Need to split an Ethernet port. How can I do it? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 08-28-2010, 10:23 AM - Thread Starter
jcamber's Avatar
I have an ethernet port on one of my wall plates that is currently in use by my bluray player (to access my home network, netflix, etc). My plan is to install a wall plate for my new LED TV like this one
http://www.hometech.com/hts/products...-sc300prb.html
I'll be adding the usual keystone inserts, HDMI, Component, toslink, etc and want to have ANOTHER ethernet to connect the TV to the internet as well (since the model I'm getting can access netflix, pandora, etc). Question is, is there a way I can split the ethernet I currently have and get to keep that port PLUS the one on the wall plate for the TV? how can I accomplish this??
Here's a picture of my current plate (with the ethernet I want to "split")
jcamber is offline
post #2 of 13 Old 08-28-2010, 10:49 AM
colour's Avatar
Quoted: 13 Post(s)
Liked: 38
You can buy splitters but I'd use a switch rather than split the cable. This is what I use and it works great: http://www.newegg.com/Product/Produc...-083-_-Product
colour is offline
post #3 of 13 Old 08-28-2010, 11:33 AM
sylentmode's Avatar
vote # 2 for a switch.
you can get them for really cheap
http://www.newegg.com/Product/Produc...82E16833122005
that one is $10 after a rebate (or just $20 normally) with free shipping.
Its only 10/100, so you may want to look around for something with gigabit if you really want that.
sylentmode is offline
post #4 of 13 Old 08-28-2010, 12:24 PM
DrPhD's Avatar
#3 for a switch.
A lot less hassle and who knows you may need another ethernet port in the future.
DrPhD is offline
post #5 of 13 Old 08-28-2010, 12:38 PM - Thread Starter
jcamber's Avatar
Thanks all. I forgot to mention that the only problem I see with the switch is that they're all powered. So if I wanted to hide it inside the wall I can't figure out where I would plug the switch from inside the wall... any ideas?
thanks again!
jcamber is offline
post #6 of 13 Old 08-28-2010, 02:26 PM
Stereodude's Avatar
Quoted: 3093 Post(s)
Liked: 2239
A switch has to be powered.
I've also never seen a switch rated for in wall use. You're not going to be able to put it in the wall.
Stereodude is offline
post #7 of 13 Old 08-28-2010, 03:18 PM
DrPhD's Avatar
Oh you're worried about clutter? Hmmm, a switch does take up a bit of space and I didn't think it would be a problem to power it. I have to be honest, I have no idea how you could do that, especially with multiple IP-addresses.
I do think HP sells those "Intellijack" switches, which might be more to your liking.
http://h40060.www4.hp.com/procurve/p...l&tab=2#A5810G
At the bottom of the page.
DrPhD is offline
post #8 of 13 Old 08-28-2010, 03:41 PM
colour's Avatar
Quoted: 13 Post(s)
Liked: 38
I assume your TV hangs on the wall? Is there not an outlet behind it? If so I would figure out a way to place a switch behind the TV, plug into the same outlet and just run the ethernet cable.
I wouldn't split the ethernet no matter what.
colour is offline
post #9 of 13 Old 08-28-2010, 08:04 PM
micagreenmachine's Avatar
I believe you can split it, but you'll be limited to 100Mbps... If speed and response is of no concern, it may be your answer.
But, I would get a small switch and try to conceal it instead anyway.
http://www.instructables.com/id/How-...22splitter%22/
micagreenmachine is offline
post #10 of 13 Old 08-28-2010, 10:14 PM
sold's Avatar
As above if you don't mind 100Mb then a splitter at each end of the cable will do the job (as 100BASE-TX only requires two of the four pairs in the cable). It's not the ideal way to do things, but there's no real reason not to in your situation.
sold is offline
post #11 of 13 Old 08-29-2010, 12:12 AM
Cocophone's Avatar
Here's a link with a drawing.
http://www.cabling-design.com/refere...ts/split.shtml
==Cocophone==
Cocophone is offline
post #12 of 13 Old 08-29-2010, 06:35 AM
TUKIN18S's Avatar
splitting can cause issues. I would highly recommend you get a switch.
TUKIN18S is offline
post #13 of 13 Old 08-29-2010, 08:18 AM - Thread Starter
jcamber's Avatar
This just gave the idea of maybe just have a wifi adaptor. Maybe fast enough to stream HD from Netflix?
Wifi adapter
http://www.youtube.com/watch?v=ugxP3...layer_embedded
If not, I'm also considering this adapter. Up to 200mbps... not bad right?
Powerline adapter
http://www.youtube.com/watch?v=JN74V...eature=channel
Thanks all!
jcamber is offline
