The April Fools Flood Procrasto-Budget Build - AVS Forum | Home Theater Discussions And Reviews
post #1 of 177 Old 08-07-2009, 03:55 PM - Thread Starter
gitSehT's Avatar
Deleted
gitSehT is offline
post #2 of 177 Old 08-07-2009, 05:09 PM
Quoted: 3258 Post(s)
Liked: 2744
Did you do anything about the exterior drainage or are you hoping that sealing all the cracks you can find will keep future floods out of the basement?
post #3 of 177 Old 08-07-2009, 05:33 PM - Thread Starter
gitSehT's Avatar
Deleted
gitSehT is offline
post #4 of 177 Old 08-07-2009, 05:41 PM
hanesian's Avatar
Quoted: 36 Post(s)
Liked: 83
Originally Posted by gitSehT View Post
My goal is to be setup by the time GT5 is released, so I have anywhere from 4 months to 4 years to finish
Tough luck with the flooding. Glad to see you bouncing back and making the best of it with a basement remodel. I had a similar unexpected start to my build, although mine was mold related. Hope you've had some landscaping review to minimize the chances of anything like that happening again. I know the odds are against it, but you really don't want to put in all the time and effort and money only to see another 100 year event happening in a few years!
BTW, nice woodpile - had 'er long? I kinda have a thing for woodpiles.
It's complicated.
The Un-Theater Un-Build
hanesian is offline
post #5 of 177 Old 08-07-2009, 10:03 PM - Thread Starter
gitSehT's Avatar
Deleted
gitSehT is offline
post #6 of 177 Old 08-07-2009, 10:11 PM - Thread Starter
gitSehT's Avatar
Deleted - Selling House
gitSehT is offline
post #7 of 177 Old 08-08-2009, 08:22 PM - Thread Starter
gitSehT's Avatar
gitSehT is offline
post #8 of 177 Old 08-09-2009, 08:13 PM - Thread Starter
gitSehT's Avatar
gitSehT is offline
post #9 of 177 Old 08-10-2009, 08:54 AM
jpdeuce's Avatar
I kept braking tapcons so I took them back and got shorter ones thanks to the tips in a thread I can not seem to find right now.
That would be mine. Glad it helped you out. I hope it saved you the few days it took me to figure that whole deal out.
Project is looking good so far. Do you have a plan for all your equipment? If I had open walls, I sure would be running conduit or flex vacuum pipe or something in certain locations for running wire.
The above is merely one person's opinion and is probably worth as much as you paid for it.
My Basement HT/Family Hang Out
jpdeuce is offline
post #10 of 177 Old 08-10-2009, 09:43 AM - Thread Starter
gitSehT's Avatar
gitSehT is offline
post #11 of 177 Old 08-10-2009, 10:03 AM
bhuttman's Avatar
How did you fare with that storm last night? Hopefully you avoided any further flooding...
B
bhuttman is offline
post #12 of 177 Old 08-10-2009, 11:11 AM - Thread Starter
gitSehT's Avatar
gitSehT is offline
post #13 of 177 Old 08-10-2009, 11:12 AM - Thread Starter
gitSehT's Avatar
gitSehT is offline
post #14 of 177 Old 08-10-2009, 05:22 PM
hmmm5's Avatar
enjoy the build. can't quite tell from the pics, are those floor plates PT?
hmmm5 is offline
post #15 of 177 Old 08-10-2009, 05:45 PM
bhuttman's Avatar
What flooring are you doing? Are you going to put OSB on the Platon, and what thickness are you thinking about?
bhuttman is offline
post #16 of 177 Old 08-10-2009, 05:59 PM - Thread Starter
gitSehT's Avatar
gitSehT is offline
post #17 of 177 Old 08-11-2009, 07:50 AM
jpdeuce's Avatar
I am planning to run pipe (pvc pipe we run at work hopefully) down both sides of the room through the soffits I will be building. I am going to put "T" intersection parallel to where the projector is going to be so I can branch off hdmi etc and then pull speaker wire etc to the back or front of the room. I was actually planning on this before I found this site, the info I read here only solidified it. I am going to try to put up a floor plan soon to explain better.
As a suggestion, just try to avoid 90 degree intersections. It will make it easier on you pulling wire down the road if there is some bend in it.
jpdeuce is offline
post #18 of 177 Old 08-11-2009, 08:45 AM - Thread Starter
gitSehT's Avatar
gitSehT is offline
post #19 of 177 Old 08-11-2009, 10:27 AM - Thread Starter
gitSehT's Avatar
gitSehT is offline
post #20 of 177 Old 08-11-2009, 12:32 PM
bhuttman's Avatar
BhUTTMAN (all i see when I look at your name is butt man)
Pretty common - I've been called much worse.
bhuttman is offline
post #21 of 177 Old 08-11-2009, 12:35 PM
In2Photos's Avatar
I'm a butt man, too.
Was that too much information?
Mike
In2Photos is offline
post #22 of 177 Old 08-11-2009, 02:37 PM - Thread Starter
gitSehT's Avatar
gitSehT is offline
post #23 of 177 Old 08-12-2009, 04:56 AM
joetoronto's Avatar
Is there any way you can make the width of the room a bit wider, gitSehT?
I ask because the theatre room in my main house in Vaughan is about the same width as the one your planning, and I find it's a bit narrow for seating.
I learned my lesson building that one when I built this one, in Wasaga Beach.
Just say no to cable.
joetoronto is offline
post #24 of 177 Old 08-12-2009, 08:06 AM - Thread Starter
gitSehT's Avatar
gitSehT is offline
post #25 of 177 Old 08-12-2009, 08:13 AM
joetoronto's Avatar
I want to have a bathroom down there and all the plumbing is under the beam (indicated in Blue on the layout). I want to avoid moving this due to the expense and general pain in the ass factor. I was considering going with a "L" Sectional on the out side wall and a recliner on the bathroom side.
If anyone can help with the layout it would be appreciated!
Ah, lol, how ironic. It only became an issue for me when I changed the seating from an "L" shaped sectional to row seating.
post #26 of 177 Old 08-19-2009, 09:15 PM - Thread Starter
gitSehT's Avatar
gitSehT is offline
post #27 of 177 Old 08-22-2009, 08:50 PM - Thread Starter
gitSehT's Avatar
gitSehT is offline
post #28 of 177 Old 08-31-2009, 10:04 AM - Thread Starter
gitSehT's Avatar
Went away on vacation last week, got a little framing done before and after the trip to Clevland and Cedar Point.
Did I mention that I procrastonate? I will get some pics up soon.
gitSehT is offline
post #29 of 177 Old 08-31-2009, 12:32 PM
hanesian's Avatar
Quoted: 36 Post(s)
Liked: 83
No. But I imagine you meant to and were planning on doing it just as soon as you got around to it.
hanesian is offline
post #30 of 177 Old 08-31-2009, 02:13 PM
Dradius's Avatar
Looking good so far. Floods suck. I just went through it so I know how you feel. How do you like that B&D hammer drill? I need to get one. Also good info about the tapcons Jpdeuce
Dradius is offline
