Billybar's Basement Theater etc.. Build - Page 9 - AVS | Home Theater Discussions And Reviews
 9Likes
post #241 of 244 Unread Today, 07:38 AM
DDarroch's Avatar
awesome
I have enjoyed following this thread, especially now that I am in the middle of my build. I was in the same boat as you for lights. I determined that I could get by with 4 x 6" cans. It is not super bright but it saved me a ton of work since the ceiling joists run right to left. So I figure that 95% of the time the lights will be out anyway. I figure it might be a choice that I regret later, but if someone needs to find something, that is why they invented flashlights. I am excited to continue this thread and watch all your progress.
my build is here : Darroch Theater
DDarroch is online now
post #242 of 244 Unread Today, 09:56 AM - Thread Starter
barlav's Avatar
Thanks DDarroch! I visited your thread, very nice! I am subbed.
DDarroch likes this.
barlav is online now
post #243 of 244 Unread Today, 09:59 AM - Thread Starter
barlav's Avatar
I think I have decided on sconces. Found some reasonably priced that I like the look of so I ordered one and installed it when it arrived yesterday. I am liking it. It will also match the trims of the other lights which are a "Tuscan Bronze". Now I have to order 10 more
post #244 of 244 Unread Today, 10:38 AM
zoepup's Avatar
Quoted: 24 Post(s)
Originally Posted by barlav View Post
I also will have sconces. And between those and the soffit lights I think you're right, I won't have much need for the overhead ones. They have been nice to have while finishing the space. In hindsight I wish I used fewer and added a star ceiling instead...ah well.
Yeah that is a ton of overhead cans. I was in same dilemma and then realized I hate overheard lights. I prefer dim to no lights. So I only put 6 LED smart bulbs on each side of mine. It won't light up like yours but it is sufficient for now and I prefer torches lights, etc.
Your build is moving alone nicely. I am thinking of doing your under stairs media cabinet as well.
MY Build in Progress >>> My Home Theater Build
Living Room: Samsung PN60F8500, KEF 3005 5.1, Marantz SR6003
HT: Selection in progress
In storage: Mirage M7si, Mirage LF-150, Marantz SR7200
zoepup is online now
Basement Bar
