Home Theater on a Budget - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-07-2008, 04:57 AM - Thread Starter
kaiservt's Avatar
I am moving in to a bigger place and will have room to have a small theater setup. The living room is about 12x15. I am picking up a Samsung LN52A550. I also have a pair of older Polk Audio RT55's that I was thinking about using as fronts. So I need a receiver (current receiver is old and beat from college abuse), a center channel speaker, rears, and a sub if needed (I'm thinking 5.1 at this point). I like Polk, but I have no strong feelings about staying with them. My HD sources are HD cable and there will be a blu-ray player in my future (not included in this purchase). I don't have an exact budget in mind, but I will say this. BANG FOR THE BUCK. I want a good sound, but I don't want to spend a ton as I have just dumped money into the TV. Thanks ahead of time.
-Kaiser
kaiservt is offline
post #2 of 3 Old 05-07-2008, 07:54 AM
JOHNnDENVER's Avatar
You are really going to have to give a budget.
Recievers are going to be best researched in the Amps, recievers, and processors section.
When I help people on tight budgets, I almost always suggest Parts Express Subs.
Where else can you get two decent 12" powered subs for $300-ish...
JOHNnDENVER is offline
post #3 of 3 Old 05-08-2008, 02:05 PM
cobolisdead's Avatar
Quoted: 45 Post(s)
For the sub:
http://www.amazon.com/JBL-SUB12-12-I...dp/B000FBRC6Y/
For the Receiver:
http://www.amazon.com/Onkyo-TX-SR705...dp/B000OBMX0K/
For the Rears:
http://www.amazon.com/Polk-Audio-Two.../dp/B000MGNDHE
For the Center:
http://www.amazon.com/Polk-Audio-Mon...dp/B0002MPMAE/
At least that is what I would do. Just shy of $900, and you have a Receiver that you can keep for a long time, that has HDMI inputs, a decent Center speaker, an awesome Sub-woofer, and some decent rears. Of course, you can always skimp a bit and get a better valued sub woofer, but I'd recommend that receiver to you regardless.
Quis custodiet ipsos custodes?
cobolisdead is offline
