The Valley Theater & Game Room (The Return of the Build Thread) - Page 8 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #211 of 224 Old 07-07-2012, 12:24 PM - Thread Starter
jroyv's Avatar
Quoted: 18 Post(s)
Liked: 27
Originally Posted by cuzed2 View Post
Now that you are finished don't become a stranger to these parts... smile.gif
I've already started planning theater 2.o that will take me at least two years. biggrin.gif
Joe V
Time > Money
V-T Theater 2.0
V-T Theater 1.0
jroyv is offline
post #212 of 224 Old 08-13-2012, 10:33 AM - Thread Starter
jroyv's Avatar
Quoted: 18 Post(s)
Liked: 27
I promised some more pictures of the DVD Case Doors along with some detail of how I build them.
Please note if I was truly trying to conceal a room I wouldn't post pics of it online. These are purely novelty and to make use of the space a door would occupy... Hence no elaborate locking mechanism.
The #1 thing to remember when creating inward opening doors of this sort is you have to allow for the depth (b) of the door and make your opening that much wider.
If you remember your geometry the the distance (c) from the rear hinge (A) to the front face on the latch side (B) is longer than the face of your cabinet (a). You use your trim to cover this gap.
Solve for c (little c)
Except for the back and trim all of the lumber for the DVD Case Doors are select pine dimensional lumber. 3/4" stain grade pine plywood for the back and what ever trim floats your boat for the back.
In my case 1x8s making shelves that are 71/4" deep & 3/4" thick.
Each shelf is supported by an 8" cut piece of 1x8 and the sides are full length pieces. The "kick plate at the bpttom can be what ever is left over from your total height or you can adjust the height of your bottom shelf. I like the look of the kick plate though.
I'll throw up a diagram of the pieces when I get a chance.
I have an additional piece of 1x4 around the back to trim out the plywood and to give myself a an other 3/4" of screw depth for the hinges.
These are the hinges I used. 5 for the big case 4 for the small one. (Note the link is for a "3 -pack".)
Global CP4545BB-26D-M Commercial Grade, Full Mortise Ball Bearing Hinge 3-Pack, Brushed Chrome
BasementHT5 likes this.
Joe V
Time > Money
V-T Theater 2.0
V-T Theater 1.0
jroyv is offline
post #213 of 224 Old 08-13-2012, 11:25 AM
lightsareout's Avatar
Nice build, where did you find that glass door fridge?
lightsareout is offline
post #214 of 224 Old 08-13-2012, 01:47 PM - Thread Starter
jroyv's Avatar
Quoted: 18 Post(s)
Liked: 27
Fridge came from home depot... Cheapest one I found approved as a "built-in" unit.
Joe V
Time > Money
V-T Theater 2.0
V-T Theater 1.0
jroyv is offline
post #215 of 224 Old 08-13-2012, 08:31 PM - Thread Starter
jroyv's Avatar
Quoted: 18 Post(s)
Liked: 27
Additional DVD Case door info.
Hope this makes sense. Width and Height can vary to fit your need.
For mine each shelve for my DVD case doors is 8" high to accommodate over-sized DVD boxes . There is a single ripped 1x8 for the "kick plate" at the bottom to make up remaining distance. Both my doors are standard "door height" so I could match trim with the door to the bathroom. The Plywood on the back forces the structure to stay rigid and square. Every join is nailed and glued. The entire door is very sturdy with absolutely no sag despite catching the kids climbing on them a few times.
Joe V
Time > Money
V-T Theater 2.0
V-T Theater 1.0
jroyv is offline
post #216 of 224 Old 08-18-2012, 03:42 PM
mn_hokie's Avatar
Liked: 27
Quick question. What are the dimensions of your 3rd row bar? I'm planning for 8 feet for 4 armless chairs, so I'm curious what you used for 3.
mn_hokie is offline
post #217 of 224 Old 08-18-2012, 06:36 PM - Thread Starter
jroyv's Avatar
Quoted: 18 Post(s)
Liked: 27
The bar is 8'4" wide by 20" deep. But I only have 7'3" between the bar "supports" which are basically 2x4 half walls. Because of that 4 stools at my bar would be really tight.
If you are using more space efficient supports for your bar you might be OK.
The arched "window" above the bar is 7' wide.
Joe V
Time > Money
V-T Theater 2.0
V-T Theater 1.0
jroyv is offline
post #218 of 224 Old 08-18-2012, 06:40 PM - Thread Starter
jroyv's Avatar
Quoted: 18 Post(s)
Liked: 27
I've started a thread for the planning stage of my new theater/house build here:
http://www.avsforum.com/t/1425070/vt-theater-game-lounge-and-home-automation-the-prequel
Joe V
Time > Money
V-T Theater 2.0
V-T Theater 1.0
jroyv is offline
post #219 of 224 Old 08-26-2012, 09:25 AM
bigb76180's Avatar
Do you have more pics of your equipment rack build? I love it and want to see if I can reproduce it.
bigb76180 is offline
post #220 of 224 Old 08-27-2012, 07:05 AM - Thread Starter
jroyv's Avatar
Quoted: 18 Post(s)
Liked: 27
This is all I have currently in my photobucket account. I'll try to get some detail and dimensions for you.
The construction is pretty simple. The body of it is just finished drywall painted to match the theater. The shelves are all stain grade select pine.
A small support strip is glued and nailed to each side wall. The shelve is glued and nailed to each pair of supports. And a 4th piece just wide enough to cover the front edge of the shelve and the support is nailed and glued to the front. Other than the drawer at the bottom and some trim at the bottom and back that is all there is to it.
I'll get you more latter.
Joe V
Time > Money
V-T Theater 2.0
V-T Theater 1.0
jroyv is offline
post #221 of 224 Old 08-27-2012, 07:41 PM
bigb76180's Avatar
Thanks man !
post #222 of 224 Old 08-28-2012, 09:11 AM - Thread Starter
jroyv's Avatar
Quoted: 18 Post(s)
Liked: 27
No problem. Here is the rest:
Entire opening is 69" tall by 19" wide by 16.5" deep. Space between shelves is 13.5". The trim piece on each shelve is 1.5" wide. All the lumber used is 1x dimensional lumber so is 3/4" thick.
Drawer takes up the remaining space at ~8" tall.
Front
Support from the back.
Rear view... Damn my cable management use to be good back there.... will have to clean it up
Drawer Inside
Drawer Rails
Support from the front.
Joe V
Time > Money
V-T Theater 2.0
V-T Theater 1.0
jroyv is offline
post #223 of 224 Old 05-01-2014, 10:49 AM
DALEBOB34's Avatar
Was wondering what did you use to make all your arches with? The room looks great!
DALEBOB34 is offline
post #224 of 224 Old 06-11-2015, 11:35 AM - Thread Starter
jroyv's Avatar
Quoted: 18 Post(s)
Liked: 27
Linking over to theater 2.0 currently under construction in our new home to be.
For those few people that followed my old build:
V-T HT 2.0: Dedicated Room within a Room within a Concrete Home
Joe V
Time > Money
V-T Theater 2.0
V-T Theater 1.0
jroyv is offline
