Need help with wall color - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 04-07-2008, 08:05 AM - Thread Starter
2MchBst's Avatar
I've gotten all the components I need for my theater room and just finished buying some furniture. What I need is some color advices for the wall. Here is a picture of the carpet, furniture and walls. I've seen where most people paint their walls some shade of red if they have dark furniture, but what do you when when your furniture is red?
2MchBst is offline
post #2 of 7 Old 04-07-2008, 09:10 AM
chinaclipper's Avatar
What do you do? You do what ever you want! That is the beauty of the home theater. Do you have a theme or a central idea for designs? For instance, my walls/colors are a burgundy/black combo, because I was trying to mimic the older theaters I remember from my childhood.
Colors help to mimimize reflections which will cause bad conditions for viewing, that is of course why lots of people chose the darker colors. Think of just about every theater you have visited.....
Best,
Tom
Chinaclipper
_______________________
Le Cinema Rockhurst
See my build progress here!!
chinaclipper is offline
post #3 of 7 Old 04-07-2008, 09:53 AM
Johnsteph10's Avatar
Quoted: 31 Post(s)
Paint whatever color floats your boat.
Personally, I think a dark khaki color in that room would make the red pop and look really good.
John
Johnsteph10 is offline
post #4 of 7 Old 04-07-2008, 10:04 AM
ImkSpyPlns's Avatar
I have a red couch and went with a dark mahogany color and love it. I'm not an interior designer, so I'm sure there was a better choice. But for the theater it seemed like the best dark choice.
Lurker extraordinare!
-Jared
ImkSpyPlns is offline
post #5 of 7 Old 04-07-2008, 10:42 AM - Thread Starter
2MchBst's Avatar
Do you have a pic you can put up. That's one of the ideas I was tossing around.
2MchBst is offline
post #6 of 7 Old 04-07-2008, 11:02 AM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
Agreed. A dark brown/tan would like great with the red.
@OP. I picked up a color wheel as well as a paint sample system (it has samples of almost all their colors) at Sherwin Williams and that has made all the difference.
ack_bk is offline
post #7 of 7 Old 04-11-2008, 06:37 PM
ImkSpyPlns's Avatar
Here's the best one I have that shows the color. Right now my theater is in a state of disarray, so I can't take any new ones. I really should take new ones soon.
It was a simple mahogany from home depot in their flattest paint.
-Jared
