bar table behind theater seats - AVS Forum | Home Theater Discussions And Reviews
 15Likes
post #1 of 132 Old 02-09-2011, 07:58 PM - Thread Starter
DedicatedHT's Avatar
I'm looking for a table to put behind my seats for extra seating. I've seen people do it here and can't find any now. It has to be high enough to sit under with a barstool, narrow (preferrably 1-2'w just enough to lean on and place drinks) and around 4' long.
What are these called? I'm googling and its not entry table, not sofa table, not pub table, not bar table, not console table??
What are they called and who's got examples here? Are there designs to make one with granite top?
DedicatedHT is offline
post #2 of 132 Old 02-09-2011, 08:17 PM
Quoted: 3434 Post(s)
Liked: 2893
post #3 of 132 Old 02-09-2011, 09:01 PM - Thread Starter
Exactly what I'm looking for thanks. You say the wings are purely aesthetic but I'm guessing they are needed to support the granite.
My media room is upstairs and I would somehow have to attach to the subfloor. I was looking for a table for now I can use until I build what you have. But don't know what to search for.
post #4 of 132 Old 02-10-2011, 05:36 AM
Spartan94's Avatar
Spartan94 is offline
post #5 of 132 Old 02-10-2011, 09:13 AM
Liked: 2893
using 2x6s for the wings was the aesthetic choice, 2x4s would have been fine.
Also depending on the width and shape of the granite a mid brace may not be required.
post #6 of 132 Old 02-10-2011, 11:48 AM - Thread Starter
do you guys have build shots of framing/sheetrock/floor mounting/trim, etc? DC I saw some from you but it was already MDF'd.
post #7 of 132 Old 02-10-2011, 12:39 PM
Liked: 2893
my second picture in the linked post shows the framing. My framing sits on the floor.
There are a lot of photos in Buffbakers photo album, his sits on the riser.
album: http://public.fotki.com/jeffbaker24/bar__home_theater/
BuffBakerGA likes this.
post #8 of 132 Old 02-10-2011, 01:26 PM
Spartan94's Avatar
I have some framing pics in my build thread, but there are much more here:
http://www.screencast.com/users/Matt...7-7d13c4e1c7ff
I just built it right on top of my laminated floor -- and it is mobile, although it weighs a ton.
post #9 of 132 Old 02-10-2011, 02:19 PM
imjay's Avatar
Don't get a table - instead put a nice, wooden bar with four to six nice, big and comfy bar chairs. People may prefer sitting at the bar instead of a "theater" seat more than you might think
imjay is offline
post #10 of 132 Old 02-10-2011, 03:15 PM - Thread Starter
jay, that is exactly what happened during super bowl, people were fighting for the bar chairs i had under the entry table i carried up there!
the table would just be temporary until I build something. I think not wood but sheetrock painted the same dark brown as the walls, same floorboard trim, same granite as in kitchen. My room is only 12x16 here is what I'm working with. Seating is at 10' so I only have 6' for a bar and walking room behind it.
Sorry its a little dark
post #11 of 132 Old 02-11-2011, 05:54 AM
Liked: 2893
You might want to investigate adjustable height training tables and counter height stools.
Bar height is around 42 inches and counters are 36. I did see some training tables that adjust to 36.
You will need to Google around. Here is the basic shape:
post #12 of 132 Old 02-11-2011, 12:22 PM - Thread Starter
Thanks BIG, yes something like that but with WAF. thanks for the help
post #13 of 132 Old 02-28-2011, 10:00 AM - Thread Starter
OK so I found this picture of a narrow framed wall. My questions are
1. How do you mount this upstairs to a subfloor
2. will it support a granite top without falling over?
post #14 of 132 Old 02-28-2011, 10:30 AM
DaveHolland's Avatar
I'm considering doing the same sort or bar/table behind my first row seating. How does having that big reflective panel right behind your head affect the sound quality?
-Dave
DaveHolland is offline
post #15 of 132 Old 02-28-2011, 11:07 AM
jayn_j's Avatar
Quoted: 62 Post(s)
Liked: 41
-Dave
If you go with the 36" height that Big suggested, it probably wouldn't be a problem. My Berks are 42" to the top of the seatback and would totally block any reflections from the bar. Your head would be above bar height. Take a look at Big's link to see what I mean.
If you are worried, you could always upholster the front or just glue black short nap carpeting to the front face.
jayn_j is offline
post #16 of 132 Old 02-28-2011, 05:15 PM
Liked: 2893
My bar is 43 inches tall measured from the floor not the riser. My chair backs, tall Berkline 045s are never below the top of the bar even in a reclined position. So most of the front side of the bar is blocked by the seating.
post #17 of 132 Old 03-01-2011, 08:45 AM
glend123's Avatar
Here's My Bar/Island. it's just under 8' long. the granite top is 18" x 8' long and will be 42" high to the top of the granite, which is standard height.
glend123 is offline
post #18 of 132 Old 03-05-2011, 01:05 PM - Thread Starter
Thank you Glen!
How are you going to mount to the floor?
What are you going to do with the carpet cut it out or leave it?
How did you attach the wings?
Are you going to Sheetrock?
post #19 of 132 Old 03-05-2011, 02:06 PM
glend123's Avatar
Here's where I stand now.
I need to finish the trim and stain. I am going to bolt it to the floor, hopefully right throught the carpet. We'll see how that goes.
glend123 is offline
post #20 of 132 Old 03-05-2011, 02:20 PM
Liked: 2893
post #21 of 132 Old 03-07-2011, 11:00 AM
ack_bk's Avatar
Quoted: 551 Post(s)
Liked: 656
I don't think you will have a problem. Just get a hammer drill, and some 3/8" concrete anchors.
Nice job by the way. I am looking into something very similar but am a little scared about granite costs.....
Do you mind if I ask how much that set you back for your top?
dabsabre likes this.
ack_bk is offline
post #22 of 132 Old 03-07-2011, 11:45 AM
glend123's Avatar
Granite can be expensive, but a piece of this size could be classified as a remnant and someone might be happy to cut it and radius the corners for you. I found that their are many granite suppliers advertising on craigslist. I just emailed all of them with my requirements and got quotes ranging from $250 to $800. The piece I ended up getting was $150, only because it is 3/4" thick instead of the more common 1-1/4 thick. I was hesitant at first about it looking cheap, but so far I'm glad I went with it because it was pretty heavy, I don't think I could lift the thick stuff.
glend123 is offline
post #23 of 132 Old 03-07-2011, 12:51 PM
ack_bk's Avatar
Quoted: 551 Post(s)
Liked: 656
Thank you. I will start framing next week for my basement and my wife and I decided on a wet bar with a similar bar top idea for folks that overflow into that area and want to watch the projector screen (120" screen).
I have been thinking about remnants and did not realize how affordable they were. Will definitely look into this. Thanks!
ack_bk is offline
post #24 of 132 Old 03-15-2011, 06:09 PM
haslip's Avatar
Be real careful with a 3/4 piece of granite that long. It can break like a cookie much more easily than you think.
Carry it and lift it perpendicular to the floor, vs. parallel that makes any sense. This I know, if you have someone at each long end, and lift it the way it is now, it WILL break.
I also understand that quartz synthetic, like Dupont Zodiac is much stronger in this regard.
I was a cheap bastard, and bought a remnant of Zodiac, and picked up one end so see how heavy it was. Guy had a look of terrror, and told me if it was granite, it would have broke in the middle for sure (my piece was 7 foot long and 18 inches wide).
Yeah, i build a table very similar to this, but had a local iron/welder guy make the table to my specs, and then I had it powder coated.
Deltaphi216 and jcoolz like this.
haslip is offline
post #25 of 132 Old 04-30-2012, 07:47 AM
JTDinVA's Avatar
Sorry to post on an old thread, but I was building something similar which led me to your pics. I was wondering where you purchased the bar stools and how much they were (if you don't mind)? Everything I see is really expensive.
JTDinVA is offline
post #26 of 132 Old 04-30-2012, 08:27 AM
Liked: 2893
Just one potential source for you to check, this is an auction house that handles local business liquidations and they get a lot of resturants. There are some bar stools up for bid right now. of course you have to buy the lot of 11
http://www.rasmus.com/auction_detail.php?id=180611
post #27 of 132 Old 04-30-2012, 08:42 AM
glend123's Avatar
I forgot to update my finished bar, so here it is. I bought my stools on craigslist for $300 for 4 of them. I wanted Very thick padding and armrests and to buy them new would be too expensive.
Tedd and BuffBakerGA like this.
glend123 is offline
post #28 of 132 Old 07-31-2012, 11:54 AM
str1der's Avatar
Quoted: 28 Post(s)
Sweet. Any thought of putting in a foot bar?
str1der is offline
post #29 of 132 Old 07-31-2012, 12:13 PM
glend123's Avatar
I thought about it, but the footrests on the bar stools seem to be working ok. I might stretch a piece of oak across the bottom if I'm looking for a small project this winter.
glend123 is offline
post #30 of 132 Old 12-22-2012, 04:25 PM
Atren's Avatar
Wow this is a great thread. Thanks for the pictures BIGmouthinDC and gelnd123. I wanted to build exactly what you have and I had it in my mind but I just couldntmake it come together!!! I will most likely base my back table on your design. Could you post the width dimension of the bar under the 8" wide granit?
Oh and great steal on the stools. I want something bulky and chusiony as well but dont want to pay a boat load from them. guess I will have to keep my eye on craigs list.
Atren is offline
