How high (or low) to hang projector - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 09-28-2009, 07:01 PM - Thread Starter
mvivanco's Avatar
I am a little confused with the setup position for the Panasonic PT-AE3000U. My media room will be about 11' 7" by 18", the ceiling is 8' 6" and the screen will be 110". The projection distance is OK for me as well as the width from the right edge of the screen to the center of lens. However, the height from the edge of the screen to the center of the lens (H) says the should be between 2' and 2' 6". So if the top of the screen was 7' 6" from the floor, then the projector would have to hang down to 5' 6" to 5'? Am I understanding that correctly? I cannot believe I am. I have never seen anyone's projector hang down that low. What am I not understanding?
mvivanco is offline
post #2 of 8 Old 09-28-2009, 07:18 PM
Gadget_girl's Avatar
I can't answer whether or not you are interpreting your numbers correctly, but my understanding of the panasonic projectors, indicates that at 5' to 6' you might want to consider setting it on top of a bookshelf at the back of the room rather than suspending it from the ceiling. I understand this is fairly common. My Panasonic AE900 sits about 5' from the floor (top of the screen is about 7' 8") in a shelving unit that also houses my DVD player and satellite reciever.
Gadget_girl is offline
post #3 of 8 Old 09-28-2009, 08:43 PM
Quoted: 3901 Post(s)
Liked: 3335
I just stared at the table and diagram for 15 minutes. Something is wrong. I would give a call to where you plan on buying the projector.
If you go to Panasonic.com and look up the manual for this projector you will find different instructions which will tell you you can pretty much put it close to the ceiling. Certainly above the top edge of the screen.
post #4 of 8 Old 09-29-2009, 09:31 AM
JOHNnDENVER's Avatar
With lens shift as is available on this projector? I would not suspend it, I'd just shelf it high to the cieling.
I have not mounted a projector using amount since the advent of lens shift in LCD projectors. Years now.
JOHNnDENVER is offline
post #5 of 8 Old 09-29-2009, 10:11 AM
Suntan's Avatar
Quoted: 78 Post(s)
Liked: 113
I have the 3000u hanging from my ceiling so maybe I can help. Yes, that diagram is confusing and incorrect.
First, are you planning to use the automatic 16/9 <-> Scope zoom feature?
If yes, then the most you can offset the PJ is to the edge of the screen. By that i mean, if you plan to hang the PJ, and the top edge of your screen is 7' off the ground, the lens of the PJ has to be at about 7' or lower to make use of the auto zoom feature. (I will clarify, you can have more of an offset and still technically "use" the auto-zoom feature, it is just that with more offset than the top of the screen, when you zoom out to the scope setting the large offset will cause the image to shift too far down and will result in the scope image being shown on the lower part of your screen and the wall below it.)
If you do not plan to use auto zoom, you can have even more offset than just to the top of the screen. I believe you can have it as much as half of a screen height above the top edge of the screen (so the lens of the PJ would be a full screen height above the center point of the screen on your wall) but don't quote me as I'm not positive. If you trawl the huge 3000u thread I believe they covered this a few times.
Lastly, if I haven't made it confusing enough, as I said above you *can* still technically use the auto-zoom feature even if you have the PJ lens mounted above the top edge of your screen. It is just that every time you zoom in and out, you will need to manually dail in the lens offset to get the picture to raise/lower back in place to fill your screen (which kind of eliminates the "automatic" part, but adjusting vertical lens offset is still much easier and quicker than manually adjusting zoom or focus imo. So the auto-zoom feature would still have some merit.)
-Suntan
Suntan is offline
post #6 of 8 Old 09-29-2009, 11:57 AM - Thread Starter
mvivanco's Avatar
John and Suntan, I can easily build a shelf to hold the projector on the wall. That isn't an issue. More of the issue was, how high do I hang/build it. From what Suntan is saying, I should be able to put it most anywhere as long as its at or below the top edge of the screen and still be able to use the auto zoom on it.
mvivanco is offline
post #7 of 8 Old 09-29-2009, 12:06 PM
Suntan's Avatar
Quoted: 78 Post(s)
Liked: 113
Yup, if you can keep the lens within the boundary of the top and bottom of the screen, you should be good to go for auto-zoom.
Do keep in mind though, in case you weren't planning to mount the PJ directly in line with the screen, the PJ needs to be centered on the screen (no right/left lens shift) to auto-zoom too. If it is shifted left/right, then the picture will slide off the side of your screen when you zoom in (you can always manually re-adjust it each time you zoom, the same way I described when the PJ lens is hanging above the top of the screen.)
-Suntan
Suntan is offline
post #8 of 8 Old 09-29-2009, 12:27 PM - Thread Starter
mvivanco's Avatar
John, do you literally just shelf build? If so, how long do you make the shelf so there is enough air flowing behind the projector?
mvivanco is offline
