Quote
The
FPD For Professionals Blu-ray test disc provides some excellent clips to evaluate a flat-panel display's motion rendering and other characteristics. Auto Motion Plus did clean up moving objects quite a bit, but it also introduced some serious artifacts in certain types of images.
For example, it sharpened the horizontally scrolling monoscope pattern, but the horizontal and diagonal bursts were full of distortion artifacts. Turning AMP off removed the artifacts, but the motion was a lot blurrier.
AMP did improve the horizontally scrolling characters and map as well as the swinging hammock and metronome without problems, but the artifacts are so obvious when they appear that I tended to leave AMP off.
http://ultimateavmag.com/flatpaneldisplays/208sam4671/
