Should i plug the Sub to UPS? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-13-2011, 02:27 PM - Thread Starter
motoharu's Avatar
When there is a shortage or spike on the electricity my old Definitive Tech sub was making a "Boom" sound which is really disturbing and probably harmful to sub.
And after a few years it started making a loud hum.
So, in my new setup i am thinking of plugging the sub (Focal SW800) to a UPS, to avoid that boom sound and possible harm it can do.
Do you think its safe and/or useful to do so?
On my setup, what else should i use with UPS?
Have total of 8 outlets from two 1000VA APCs.
Marantz SR7005 AVR
Marantz UD5005 BDP
Samsung 55C8000 LED/LCD
Epson 8500 Projector
Onkyo DVD
Satellite Box
Focal SW800 Sub
WD TV Live
2TB x 2 WD Elements External HD
Thanx
motoharu is offline
post #2 of 5 Old 02-13-2011, 06:03 PM
holt7153's Avatar
Quoted: 137 Post(s)
Liked: 221
Marantz SR7005 AVR
Marantz UD5005 BDP
Onkyo DVD
Satellite Box
Focal SW800 Sub
WD TV Live
Thanx
Don't most sub companies tell you to plug directly into the wall and NOT into plug into power strips/conditioners, UPS, etc?
Anything good in life is either illegal, immoral, or fattening.
holt7153 is offline
post #3 of 5 Old 02-14-2011, 01:04 AM - Thread Starter
motoharu's Avatar
Have no idea, that's why i'm asking
motoharu is offline
post #4 of 5 Old 02-14-2011, 09:33 AM
gregzo's Avatar
Two 1000VA are a couple of pretty big, beefy UPS units. Most folks don't have stuff this size. These are usually relagated to small company, server systems...or home users that tend to know their stuff.
So if you have these...I would tend to think you probably know your stuff...
Like any UPS installs...just add up your wattage usage and plug in what you can. Most 1000VA UPS units will run 600 watts comfortably each. Check you max usage of your components and plug 'em in and relax and enjoy. The circuitry on a UPS is far superior to any power strip or surge suppressor. They will run any electronics with relative. As you know, amps can max much higher than typical draw...you don't want the breaker on the UPS to trip on you...so use max current draw of each piece.
Good Luck.
gregzo is offline
post #5 of 5 Old 02-14-2011, 06:36 PM
Speedskater's Avatar
Quoted: 20 Post(s)
This is the correct answer!
Kevin
Speedskater is offline
