Home Theater Connectivity/Schematic Design Tools? - AVS Forum | Home Theater Discussions And Reviews
Old 03-23-2010, 10:39 PM - Thread Starter
JoeG44's Avatar
Are there any software packages out there that can capture an existing Home Theater design or design a new one from scratch? My Home Theater design is captured with a combination of paper and various Word/Excel files.
I'd like to capture all the wiring connects(port assignments, wire type), source/sink items(ie .AVR, DVD players, TV, media streamers etc.)?
Thx in advance.
JoeG44 is offline
Old 03-24-2010, 07:57 PM
RVelle's Avatar
I did mine in Visio (Powerpoint could work, just would take a bit longer), it took some time, but worth its weight in gold because I couldnt easily trace cables back once they were routed. I just boxed out each component, and made a key to identify each type of cable:
RVelle is offline
Old 03-25-2010, 05:28 AM
Flips's Avatar
+1 for visio.. if you are looking for something open source you could tray Dia:
http://live.gnome.org/Dia
flips
Flips is offline
Old 03-25-2010, 05:57 AM
elmalloc's Avatar
Quoted: 27 Post(s)
Liked: 44
Google sketchup.
Current Projects:
ON HOLD - Building Home Gym.
elmalloc is online now
Old 03-27-2010, 01:25 AM
mystic_sniper28's Avatar
not sure on product suites..
though my suggestion for setup:
avr 1 preamped into avr 2
alternately
2 of everything using avr's with networking...
not sure of inside to outside is though i would try to keep cables to a min where possible...
also look at iptv distribution...
mystic_sniper28 is offline
Old 03-28-2010, 09:52 PM - Thread Starter
JoeG44's Avatar
I used Powerpoint in the end ....
JoeG44 is offline
