Stand to elevate my TV 6-9 inches? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-16-2010, 10:06 AM - Thread Starter
dconner's Avatar
I just got a Sony KDL-52EX700 HDTV:
And it's great, but I have the same nagging problem I had with the old TV. This TV sits on top of a cabinet containing all my various components. And the cabinet's fine too, but I'd love to raise my TV slightly, to make it about 6, 9 inches, something like that, higher?
Are there any stands made for this sort of thing? I suppose I could just try to scrounge a sturdy box or crate or something, but it'd be nice to have something that looks fairly decent too.
Any ideas for this sort of thing?
dconner is offline
post #2 of 5 Old 06-16-2010, 11:33 AM
Suntan's Avatar
Quoted: 75 Post(s)
Liked: 107
You're not going to find much that doesn't ultimately say "I'm a lump set under the TV to raise it up."
another option would be to put something under each leg of your table to lift the TV & table up 6 to 9 inches. depending on the type of table and the layout, that may look less obvious.
-Suntan
Suntan is offline
post #3 of 5 Old 06-16-2010, 02:27 PM
The Incident's Avatar
You could always do something like this:
http://www.standsandmounts.com/woodt...lacksatin.aspx
- Just doing my part to stimulate the economy!
Tipping Rock Theater
The Incident is offline
post #4 of 5 Old 06-16-2010, 03:03 PM - Thread Starter
dconner's Avatar
Thanks, that's the kind of thing I was thinking about. Seems like something there might do the trick, depending on the size and weight they can support.
dconner is offline
post #5 of 5 Old 06-17-2010, 02:16 AM
They also have items like soundbar risers that could work if you are trying to elevate your TV above a soundbar:
http://www.standsandmounts.com/woodt...dbarriser.aspx
I've ordered from these guys on a couple of occasions and have been very happy with them. Prices are good, delivery is quick and there always seems to be an additional discount.
