everything is wired...but i'm not getting sound? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 12-27-2008, 03:33 PM - Thread Starter
mod220's Avatar
my dad just hooked up his AV system consisting of the following:
Pioneer Plasma
Sony Reciever
Sony BluRay
HD Cable Box (Comcast)
i cant provide a visual diagram, but heres what we did.
cable from wall to cable box
HDMI from Reciever to TV
HDMI from Reciever to Cable Box
HDMI from Reciever to to BluRay
visually everything works great, but we cannot get any sound? any idea? HDMI is working as the visuals are there, but no sound at all.
any suggestions?
mod220 is offline
post #2 of 17 Old 12-27-2008, 04:28 PM
Grae's Avatar
Did you configure your inputs for HDMI audio? Make sure they're not set to optical or something else.
Grae is offline
post #3 of 17 Old 12-27-2008, 04:41 PM
Quoted: 3272 Post(s)
Liked: 2751
you didn't mention hooking up any speakers to the receiver.
post #4 of 17 Old 12-27-2008, 05:25 PM
Wazzey's Avatar
make sure the input on the receiver is set to "auto" so it finds the digital signal. It is possible it is set to analog and is looking for the left right
Mike's attempt at a Theater
DIY motorized masking system
"Name?" Shropshire Slasher
"Occupation?" Shropshire Slasher
Wazzey is offline
post #5 of 17 Old 12-27-2008, 06:29 PM - Thread Starter
mod220's Avatar
speakers are hooked up fine, we get audio when using an optical cable, just cant seem to get HDMI to work
we tried all 3 seetings: 1) auto 2) analog 3) optical...none worked
mod220 is offline
post #6 of 17 Old 12-27-2008, 06:35 PM
victor-eyd's Avatar
Could be bad hdmi. Switch cables and see if the problem persists.
Free cake! Free cake!
- Mordecai and Rigby
Big Screen/Small Space! My 13x12 Bedroom HT
Think small, project big!
Small theaters gallery
victor-eyd is offline
post #7 of 17 Old 12-27-2008, 06:59 PM - Thread Starter
mod220's Avatar
but its transmitting visual perfectlly, it was my understanding hdmi was all or nothign...is it possible i have a bad cable that does visual only?
mod220 is offline
post #8 of 17 Old 12-27-2008, 07:26 PM
Wazzey's Avatar
what is the model # on the receiver?
Wazzey is offline
post #9 of 17 Old 12-27-2008, 07:49 PM
Liked: 2751
What happens when you switch the receiver to Tuner? do you at least hear static?
post #10 of 17 Old 12-27-2008, 10:37 PM
yodabadass's Avatar
Your receiver may be a model that only does video not audio decoding though the HDMI cable. We need to know what model you have to help you out more.
yodabadass is offline
post #11 of 17 Old 12-28-2008, 07:23 AM
BoomBoomRoom's Avatar
He probably has an HDMI pass through, not repeated reciever. He says optical works, and video works when switched.
BoomBoomRoom is offline
post #12 of 17 Old 12-28-2008, 11:34 AM - Thread Starter
mod220's Avatar
thanks everyone. the reciever is a Sony STR DG-510
mod220 is offline
post #13 of 17 Old 12-28-2008, 12:32 PM
Wazzey's Avatar
I'd start with one at a time....and unplug the other.
HDMI out to TV
Bluray HDMI in to DVD in...
If this doesn't work... run an rca cable from the bluray digital out to the "dvd in coax" on the back of your receiver. This should work and sound just as good.
The receiver says it is only 1080i passthrough... I have a feeling that audio might be an issue with the hdmi. I havn't looked close enough online
Wazzey is offline
post #14 of 17 Old 12-28-2008, 01:13 PM
Wazzey's Avatar
According to your quick start guide
Notes:
To enjoy multi channel surround sound from the dvd player be sure to connecto the coaxial digital cord.
To enjoy multi channel surround sound when connecting HDMI, be sure to connect the digital audio jack
I think you have to connect HDMI AND the digital audio out for sure
If you use the hdmi "DVD IN" then you have to use the coaxial digital in
If you use the hdmi "Video 2/BD IN" then you have to use the optical digital in
Wazzey is offline
post #15 of 17 Old 12-28-2008, 04:07 PM - Thread Starter
mod220's Avatar
but the problem is he can only run a single optical cable, and we have 2 devices (cable, dvd) so how do we do that?
i thought ultimately this was the purpose of HDMI, single cord, etc.?
mod220 is offline
post #16 of 17 Old 12-28-2008, 04:38 PM
Liked: 2751
I see 3 digital audio inputs, two optical and one coax, you should not have a problem.
HDMI cable does have the audio, your Cable box and Bluray probably output the audio over the HDMI cable. Sony in designing your entry level receiver decided not to build in the circuitry that would handle it. Your beef is with the Sony design team.
Time to think about Craig's list.
post #17 of 17 Old 12-28-2008, 04:42 PM
Liked: 2751
