Flyboyusa's Basement Theatre - AVS Forum | Home Theater Discussions And Reviews
post #1 of 234 Old 11-13-2010, 05:09 AM - Thread Starter
flyboyusa99's Avatar
So, I previously started a thread when I was in the planning stages. I've decided to start a new thread now that I'm actually underway with construction.
First off, a couple sketchups and ACad dwgs showing the overall layout. I think this will be the best layout considering the overall length/size of the basement. I was concerned with leaving the bar/theater all one area due to acoustics, light, etc. so I designed a divider wall with a large arch and another smaller doorway. The 5 ft. long arch should provide the "open concept" but yet still give some division between the areas. Besides, I've seen a few designs with the back bar concept that looked really great.
By flyboyusa at 2010-11-13
Also, a pre-construction picture showing the entire length of the basement that will be divided into bedroom, theater and bar/seating/fireplace area:
By flyboyusa at 2010-04-05
More to come.....
flyboyusa99 is offline
post #2 of 234 Old 11-13-2010, 05:32 AM
imjay's Avatar
Only improvement I can see would be to keep the bar, lose the extra seating and put in a couple of pinball machines. Change it from a quiet sitting area to something a bit more fun.
imjay is offline
post #3 of 234 Old 11-13-2010, 01:58 PM
RTROSE's Avatar
Quoted: 195 Post(s)
Liked: 169
Good looking space. Couple of questions. Is the bedroom going to have a full time occupant, and do you have to go through the theater to get to it? Hard to tell from the drawings. If there is going to be a full time occupant (rather than a spare room for quests, I would make every effort to do some sound isolation/proofing other wise you will regret it later. I could also be annoying at times to have someone going through the theater to get to the room. What size it the theater going to be? Overall I would say pretty good setup. I second the pinball thought, or maybe a pub table to pay cards on.
Good luck.
RTROSE
RTROSE is offline
post #4 of 234 Old 11-14-2010, 06:38 AM - Thread Starter
Thanks for the thoughts/suggestions.
I agree, the seating area may be re-purposed eventually, just had to throw a few seats/couch in to keep the wifey interested!
Anyhow, the guest room may become my daughters room when she is older. I have DD and greenglue on the bedroom side already, plus Roxul in between, plus another DD and GG layer on the other side once I get to that point. Also have a DD w/o GG on the ceiling, with cellulose blown into the joist bays b4 drywall went up. So far, the green glue has performed exceptionally well, amazing stuff that I would recommend to anyone.
Here's a couple pictures of the GG being applied.
By flyboyusa at 2010-11-14
post #5 of 234 Old 12-02-2010, 05:18 PM - Thread Starter
The guest bedroom is finally complete!
The drywall stage... dusty
By flyboyusa at 2010-10-29
The finished room:
By flyboyusa at 2010-12-02
Some pictures of the dividing arch wall framed up:
Looking towards the screen wall
Looking back from the HT towards the bar/game area
post #6 of 234 Old 12-13-2010, 03:40 PM - Thread Starter
Finally got the bedroom hallway drywalled! Need to mud/tape and flooring next.
Before drywall:
By flyboyusa at 2010-12-13
After drywall. I used double drywall and 12 tubes of green glue with Roxul packed into all the cavities. The media cabinet is cutout and ready to starting constructing.
Also working on getting recessed lights installed in the HT room:
post #7 of 234 Old 12-13-2010, 05:31 PM
leo95se's Avatar
why are you using OSB on the walls, as well as 2 layers of sheetrock? is there a recommended HT construction method? as im looking to build this would be good to know. thanks!
leo95se is offline
post #8 of 234 Old 12-13-2010, 06:32 PM - Thread Starter
The osb is used only because I have the arched openings, it's used only for support to make the form for the arch. Most of the walls are 2 layers of 1/2 drywall with green glue in between for soundproofing, but around the arch areas I use 1 layer of 1/2 osb and 1 layer of 1/2 drywall. If you just have square door openings, you could just use the 2 layers of drywall with gg inbetween.
post #9 of 234 Old 12-15-2010, 06:48 PM - Thread Starter
The main recessed lights for the HT room are in and working! I plan to have additional eyeballs along the soffit to wash the side walls as well as stage lighting.
By flyboyusa at 2010-12-15
post #10 of 234 Old 12-15-2010, 08:42 PM
Fuzzybear50's Avatar
Looking good, what type of flooring did you use in the bedroom? Btw, i'm in La Porte
Beer is the answer! What is the question?
Fuzzybear50 is offline
post #11 of 234 Old 12-15-2010, 10:54 PM - Thread Starter
Thanks Fuzzybear. The flooring is a engineered bamboo 3/4" snap together product, they had it on clearance at Menards in Elkhart for $2.89/sq.ft. which is a bargain for this type of flooring. It was easy to install and so far is working very well.
Anyhow, nice to see another northern IN Hoosier on the forum!
Sounds like you enjoy beer as well, bonus!
Here are a couple pictures of my home brewery, it's another hobby of mine that seems has been crowded out lately by the HT bug!
Dave
post #12 of 234 Old 12-17-2010, 02:58 PM
That looks like an intricate set up.
post #13 of 234 Old 12-17-2010, 04:39 PM
RTROSE's Avatar
Quoted: 195 Post(s)
Liked: 169
I have been interested in home brewing for a long time, but have not done anything to pursue said interest. I get enough flack for the HT journey without adding another hobby to the mix.
Looks like a pretty sweet setup. A buddy of mine home brews and every so often I get some of his "extra". Usually pretty good stuff.
RTROSE
RTROSE is offline
post #14 of 234 Old 12-17-2010, 07:01 PM
markek's Avatar
Quoted: 24 Post(s)
Flyboy,
What type of subfloor did you put under the bamboo flooring?
Congratulations, everything is looking great so far.
Onkyo TX-NR646
markek is offline
post #15 of 234 Old 12-18-2010, 04:48 AM - Thread Starter
Thanks RT, homebrew is a lot of fun, I would highly recommend you take up the hobby, anyways that's got it's own forum to write in, I'll stick to the audio/video here.
markek, the underlayment I used was from Menards, it's a thin blue foam with a poly liner on one side. This was recommended for install over concrete, since it acts as a moisture barrier as well as a sound absorber. The sales guy specifically said not to use any felt or natural fiber based underlayment as it will absorb moisture and begin to mold/mildew.
Here are a couple pictures:
By flyboyusa at 2010-12-18
The poly moisture barrier layer is installed facing up. Along one edge is an adhesive strip:
and along the other edget is an overlap vapor barrier to stick to the adhesive strip to provide a continuous barrier, worked well:
post #16 of 234 Old 12-19-2010, 04:47 PM - Thread Starter
Made a little progress this weekend. I got the media closet framed in:
From the front:
By flyboyusa at 2010-12-19
From the back side:
Also got most of the outlets wired in the HT room:
30 ft. Monoprice HDMI cable, "future proof" conduit and 110V outlet in the mounting location for the projector:
It is difficult to think of any and all wires, cables, water lines, natural gas lines, drains, etc.. that need to be run in the ceiling. I want to make sure I have EVERYTHING that I will possible need before I insulate and drywall the ceiling.
I plan on stapling landscape fabic to cover the enitre ceilling and filling all the joist cavities with blown in cellulose. Then cover with double drywall and green glue. This is what I did in the guest bedroom and it worked very well. I just need to make doubley shure I have everything ran before closing it up!
post #17 of 234 Old 12-31-2010, 12:26 PM - Thread Starter
OK are there any plumbers out there?
I have to tie into my main drain trunk running down the center of my basement.
I will be using an undersink mounted drain pump for my wet bar, it required 1-1/4" drain line with no vent required. So I want to put a Y into the end of the main drain line, I have access to the very end of it and plan on solvent welding in a Y here:
By flyboyusa at 2010-12-31
Can anyone comment on this and let me know if this will work ok please??
This line is a 3 or 4" running the length of the house and exits out the end of the basement into the septic tank. This is the opposite end and reduces down to 1-1/2" pipe, the elbow pointing up is going to the clothes washer drain.
Dave
post #18 of 234 Old 01-01-2011, 10:30 AM
leo95se's Avatar
thats no problem, should work just fine
leo95se is offline
post #19 of 234 Old 01-01-2011, 06:40 PM - Thread Starter
Thanks leo, I always tend to second guess myself, it's good to hear confirmation from someone else that this drain setup will work.
I managed to get the bar rough framing done tonight as well as the cabinet layout drawn on the floor. Framing for the 1/2 wall was done with 2x6 lumber for stability/strength.
By flyboyusa at 2011-01-01
A couple closeups from inside the bar:
The view from sitting at the bar looking towards the screen wall - should be good for football season!:
Also, I got the natural gas, electric and low voltage ran to the fireplace location. I started framing the hearth and fireplace corner wall, but realized I have to drywall behind before finishing the framing. Hope to finish this tomorrow.
Dave
post #20 of 234 Old 08-01-2011, 08:49 PM - Thread Starter
Well I've made some progress since Jan.. I've decided against the full bar and will leave this space as a sitting area. Got a great deal on a demo unit direct vent fireplace (gotta love craigslist!). All electrical is fully complete, hope to start blowing insulation in all the floor joist bays soon, then hanging sheetrock on the ceiling. Once that's done, I'm hoping the rest will go a little faster.
Lots of pictures to come!
post #21 of 234 Old 08-04-2011, 02:26 PM - Thread Starter
View looking at the stage - Roxul installed
By flyboyusa at 2011-08-04
Fireplace framed and set in place - waiting for the fireplace guy to come and install the venting thru the rim joist to the outside:
After the fireplace guy is done - vent installed (I wasn't up for attempting this myself, I'm sure I could have done it but I'll sleep better at night knowing it's done properly - some things are better left to the pros):
Closeup of the vent exiting the rim joist:
Another vent picture:
Rough electrical - 4 switches - main can lights, under soffit lights, upper soffit lights and stage lights:
Bump out area for future sitting/game area:
Dave
post #22 of 234 Old 08-04-2011, 04:03 PM
RTROSE's Avatar
Quoted: 195 Post(s)
Liked: 169
Yeah, progress. Looks good. Now keep it up and the pictures too.
RTROSE
RTROSE is offline
post #23 of 234 Old 08-11-2011, 03:00 PM - Thread Starter
So I got a few more things accomplished:
The equipment cabinet before:
By flyboyusa at 2011-08-10
Drilling the holes for the shelf pegs:
And after:
A few shots of the pre-wiring for surround and rear-surround speakers:
Also got the plywood arch finished in the hallway entrance door:
The fireplace guys were back and finished the install, it's fully functional now - the new fireplace is great.
Just picked up 60 sq. ft. of veneer ledgestone and supplies to get started on the finishing of the fireplace.
Also, picked up oak lumber to build a custom mantel for above the fireplace.
Off to get some more done!........
Dave
post #24 of 234 Old 08-12-2011, 03:26 AM - Thread Starter
The stone for around the fireplace:
By flyboyusa at 2011-08-12
And the keystone arch surround fitted in:
Dave
post #25 of 234 Old 08-13-2011, 05:56 PM
RTROSE's Avatar
Quoted: 195 Post(s)
Liked: 169
I really like that stone. Nice choice! Looks like you're still making progress and that is all that is important. Keep up the nice work.
RTROSE
RTROSE is offline
post #26 of 234 Old 08-14-2011, 12:59 PM - Thread Starter
Thanks Rose.
Got a few more items completed on the fireplace, this thing is taking too much time away from work on the theater! Anyways....
Cement board and lathe complete. Mantel shelf built and fitted:
By flyboyusa at 2011-08-14
Outlet above the mantel for the wife to plug in Christmas lights, etc...
Now off to mix mortar and scratch coat, should be fun and messy.
Dave
post #27 of 234 Old 08-14-2011, 05:10 PM - Thread Starter
Scratch coat is complete. Lesson learned, it's better to be too wet of a mix rather than too dry. I started off too dry and had major difficulties, as soon as I made it about like yogurt, it started working much better.
Anyhow, I got it done finally, I have a new appreciation for stone masons!
Dave
post #28 of 234 Old 08-14-2011, 08:54 PM
RTROSE's Avatar
Quoted: 195 Post(s)
Liked: 169
I'm watching with great interest. I have tackled many things during my build, but masonry is not one that I have had the bravery to do. Looking forward to seeing how it all turns out. Take lots of pics during the process.
Good luck.
RTROSE
RTROSE is offline
post #29 of 234 Old 08-16-2011, 07:37 PM - Thread Starter
Finally got to start installing stone work on the fireplace, almost 1/2 way done. Very time consuming, I was trying to go for the stacked stone look without grout lines, but it's not that easy to make them fit exactly together, so I will probably end up with some grout lines.
By flyboyusa at 2011-08-16
Dave
post #30 of 234 Old 08-21-2011, 12:59 PM - Thread Starter
The stone work is finally all up and about 2/3 grouted, the grouting is very time consuming and difficult to make it look good. Some pictures:
By flyboyusa at 2011-08-21
I'm out of grout, need to get another bag tomorrow, so for the rest of today I'm going to try and get landscape fabric stapled to the bottom of the floor joists in prep. for blowing insulation into the joist bays, then drywall. Can't wait to see the ceilings drywalled so I can start on the soffits in the HT and the stage! Should be soon, pictures to come.
Dave
