Dish - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By baimo
  • 1 Post By Ryan_M
  • 1 Post By baimo
post #1 of 4 Old 01-02-2000, 08:12 AM - Thread Starter
Ryan_M's Avatar
Due to the problems associated with cable in my area I have pretty much decided to go the satellite way. I'm currently not doing the HDTV however that will most definitely be an issue in the next few months for me. Question is whether to go with Dish or DirectTV? If I go with DTV is it just easier to get the RCA DTC-100 or wait for a newer model with component access? Or is Dish the way to go, what is there support for HDTV at the current time? It appears that Dish has the better prices for programming. Any help would be appreciated.
Ryan_M is offline
post #2 of 4 Old 01-02-2000, 11:31 AM - Thread Starter
Ryan_M's Avatar
Any idea on when the 6000 receiver will be out?
Stu03 likes this.
Ryan_M is offline
post #3 of 4 Old 01-02-2000, 05:06 PM
baimo's Avatar
I would assum they will announce that at the las Vegas show this week.
Baimo
chalugadp likes this.
baimo is offline
post #4 of 4 Old 01-02-2000, 10:27 PM
baimo's Avatar
If you are waiting a few months for HDTV,the choice will probably be similar. Dish is coming out with their 6000 receiver that has an HDTV decoder built-in. I am sure(after learning from DTV's mistake) it will have component and other outputs.
So the choice just might be programming.
DTV has better exclusive sports packages and Dish seems to have better movie packages.
Baimo
Stu03 likes this.
baimo is offline
Closed Thread General Home Theater & Media/Game Rooms
