Can I connect 3 HDMI cables together with 2 couplers? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Aberk
post #1 of 12 Old 01-17-2010, 11:08 AM - Thread Starter
broadwayblue's Avatar
Quoted: 28 Post(s)
Anyone ever do this? Would using 2 HDMI couplers allow me to successfully connect 3 relatively short (6', 15', 6') HDMI cables together? I never tried this before and it would be the easiest solution for my current install. Thoughts?
broadwayblue is offline
post #2 of 12 Old 01-17-2010, 12:00 PM
Johnsteph10's Avatar
Quoted: 31 Post(s)
Liked: 24
That's a lot of connections for HDMI which is widely known to be finicky at best. I would test it out first....the best practice, though, would be a single cable of appropriate length.
John
Johnsteph10 is offline
post #3 of 12 Old 01-17-2010, 04:43 PM
Colm's Avatar
Liked: 94
It is alway best to have as few connections as possible. But this is no worse than having a HDMI cable in the wall and cables from the wall to the display and the source. A lot of people do that with even longer runs.
Colm is offline
post #4 of 12 Old 01-18-2010, 09:20 AM - Thread Starter
Quoted: 28 Post(s)
Thanks guys. We miscalculated the length of the middle run and at this point it would be quite a hassle to remove it and add a slightly longer cable. I'm hoping that since it is a relatively short run (<30') it will still work ok.
post #5 of 12 Old 01-18-2010, 09:27 AM
localnet's Avatar
You had better test it first first... To be safe, go find some Cat5e cable and run two of those if you can along with your HDMI. That will at least allow you to run HDMI baluns. Or run something to pull a new one piece HDMI cable through in case you have a failure.
And you need two Cat5e cables to get a full HDMI signal over baluns.
localnet is offline
post #6 of 12 Old 01-18-2010, 09:08 PM
BioSehnsucht's Avatar
I was for awhile running 1080i from my Tivo, and 1080p from Xbox360 and PC, to my bedroom from the living room (in my last apt). From the 4x2 monoprice HDMI matrix switch in the living room, the output to the bedroom went through as 12' cable, faceplate w/ cable saver, 15' cable, another faceplate, then 30' cable and then plugged into a 2 port HDMI switch (which I used solely because it output any DD/DTS/2.0 PCM over toslink to my old receiver in the bedroom). All cables / wall plates and matrix switch from monoprice, the small switch in the bedroom was from ebay.
I did have problems before putting in a switch at the end of that chain going direct to the Moome card in my old NEC ISS, but using an old 5 port 1.1 switch from monoprice (prior to the one w/ the SPDIF out) fixed that.
So, you can actually go pretty far and with some crazy combinations but it will depend on your gear. If it doesn't work, throw in some switches that have equalizers and it may save the day.
(I'm not running this insane setup at this point and have nothing in the bedroom yet, I recently moved to a house and haven't yet wired everything up but will be going the structured wiring route)
BioSehnsucht is offline
post #7 of 12 Old 08-13-2013, 08:49 PM - Thread Starter
Quoted: 28 Post(s)
Have any of you successfully used HDMI wall plates like this:
http://www.monoprice.com/Product/?c_id=104&cp_id=10425&cs_id=1042501&p_id=7330&seq=1&format=1#largeimage
Would make for a clean install, but I'm concerned about potential signal issues going from a cable box HDMI to wall plate then HDMI behind the wall to 2nd wall plate to HDMI to TV. Bad idea?
post #8 of 12 Old 02-01-2017, 08:37 PM
Liked: 0
Smile 2 couplers = bad idea
I tried this now and it's not working. I have 3 10-meter HDMI and 2 couplers. If I connect 2 HDMI cables with one coupler, it's working. But if I add one more HDMI + another coupler, it's not working. I have tested both couplers and the 3 HDMI cables. It's all working as long as you only use one coupler. 2 Couplers seems to be not working. It doesn't transmit any signal at all.
Jehzeel Laurente is offline
post #9 of 12 Old 02-02-2017, 09:36 AM
Aberk's Avatar
Quoted: 212 Post(s)
Liked: 151
I think where you went wrong is not with 2 couplers. Its with a ~100' HDMI cable that is made up using 2 couplers.
AVfile likes this.
Aberk is offline
post #10 of 12 Old 02-03-2017, 09:06 AM
drunkpenguin's Avatar
Quoted: 1349 Post(s)
Liked: 1367
http://www.monoprice.com/Product/?c_...t=1#largeimage
I'm about to do this this weekend. Hopefully it works. I'll try to let you know.
Just 'cause you're right doesn't mean I'm wrong
drunkpenguin is offline
post #11 of 12 Old 02-05-2017, 08:53 AM
AVfile's Avatar
Quoted: 282 Post(s)
Liked: 138
Is it still true than anything over 25' cannot be HIGH SPEED certified?
My current 35' Planetwaves cable is giving me trouble so I'm looking to replace with a 10m Ultralink Integrator. I can't find any website for Ultralink now
"This one goes to eleven." Martin Logan Descent-i subwoofer
AVfile is online now
post #12 of 12 Old 02-05-2017, 08:58 AM
Liked: 1367
I just ran a 35' hdmi cable through the ceiling with a wall outlet on both ends. There are 2 more 4' cables on each end. The wall outlets add another connection are so I basically have the equivalent of 5 cables plugged into each other. Zero issues, works like a champ! I'm not running 4k yet if that makes a difference, but it's working great for me over here.
