New build--- theater/bar/kitchen - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 69 Old 04-28-2010, 08:18 PM - Thread Starter
jbrocious's Avatar
Originally Posted by mekkerl View Post
Did you use any kind of vapor barrier behind the walls? Or, just paint the cinder blocks and put up your framing with r-13 faced insulation?
3 coats of drylok, then a 6mil vapor barrier--- also pressure treated 2x4s for the sill plates.
jbrocious is offline
post #62 of 69 Old 04-29-2010, 07:52 PM - Thread Starter
jbrocious's Avatar
Update pics!
Still have trim work, staining, painting, and to pick up the apartment fridge, but I'm getting close. Ignore the mess on the back bar!
I tried to take the pictures to show the perspective from the bar area.
post #63 of 69 Old 04-30-2010, 06:09 AM
beach31684's Avatar
Looks great. I love the idea of using the drip tray as an accent peice for the bar. I have not seen that before.
This bar is definitely one of my favorites, Great job!
I had a thought once... but it got lonely and went away.
The Beach House Bar Build
http://www.avsforum.com/avs-vb/showthread.php?t=1240927
beach31684 is offline
post #64 of 69 Old 04-30-2010, 08:53 AM
cuzed2's Avatar
Quoted: 187 Post(s)
Liked: 237
Beautiful - and not one, but TWO tappers
Awesome!
Cuzed2
CuznEddy Cinema
cuzed2 is offline
post #65 of 69 Old 05-02-2010, 06:28 AM - Thread Starter
jbrocious's Avatar
Thanks! I figured they would be functional as much as they would give it some 'real bar' detail.
Awesome!
Yes! Ordered the kegs for tomorrow! I was planning to put Newcastle on tap, but at $170 for 50 liters, I think it would go flat before we'd drink it all. So, we got the crowd favorites Coors light and Yuengling.
post #66 of 69 Old 07-16-2012, 12:25 PM
oldstylebob's Avatar
I know this is an old thread, but do by chance have the dimensions of your bar? Im looking to build one similar, thanks!
oldstylebob is offline
post #67 of 69 Old 01-21-2013, 04:24 PM
Majerus_12's Avatar
Would anyone know where to find the Rock that was used in this bar? I checked home depot and lowes and cannot find anything that looks like it..
Majerus_12 is offline
post #68 of 69 Old 01-23-2013, 05:12 PM - Thread Starter
jbrocious's Avatar
Wow its fun seeing this old post resurrected! The stone is Owens corning pro-fit ledge stone. Its a cultured stone veneer. If you happen to be near Pittsburgh I still have 2 boxes left over. You should be able to order it from most building supply companies. I got it from a local place. Price is pretty standard everywhere I called. Hope this helps.
post #69 of 69 Old 01-23-2013, 05:55 PM
Majerus_12's Avatar
Great! Ill get to googling smile.gif .. I was presently surprised to get a response. Good looking bar btw .
