Finally in my New House...basement plans - Page 12 - AVS Forum | Home Theater Discussions And Reviews
 104Likes
post #331 of 360 Old 11-17-2016, 02:17 PM
Quoted: 122 Post(s)
Following from JVC thread, I"m thinking if I should order HDFury as well. There are many 4K movies available to rent now so wondering if that's a good option. I"m new to HDFury but if I understand it correctly, it allows JVC to play any HDR 4k in SDR. Without it, any 4k HDR can only be played in HDR. So HDFury allows us to play in SDR and also allows us to utilize bt 2020. Is that correct?
Is this this right one to get? https://www.hdfury.com/shop/splitter...60-444-600mhz/
harrisu is offline
post #332 of 360 Old 11-17-2016, 02:36 PM
Quoted: 122 Post(s)
Originally Posted by PioManiac View Post
Yes, that's the one, and that's what it does.
Some (not all) 4K/UHD Blurays come out just a little too dark because most projectors are not quite bright enough for HDR.
Sure you can raise your contrast/brightness levels, but hat also raises the black floor (to dark grey).
The HDR "Flag" also disable the JVC's auto iris, and you wont get those deep "fade to blacks" between scenes.
The HDFury Integral EDID 10 (For SDR 4K BT.2020 4:2:0 ) removes the flag for HDR,
You then setup a custom memory slot on the JVC for 4K SDR that still maintains BT.2020 and Wide Color Gammut.
If you choose to simply turn HDR off in the player, without an HDFury, it reverts to Rec.709 with no WCG (same as regular bluray)
Cool. How big of a difference do you see with HDR off and UHD played in Rec.709 vs BT.2020? Is it an obvious and easily noticeable difference?
harrisu is offline
post #333 of 360 Old 11-17-2016, 11:11 PM
Liked: 4
So Pio, when I set up my X500 it is said to upconvert from 1080p to '4k' (faux k).
I don't have plans to run 4k material as my Anthem mrx710 is not 2.2 hdpc. And besides the pj is not 4k.
I have a 2 yr old Panny bluray player. Do I need the 900?
I want the best image quality possible. The JVC pj is a generation older than yours.
What would you do?
cr500guy is offline
post #334 of 360 Old 11-18-2016, 12:05 AM
Liked: 4
When the JVC is fed a 1080 source, it uses E-Shift
(explained in detail here: http://eu.jvc.com/microsite/eu/dla-x900r/feature01.html
When I up-convert bluray to 4K with the Panny UB900 is looks almost 4K
(My personal preference) and the JVC processes the signal just like a real 4K Bluray.
You have a few options with your Anthem,
The UB900 has two HDMI out ports so you can send 1 HDMI out for audio only to the Anthem and the other to your projector for 4K HDMI 2.2 HDCP video.
(yes you will likely need new cables)
The downside is you have no display from anything connected to your Anthem.
Another option may be to use an HDFury Integral
It has 2HDMI in and 2 HDMI outputs and the ability to adjust HDCP
Throw an inquiry at the HDFury Integral section on the forum,
they seem pretty helpful at finding solutions for incompatible hardware with HDMI
Link: http://www.avsforum.com/forum/37-video-processors/
You'll probably want one to strip HDR from 4K/UHD bluray anyway
You know you're officially going down the rabbit hole now right?
Love the rabbit hole. This is great stuff. Thank you so much for your help Pio. I will be circling back to this thread alot.
cr500guy is offline
post #335 of 360 Old 11-22-2016, 02:40 PM
asharma's Avatar
Quoted: 758 Post(s)
Liked: 94
Just had another thought,
You already have a 1.4 HDMI from your AVR to your JVC right?
The JVC does have two HDMI inputs so use the other for the Panny UB900 video HDMI out
Then you just need a second HDMI out from the UB900 to run to your AVR for audio.
(The UB900 does ship with a 6' 18Gbps HDMI cable)
I think I read somewhere that your best source (4K HDCP 2.2) should go to port 1 on the JVC
and the 1.4 HDMI (1080 sources) should go to HDMI port 2 on the JVC, check the manual to be sure.
Hey Pio...I tried Zombies setup for my new 750...do I recall you having written up basic settings? Would you have a link? Thanks
asharma is online now
post #336 of 360 Old 11-22-2016, 04:38 PM
asharma's Avatar
Quoted: 758 Post(s)
Liked: 94
I followed zombie10k's instructions to the letter (for 2D Low) BT.709 video.
of course the brightness/iris setting will be slightly different depending on room, throw distance, screen size, screen gain.
I set my black level just above crushing and contrast just below clipping whites with an AV Essentials test disc.
My Settings for SDR BT.2020 (when using the HDFury Intergral EDID 10)
posted on the previous page, are pretty much identical to my 2D Low BT.709
Both use the same Gamma, brightness, iris etc...
Perfect, thank you...I'm currently tutoring (phone calls) Pat in Red Deer in regards to his x500 he bought from me...is there any chance that you "could" eventually be available for a call when I eventually fail? Perhaps PM me?
post #337 of 360 Old 11-22-2016, 06:26 PM
asharma's Avatar
Quoted: 758 Post(s)
Liked: 94
Sorry, I've never owned a X500,
.. he would be much better off making inquiries here:
Official JVC DILA-X500R / RS49U / RS4910U Owners Thread
The owners in that thread have been tweaking their settings for 3 years,
I'm a JVC n00b myself at just under 3 months.
Sorry, I meant a call with u for me about my 750 settings, just in case I try the settings and I fail miserably...I've got the Philips player which uses the same menus and chip set as the Panni...I have everything set to 4:4:4...I have not tested much but what difference do u see with 12 bit vs 8 bit?
post #338 of 360 Old 11-22-2016, 07:02 PM
asharma's Avatar
Quoted: 758 Post(s)
Liked: 94
LOL, I have zombie10k's settings, everything else at factory defaults.
My player is also set completely to 100% factory defaults/auto.
That's what worked for me so that's where it's stayed, and that's all I know.
If that doesn't work for you, I have nothing else to offer
You'll have to make further inquires with the pro's who've owned these units for over a year.
They use custom calibrations, software, light meters and colorimeters to tweak their systems to perfection.
...and many of them have owned several generations of JVC's prior to the current models.
Official JVC RS600 / RS500 (X950R / X750R - X9000 / X7000) Owners Thread
Like I said, I'm totally new to JVC's,
as a former X500 owner, you've actually been an owner longer than I have.
Everything I know has already been posted on the last couple pages,
and what little I managed to pick up came from the official owners thread.
Don't be afraid to ask them, they don't bite.
No worries, for rec 709, bt2020 with and w/o HDR, curious what do u have the iris, contrast and brightness set for each respectively...did I miss that on a previous page?
post #339 of 360 Old 11-22-2016, 07:17 PM
asharma's Avatar
Quoted: 758 Post(s)
Liked: 94
I doesn't matter what my settings are,
(although I already told you just a few posts ago, you even quoted me)
You have to make adjustments for your room,
throw, screen size, screen material, screen gain.
This is not a TV set
I can't tell you what level your blacks are crushed at, or where whites are clipping
for all your different video sources unless I'm standing in your room.
Did someone else set up your previous projector(s) for you?
Yes, I had Lion AV out of the u.s. Calibrate my x500. He vacations near Halifax in the summer. Just don't feel like dropping $400 smacks again...I may actually purchase a Spyder 5 and try Autocal. I also Watch lots of hockey which drives bulb hours up so will need to tweak settings frequently as the bulb dims.
post #340 of 360 Old 11-30-2016, 07:21 PM
asharma's Avatar
Quoted: 758 Post(s)
Liked: 94
Calibration
Hey Pio...did I read somewhere in your thread u used digital video essentials HD basics disc to set your blacks and contrast for 709 and 2020? If u did, I just got the disc, 709 turned out ok for blacks and contrast by adjusting according to the black test pattern and the contrast test pattern but when I set for SDR bt2020 using the patterns the actually video was way too washed, same with HDR...the patterns adjusted ok but the actually movie looked like crap...any insights Sir?
Anthem mrx-1120, Panasonic ub900, jvc x950, 120" 2.35 screen, Golden Ear F55 subs (2), atmos 7.2.4
post #341 of 360 Old 11-30-2016, 07:58 PM
asharma's Avatar
Quoted: 758 Post(s)
Liked: 94
Do you have an HDFury Integral installed and the correct EDID installed?
My DVE disc is quite old and only came with Rec.709 test patterns.
Pretty sure you need an HDFury intergral installed before you properly set things up for SRD BT.2020.
Sony Bluray and 4K/UHD movies have a set of test patterns
accessibly by hitting 7-6-6-9 (S O N Y) on my Panny remote.
Sorry, can't recall which one I used.
My only adjustments for HDR BT.2020 were Contrast +14, Brightness +4
Thanks man, yes my DVE is from Amazon just today but I think it's a 2008 BR version. Yes I do have an integral with correct edids installed...actually for rec 709, would I just still leave the Integral on edid 10? Would it just pass thru?
I did switch it to 8 for HDR...actually I'll double check that one, I know I switched the pj to HDR...
Also for 709 and SDR 2020 you left contrast and brightness at default 0?
R u saying Sony's Lucy would have the test patterns?
post #342 of 360 Old 11-30-2016, 11:12 PM
Liked: 4
DLA-X500 will be here tomorrow, I just put my order in for a UXL18 for my 18hz tuned Marty Cube- it ships in 7 days. I took a week extra off in Dec. Good times.
I recall in one of the threads, Pio, you have had experience using the Monster power Centers.... Im wondering which one will allow my Anthem receiver to trigger one of its plugs for my subs amplifier. The subs amp is a Crown xls1500. Its a push button on/off switch. In other words it has no trigger input. So I would leave the amps button pushed in to 'on', have it plugged into one of the powercenter's plugs, and have that plug triggered, thereby powering the crown amp, upon the powering up of the Anthem.
I understand a guy can do that?
EDIT:
After some reading I just need to get me a power conditioner that has a trigger effect, but with a delay, so I don't get the 'thud' from my receiver powering on as well.
cr500guy is offline
post #343 of 360 Old 12-01-2016, 05:09 PM
asharma's Avatar
Quoted: 758 Post(s)
Liked: 94
Are you suggesting the test patterns on Sony uhd movies are bt2020 test patterns?
post #344 of 360 Old 12-02-2016, 12:45 PM
asharma's Avatar
Quoted: 758 Post(s)
Liked: 94
Thanks man, crap, I just paid $39 smacks for DVE from Amazon!
post #345 of 360 Old 12-06-2016, 09:48 PM
richlife's Avatar
Quoted: 473 Post(s)
Liked: 500
Hmm. Doesn't this thread need a minor update? Or was that the other @PioManiac ?
Atmos/DTS:X HT in Vaulted Room -- LG OLED Settings Options
Yamaha RX-A3060: 7.2.4 or 7.2.2 + Zone2 (switchable); OPPO 203; LG OLED65B6P; Harmony 650 & Home Hub
Base: Mirage OM-6 (FLR), MC-si (C), OM-R2 (SLR), FRx-nine (BLR)
Presence: ELAC A4s (FP), RSL C34Es (RP); 2 aci Titan subs; RP amp: AudioSource AMP100VS
richlife is online now
post #346 of 360 Old 12-15-2016, 04:46 PM
Yellow Jacket's Avatar
Quoted: 40 Post(s)
Liked: 8
Holy cow those are going to look sweet...
To Hell with Georgia...
Yellow Jacket is offline
post #347 of 360 Old 12-16-2016, 07:47 AM
Quoted: 40 Post(s)
Liked: 8
I have a pair of Ascend Sierra Ones in cherry finish, and I enjoy looking at them as much as listening to them.
I don't know if I'd ever turn those on, or just put them on the kitchen table and look at them.
PioManiac likes this.
post #348 of 360 Old 12-17-2016, 11:27 AM - Thread Starter
PioManiac's Avatar
Quoted: 1314 Post(s)
Liked: 1295
It's officially been three weeks since Black Friday,
and a L-O-N-G wait, and on the coldest freaking day of the year, -30º this morning
...it's Finally Here!
Unfinished Basement Theater & Whisky Guitar Lounge
JVC-DLA X750R | 120" Screen | LG 65" OLED 65B6P| Panasonic DMP-UB900 | HDFury Integral
Yamaha RX-A3050 + RX-V3900 | Atmos 7.4.4 | Mission M3i Speakers | Funk Audio 18.0 sub's
PioManiac is offline
post #349 of 360 Old 12-17-2016, 11:35 AM - Thread Starter
PioManiac's Avatar
Liked: 1295
Cool
post #350 of 360 Old 12-17-2016, 03:54 PM - Thread Starter
PioManiac's Avatar
Liked: 1295
Cool
Before Pic, 50" Pioneer Kuro
New LG 65" OLED is a Perfect Fit
Now I just need to relocate my Velodyne 12" subs
...and the XBONE and PS4 to make room for the Big 18.0's... on the way
post #351 of 360 Old 12-17-2016, 04:36 PM
DavidK442's Avatar
Quoted: 506 Post(s)
Liked: 341
DavidK442 is online now
post #352 of 360 Old 12-21-2016, 04:42 AM
Nexgen76's Avatar
Quoted: 421 Post(s)
Liked: 99
Wow......That's really close, the only advantage i could see in the pic is the whites on the OLED just a bit bright & so is the image. But that's scary close.
JVC DLA-RS400U
Sliver Ticket 120' Grey screen
Aggressive 1299 L/C/R/, Volt 10XL x 2 surround, MKII Atmos Modules x 4(Jav's build).
Denon AVRX6200W
Philips BDP7501 4K UHD Player
Ported Primate SI 18" HST subs x 2(DIY)
Nexgen76 is offline
post #353 of 360 Old 12-21-2016, 09:05 AM
healthnut's Avatar
Quoted: 444 Post(s)
Liked: 257
I do have one more toy that helps level the playing field,
The HDFury Intergral can remove the flag for HDR and play a brighter image on the JVC
while still maintaining 4K BT.2020 and Wide Color Gamut,
One more HDR comparison first...
JVC
OLED
JVC in SDR
OLED in HDR
JVC in SDR
OLED in HDR
JVC in SDR
OLED in HDR
To my eye, the JVC and the OLED look very comparable. I have the same gear as you, but I can't get the Panny and JVC to link with a 4k 4:4:4 connection. I contacted JVC and they suggested trying certified 4k 18 cables. I'm running Blue Jeans now from 4 feet and only getting 1080P rec709. What cables do you use?
healthnut is online now
post #354 of 360 Old 12-21-2016, 11:27 AM
skypop's Avatar
Quoted: 161 Post(s)
Liked: 79
Nice Pictures of the JVC Vs. OLD, I like the JVC pictures better because of the details shown,the oled seems to be over exaggerating the whites,look at the clouds in pictures and also in the Star Trek movie,the top of the heads of the people. Looks great though. I'm A JVC Projector owner also so I'm a little biased lol.
2 Channel: Fi 2A3 mono's,Hovland HP100 W/MM Phono Stage,Technics SP10MK2/SME/Benz,Medallion Cabinets With Fostex 206EN Drivers,Peerless Subs....HT:126" Seymour AT Screen,JBL Studio 590's LCR,JBL 8340a Surround,JBL HT5 Fr Heights, and JBL SCS8 Back Surrounds,2 Epik Empire Subs,HSU Midbass Sub,Marantz 7702MK2,Outlaw 7125,Marantz Ma500's,Panasonic UB900,Toshiba HD35,JVC RS400. Black Velvet.
skypop is offline
post #355 of 360 Old 12-21-2016, 11:42 AM
healthnut's Avatar
Quoted: 444 Post(s)
Liked: 257
I'm using several 18Gbps shorter 6' cables I bought from HDFury (4 pack for $99)
For my long run (40') to my JVC from the Intergral I have an IOGear active high speed ($69)
posted more details here: Finally in my New House...basement plans
If you're sending your signal through a Yamaha AVR you must put it in 4K Mode 1
it's in the advanced menu, where 4K Mode 2 is the factory default for lower bandwidth legacy devices/cables.
Snip from the Yamaha Manual:
Thanks for the reply. That 40" cable has to be good to output a strong signal of that length. And it seems to be reasonably priced. I need to rethink my choices in HDMI cabling.
post #356 of 360 Old 12-21-2016, 01:31 PM
skypop's Avatar
Quoted: 161 Post(s)
Liked: 79
I know the feeling,I have a 65" Panasonic VT plasma for everyday watching,only use the theater for movies,big sporting events and any 4k from Firestick. So 2-3 times a week normally.
skypop is offline
post #357 of 360 Old 12-22-2016, 02:05 PM
Quoted: 40 Post(s)
Liked: 8
Tasty!
post #358 of 360 Old 12-29-2016, 07:00 AM
srinivas1015's Avatar
Quoted: 188 Post(s)
Liked: 50
Seeing how you have both the Panasonic UB900 and the Oppo-203, can you comment on how the Oppo fares in terms of upscaling regular BDs? I ask because I hear the Panasonic is fantastic in that regard.
srinivas1015 is offline
post #359 of 360 Old 12-29-2016, 09:09 AM
Quoted: 188 Post(s)
Liked: 50
Sorry, but I have no idea where you got the impression I have ever had an Oppo.
I picked up the Panasonic UB900 shortly after it was released in Canada,
I believe it arrived just two days after my JVC back in late August.
The HDFury was ordered within two weeks later and that 3-way combo was a winner.
No need to ever even look at the Oppo, that would have been about the same price as
the Panny and HDFury combo...and from the sounds of the JVC thread...failed miserably
at HDR to SDR conversion.
..and Yes, regular 1080 bluray looks fantastic upscaled to 4K on the Panasonic.
My screen shots from Prometheus look better than many 4K/UHD's.
Oops, I thought you had posted about the Oppo being on the way. My mistake.
Anyway, the reason I had asked was because I have ordered the Oppo and am having a bit of buyer's remorse. The HDR to SDR conversion is a mess for now but I'm sure it will be fixed in a few months time. I'm actually more concerned about the upscaling capabilities of the Oppo compared to the Panny.
post #360 of 360 Old 01-16-2017, 07:39 AM
Ronman79's Avatar
Quoted: 191 Post(s)
Liked: 145
Been quiet here for a while. Pio, just wanted to stop by to let you know that I do believe I've decided on a JVC RS520, the new 500 that has a low lag game mode, which I'm sure you're already aware of. Your beautiful pics (and info) are one of the things that won me over from the Epson. Thanks for sharing!
Sent from my XR6P10 using Tapatalk
Ronman79 Theater Plan/Build: Click Here to Help... Current Equipment: 2016 Vizio P50 UHD FALD HDR Display (working on dedicated projection HT upstairs!) Polk Audio RTiA9 Towers / Polk CSiA6 Center / Polk FXi5 Bipole Surrounds / (4) Polk PSW505 12" Subs / Sony BDP-S790 Blu-ray / Dish Hopper with sling / XBOX One S / Harmony Elite & One
Ronman79 is offline
