Motorized Cabinet Door Opener? - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By cm11599ps
  • 1 Post By sumavguy
post #1 of 10 Old 03-01-2011, 03:18 PM - Thread Starter
cm11599ps's Avatar
Is there a remote control operated device that would allow me to open some cabinet doors? I used to have the TV in my bedroom on top of my dresser so it was no problem. I now have a new dresser and the TV is behind closed doors. I have to manually open the doors to watch TV which isn't ideal. It would be much easier to push a button on my Harmony remote and have the doors open and then have my TV turn on.
I browsed but I'm not sure if this thing exists or what it may be called.
cm11599ps is offline
post #2 of 10 Old 03-01-2011, 03:37 PM
tt300zrcr's Avatar
you would need an actuator and relay to trigger it either it be serial based or ir or rf
tt300zrcr is offline
post #3 of 10 Old 03-01-2011, 06:47 PM - Thread Starter
cm11599ps's Avatar
You might as well be speaking Greek. lol
Is this something that's hard or expensive to do? I'd like to be able to program a "Watch TV" button on my Harmony remote and have the cabinet doors open and then have the TV turn on.
I'm guessing there are no commercial products available?
Boomassiv likes this.
post #4 of 10 Old 03-04-2011, 01:35 PM
MrBobb's Avatar
Quoted: 164 Post(s)
Liked: 63
U will have to look this stuff up through high-end dealers me thinks. Hope budget is not a big consideration.
Whatever u get, IMHO, gotta be SILENT, no annoying whirring motor as the doors moves.
MrBobb is offline
post #5 of 10 Old 03-04-2011, 02:33 PM
sumavguy's Avatar
If you have a wife... see if you can program her to do that
sumavguy is offline
post #6 of 10 Old 03-04-2011, 03:20 PM
mutheater's Avatar
They make ones that are programmable? My is not....I already upgraded once, can't afford to upgrade again.
mutheater is offline
post #7 of 10 Old 09-07-2011, 02:07 PM - Thread Starter
cm11599ps's Avatar
I'm guessing there is no reasonably priced option for me. That stinks. Surely there's a need for this somewhere.
post #8 of 10 Old 09-07-2011, 02:20 PM
jautor's Avatar
Quoted: 1215 Post(s)
Liked: 777
As others have said, not likely in a price range you'd likely find acceptable (nor would most of us). Reason being that the number of options are too great to make a simple solution that would work for "everyone's furniture".
Other thing working against you is that TV-inside-the-dresser/armoire has been replaced with flat-panel-on-the-wall. That would be a cheaper option, even if you have to sell/replace the TV.
Jeff
jautor is offline
post #9 of 10 Old 08-12-2014, 08:52 PM
PeterAVM50's Avatar
I know this thread is a bit stale but I have the same question. Though my location isn't a bedroom and I don't care how load the opener is or how it looks. I'm looking for some sort of opener for panel that'll conceal an amp rack that'll be installed in a non-temperature controlled environment, basically outdoor temps. In the summer door can always be open but in the winter (I live in the northeast) I'll need to have this little box a bit heated so the components don't get too cold. Thus the need for a remote trigger door opener.
Short of a mini-garage door opener which would be complete overkill (though tempting...) does anyone make something that'll take a 10" x 60" plywood panel and move it from vertical to horizontal?
Any help greatly appreciated!!!
PeterAVM50 is offline
post #10 of 10 Old 08-13-2014, 04:38 AM
weaselfest's Avatar
Quoted: 46 Post(s)
Liked: 41
if DIY is an option, check out this link on linear actuator application, with sources for 120V models.
underachiever extraordinaire
weaselfest is offline
