My new bar, HT and basement build - AVS Forum | Home Theater Discussions And Reviews
post #1 of 22 Old 03-21-2008, 06:31 PM - Thread Starter
John Martin's Avatar
Hey all,
Although I have a build thread over in the dedicated side, I figured I would go ahead and start a thread here since my build is really more than a dedicated HT.
My first pics are of the bar area. Some may have seen the initial photos over on the dedicated side but here are the most recent photos of the work I got done today.
Since my mom has been visiting for the past week I did not get a lot done in the basement but I did manage to get some staining done on my bar today.
The stain color is a Minwax Red Oak over oak edging while the bar top is oak flooring finished in Minway Ebony stain.. The beadboard in the photos is from Lowe's and I am not really sure what type of wood it is, and the cabinets are oak. I really like the color contrast between the black stain and the red oak, and the way the beadboard takes the stain and gives a nice difference in how the wood reacts.
Tomorrow I plan on on putting on a few coats of Polycrylic throughout the day. Hopefully it will turn out nice. I plan on picking up a Magic Chef under counter beverage center from HD on Sunday so hopefully by end of day tomorrow I will be done with all my woodwork and can plug it in and load it up with beer and soda.
John
John Martin is offline
post #2 of 22 Old 03-21-2008, 06:50 PM
WBFletcher's Avatar
Looks nice! I like the tiles a lot.
WBFletcher is offline
post #3 of 22 Old 03-23-2008, 05:18 PM - Thread Starter
Got 4 coats of poly on the bar top this weekend. Turned out pretty nice. I still have half a can of poly left so I will continue outting on coats until I run out
Here is the bar top after 4 coats.
Also picked up an under counter beverage center from HD. $299 plus a $50 rebate. Not a bad deal.
I still need to clean the floor and seal it so ignore that part.
post #4 of 22 Old 03-23-2008, 06:23 PM
cathead's Avatar
looks great. I love the granite tile.
cathead is offline
post #5 of 22 Old 03-24-2008, 06:10 AM - Thread Starter
Thanks. So do I. Looks even better in person. Pictures make everything look dusty due to the flash. In person it super shiny and a perfect fit for the rest of the bar.
post #6 of 22 Old 03-24-2008, 01:56 PM
Netko350Z's Avatar
Very nice!
I like the look of the painted front side. I thought about doing the same to my bar front.
What fridge is that?
Netko350Z is offline
post #7 of 22 Old 03-24-2008, 02:23 PM - Thread Starter
Originally Posted by Netko350Z View Post
Very nice!
Netko,
Is is a Magic Chef, 5.8 CF under counter beverage center from Home Depot. Cost $299, plus a mail in $50 rebate and we used a $10 off coupon.
John
post #8 of 22 Old 03-24-2008, 07:03 PM
djn312's Avatar
Looks great!!
Doug's Home Theater
djn312 is offline
post #9 of 22 Old 03-25-2008, 06:47 PM
Netko350Z's Avatar
Originally Posted by John Martin View Post
Netko,
John
DAMMIT... Imight pull mine out and get that!
I love the glass front!
post #10 of 22 Old 03-25-2008, 07:37 PM - Thread Starter
Originally Posted by djn312 View Post
Looks great!!
Doug's Home Theater
Thanks Doug.
post #11 of 22 Old 03-25-2008, 08:30 PM
Fuzzybear50's Avatar
Hey John your bar looks great! How much variance did you give for framing in the beverage cooler? I was going to put one of these under my bar but I want to make it snug but not too tight.
Beer is the answer! What is the question?
Fuzzybear50 is offline
post #12 of 22 Old 03-26-2008, 06:01 AM - Thread Starter
Fuzzy,
I am not home to measure it but I believe I made the opening 24.5" to give a little cushion on the sides. I ended up with just under a 1/2" on each side. Depending on your flooring you may have to work it a bit. I installed slate and each piece is not the same thickness so I had a little difficulty getting the thing under the counter as I kept catching on the slate edges. It has leveling pegs on all 4 corners so keep that in mind when installing
post #13 of 22 Old 03-26-2008, 11:39 AM
micmag's Avatar
What type and size oak flooring did you use for the bar? how did you secure it?
micmag is offline
post #14 of 22 Old 03-26-2008, 04:04 PM - Thread Starter
It is unfinished 2.25 oak secured with liquid nails and brads to hold it in place until the liquid nails dried. It is freaking solid for sure as it is installed over .75" plywood subbase. It is stained with Minwax Ebony stain with 4 coats of poly on it.
post #15 of 22 Old 03-26-2008, 05:20 PM
HeyNow^'s Avatar
How did I miss this? Nice work, I love the base color and the Granite tiles....this is going to be a focal point for your friends, family and me when I'm invited!
Congrats!
HeyNow^ is offline
post #16 of 22 Old 03-26-2008, 05:34 PM
micmag's Avatar
Thanks for the info. It looks great.
micmag is offline
post #17 of 22 Old 03-26-2008, 06:38 PM - Thread Starter
Congrats!
Thanks Randy. Your bar was my inspiration for the wood top as was Hawkeye Josh's for the granite. You are welcome any time (after I finish the whole basement that is). Let me know if you are ever down this way and I'll have you over for a beer or two.
John
post #18 of 22 Old 03-26-2008, 06:39 PM - Thread Starter
My pleasure and thanks for the compliments. If the rest of my basement turns out as well as this has I am going to be very happy.
John
post #19 of 22 Old 11-04-2008, 10:29 AM
bchristo's Avatar
Netko,
John
John,
First, the bar looks great!
I am looking at the same set-up for my fridge. Same fridge from HD too. Do you have any problems with the fridge not cool your beer enough? I appreciate your insight
Brett
My Build Thread:
http://www.avsforum.com/avs-vb/showthread.php?t=1067354
"Sometimes you gotta race!"
Its the fastest game on two feet...check it out:
http://www.uwplatt.edu/org/lax
bchristo is offline
post #20 of 22 Old 11-05-2008, 05:58 PM
Dinger23's Avatar
Very nice work. Looks like a bar I could belly up to and drink a few
Check out Dinger's
Dinger23 is offline
post #21 of 22 Old 11-06-2008, 05:46 AM
jamis's Avatar
Nice work! Another +1 for the tiles. I have the same (but 12x12 in my HT bathroom).
jamis is offline
post #22 of 22 Old 11-06-2008, 05:59 AM - Thread Starter
Originally Posted by bchristo View Post
John,
Brett
Brett,
The fridge goes down to 39 degrees and while it takes a little while to get the drink cool, especially if you load it up full, once they are cool they are fine. No problems.
Thanks for the comments. I have done a lot more work to the bar since my last post. The basement if basically complete with only minor touch-ups in paint required and some theater trim work. I got (3) 42" bar stools locally here in Charlotte that work great at the front and I added a MAME machine to the side. Nice place to hang out now. I am looking to get a kegerator soon and start brewing my own too. Should be fun.
Jamis,
I am using the 6"x6" tiles in my HT bathroom. They look really good with a gloss sealer too.
John
