I want a bookshelf that opens up...how are they hinged? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 01-16-2009, 05:36 AM - Thread Starter
kezug's Avatar
I am looking to build a book shelf into a closet space and I still want the functionality of the closet (to store my crap).
So imagine a closet cavity about 2.5 feet deep. I am considering building a bookshelf about 8-10 inches deep (stores some books, DVD's, knicknacks). So instead of using boring bifold doors, I would have a somewhat shallow, but functional, bookshelf in its place. Only this book shelf can be opened to expose the closet space.
My closet is about 5 ft wide.
I have seen a couple of web sites that show a book shelf unit swing open to expose a room, but I am curious as to what kind of hinges are uses. I am also hoping to not have to use any casters/rollers on the bottom.
I did some searches on the internet and I can not really find out how these units are hinged.
So I thought to ask my fellow AVS'ers, hope you can point me in the right direction.
kezug is offline
post #2 of 10 Old 01-16-2009, 05:43 AM
cane.mba's Avatar
Found this article not sure if this is exactly what you had in mind or not.
http://blog.simonshea.com/2005/10/sh...follow-up.html
Mike
cane.mba is offline
post #3 of 10 Old 01-16-2009, 06:22 AM - Thread Starter
kezug's Avatar
I saw that too. I was hoping to not have to use casters.
Also, of all my searching, I find a handful of web sites that seem to point to the same 2 or 3 designs. However, there is really not much emphasis on the hinges, although this link does.
kezug is offline
post #4 of 10 Old 01-16-2009, 06:38 AM
ridecolby's Avatar
It's is pretty funny. While procrastinating about going to work this morning I was thinking the same thing, but a 30" door to storage under the stairs in my basement. I want a shelving unit that will hold DVD, Bluray, games and CDs. I went to HD this morning again while procrastinating but didn't see anything that made sense.
I did consider casters, and I think a shelf that is approximately 30"x80"ish will probably need them with all the media that will be stored in it.
Gamer Tag/PSN dubstylesmkIII
ridecolby is offline
post #5 of 10 Old 01-16-2009, 06:46 AM
BeerParty's Avatar
If you don't want to use casters but want to make the shelves functional, you will need some pretty strong hinges. You will either need piano hinges (you can get these in a 6' length) or some barn door hinges.
Chris
--Despair, Inc. "Regret"
My AviaTrix TM Build
BeerParty is offline
post #6 of 10 Old 01-16-2009, 08:55 AM
Quoted: 2831 Post(s)
Liked: 2386
post #7 of 10 Old 01-16-2009, 10:33 AM
ridecolby's Avatar
Mine needs to open out but that is really cool, and really well executed.
post #8 of 10 Old 01-16-2009, 03:54 PM - Thread Starter
kezug's Avatar
other pics in this thread from last week
http://www.avsforum.com/avs-vb/showt...highlight=room
Big, you ALWAYS come through. I swear, I dont know how you do it.
I will need mine to swing forward but it sure seems like this is exactly what I am looking for.
kezug is offline
post #9 of 10 Old 01-16-2009, 08:46 PM
zepplin's Avatar
Another option I have been looking at is with a company called "Woodfold" (can't post links yet, but you should be able to google it). They have a section on custom bookcase doors.
Although seeing the solution above may change my mind! Very nice.
zepplin is offline
post #10 of 10 Old 02-02-2009, 11:30 AM
CTsan's Avatar
I don't know if this helps but this is what I did. I'm not done yet but this is what I have so far.
They're Soss hidden hinges and they hold a ton of weight.
CTsan is offline
