Video Essentials aggravation - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 12-11-1999, 07:06 PM - Thread Starter
Kirk's Avatar
Has anyone else had a difficult time navigating around the video essentials disc?
I simply cannot skip to the chapters and test patterns I want using my Sony DVP550 remote. When I calibrated the projector and speakers for my theater it took forever because I basically had to start from the beginning of the disc and let it play through. Every time I tried to skip forward or backward to a chapter, I either blew past the test I wanted or wound up several chapters in advance of the one I actually wanted.
I've promised to take my SPL meter and the disc over to my buddy's place and calibrate his system, but I'm dreading having to use Essentials on his Sony player. Somebody save me from ripping my hair out.
Kirk
Kirk is offline
post #2 of 8 Old 12-11-1999, 07:38 PM
Brian B's Avatar
Quoted: 240 Post(s)
Liked: 106
Don't feel bad. I went to a training with Joe Kane, and HE was having trouble navigating it too!! The best advice I can give you is to buy the Widescreen Review large issue (on video technologies, etc) which has a full listing of the tests, and how to get to them directly, and what they are used for.
Brian
Brian B is offline
post #3 of 8 Old 12-12-1999, 04:31 PM
Guy Kuo's Avatar
Consider supplanting the VE disc with our AVIA disc. AVIA has more updated and higher accuracy test patterns and navigation is via on screen menus. It's much more like surfing the web. Just point and click to get to what you want. I've always found the chapter/title list of navigation like a program where you would have a full keyboard in front of you and still have to...
Press 7 for Yes.
Press 5 for No.
Guy Kuo
www.ovationsw.com
Ovation Software, the Home of AVIA DVD
Guy Kuo
Guy Kuo is offline
post #4 of 8 Old 12-13-1999, 09:15 PM
Jerry Arseneau's Avatar
I think the odd key to navigating VE is that you need to use the TITLE selection on your DVD player to get to specific areas of the VE disc. When you play the disc from the start you move progressively from each TITLE section to the next. Once you are "in" a TITLE, the menu allows you to choose a specific CHAPTER but won't indicate TITLE information. Most discs just require CHAPTER navigation so we are not accustomed to this kind of navigation.
Jerry
Jerry
Jerry Arseneau is offline
post #5 of 8 Old 12-23-1999, 07:30 AM
The VE website lists the direct access (Title:Chapter) locations for various tests.
You can check it out at.. http://www.videoessentials.com/dvd_index.htm
Jerry
Jerry
post #6 of 8 Old 12-30-1999, 11:16 PM
rsnodgrass's Avatar
I second the vote on the Avia Guide to Home Theater DVD, it's excellent. I haven't tried the VE DVD yet but the reviews I've read have all touted that the Avia DVD is several steps above.
I picked my copy up at Amazon.com for $34.99, a steal! Here is the URL:
http://www.amazon.com/exec/obidos/AS...snodgrassautA/
rsnodgrass is offline
post #7 of 8 Old 12-31-1999, 10:22 AM
Phil Olson's Avatar
I'd third the vote on Avia!
Phil Olson is offline
post #8 of 8 Old 01-10-2000, 10:08 AM
Mr Bob's Avatar
Quoted: 172 Post(s)
Liked: 105
I have 2 gripes re. VE. One is that the pluge pattern is too easy to interpret subjectively, causing far too many viewers to come out with too dark a picture after following VE's verbal directions to the letter. You have to use your own eye to settle on the ideal Brightness/Black Level setting, determined by how much dark detail fill is enough, and how much is too much. I've all but given up on the pluge pattern for this purpose, aside from looking at it AFTER I have attained the ideal Br./Bl. L. setting with various light and dark scenes, just to see how the pattern is SUPPOSED to look.
The other thing is that every time I put up the 4x3 crosshatch grid on a 4x3 RPTV, I have to space out the width a bit to get a true circle out of it. With the width brackets ID in spacing to the height brackets--right next to the edges of the screen, ID at all points--the circle is oval-shaped, longer vertically.
So I make the pic wider, as having a correct circle is more important than having the side to side brackets be ID in spacing to the top and bottom brackets.
But I really don't know which is correct. Maybe I should be going with the side brackets instead. Maybe the circle is what is off.
All I know is that they do not match up correctly with 4x3 screens out there in the field.
Mr Bob
Robert P. Jones
Image Perfection
SF Bay Area, Ca. USA
650-595-3797
bob@imageperfection.com www.imageperfection.com
[This message has been edited by Mr Bob (edited January 10, 2000).]
Robert Jones
Image Perfection
510-278-4247
650-333-4808 cell
bob at imageperfection dot com
www.projectiontvtroubleshootingadvice.com
YouTube channel: mrbobbigscreen
Mr Bob is offline
Closed Thread General Home Theater & Media/Game Rooms
