Good customer service from Monster... - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By smooothdee
Old 03-06-2011, 06:45 PM - Thread Starter
stockjock's Avatar
I believe that most here dislike Monster, but I like to reward companies for good customer service and I feel that I've received this from Monster. Quite some time ago, I bought a Monster HTS 2000 MkII power center for a bit north of $100. I'm guessing I bought it about 6 years ago.
Recently, the voltage/wattage display began flashing random numbers, but it otherwise seemed to work fine. I called Monster and they asked when I bought it. I said I wasn't certain. They asked if it's possible that it was within 5 years and I said it's possible.
With no receipt or hassle, they agreed to send me an HDP 1800. When I pointed out that the HDP 2500 has roughly the same number of outlets as the unit with the problems, they agreed to send that one instead. This unit goes for about $400. Overpriced? Maybe, but I can't beat getting one for free in exchange for an old, defective unit.
I don't know about how much good the power conditioning does, but at the absolute minimum I suspect I've received good protection for my components. But whatever you think about Monster, I have to give them credit for going above and beyond by replacing an old power center with a substantial upgrade and all without a receipt or any hassle.
stockjock is offline
Old 03-06-2011, 06:49 PM
Colm's Avatar
Liked: 94
They ought to give you good customer service for what they charge for their products...
Colm is offline
Old 03-08-2011, 08:59 PM
ellis2x's Avatar
I've actually had really good luck with Monster too. Regardless of any bashing, they do make good products and stand behind them. I had a customer with a flat panel mounted with an hdmi run through the wall to an opposite wall. The housekeeper moved the equipment while trying to get something that junior knocked down, and proceeded to bend back the head of the hdmi cable to where it snapped. I called monster on the customer's behalf, and told them I'll need to yank the cable out of the wall and run a new one. They sent the customer a brand new 16' hdmi, and just asked that I send the old one back in the prepaid box. I said I might cut the heads off the old one to make it easier to snake back out, and they said "go for it."
So yes they're overpriced. But it looks like they know it, and their customer service is all local in San Francisco. Good on 'em.
ellis2x is offline
Old 03-08-2011, 09:54 PM
Colm's Avatar
Liked: 94
Frankly, I haven't seen much Monster bashing around here, just the obvious comments that they are overpriced for what you get. A free cable from Monster is no bargain when you can buy ten cables that perform as well for the same price as one of theirs.
Colm is offline
Old 05-22-2012, 06:37 PM
rubicinc's Avatar
I figured out how to fix the problem with blinking, blank or 080 display on Monster HTS 2000 MkII. If anyone wants, please post your request, and I will describe it.
rubicinc is offline
Old 05-23-2012, 05:01 AM
khankewycz's Avatar
So technically if you would have been honest with them that you bought it 6 years ago and not 5 you wouldn't have got anything I bet.
+1
khankewycz is offline
Old 05-24-2012, 10:59 PM
MrBobb's Avatar
Quoted: 165 Post(s)
Liked: 63
Because I've been around the block a few times... I hazard to guess this is a known factory defect known at least internally to Monster, but Monster has not unilaterally initiated a recall, the front line people is been told by management, if customer complains about this problem, fix them. Cheaper than getting one of those class actions.
MrBobb is offline
Old 05-25-2012, 10:23 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 144
Monster might offer quality snake oil, and unbelievable customer service, but their/his business ethics are deplorable.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
Old 09-03-2012, 05:50 PM
orleansman's Avatar
If you have the solution for the 000 080 flashing light issue I'd love to see it.
My Monster Bar has been doing this for about a month now (5 years old) but other than that appears to work perfectly...
orleansman is offline
Old 09-04-2012, 12:16 AM
sebberry's Avatar
Quoted: 27 Post(s)
Liked: 30
I still get a chuckle out of the BJC letters.
I'd give Monster a call to see if they can help you out. Likely not a user-correctable problem. Good luck, let us know how it goes.
sebberry is offline
Old 11-10-2012, 09:59 AM
Nosferatou's Avatar
Hi, am concerned about flashing display ssues with my 5-6 years old HTS 2000 MKII. CS tell me to disconect from wall for minutes, and replug. It should fix the problem. ... Na, Same problem! What I have to tell them CS to convince them to replace my unit with another one?
thx
Nosferatou is offline
Old 11-10-2012, 10:05 AM
Nosferatou's Avatar
thx
Old 12-11-2012, 08:45 PM
legend90's Avatar
Help. I just noticed the blinking 080 and 000 lights on Monster HTS2000MKII. Date code is 06 - 07, so I figure that it's more than 6 years old.
I tried the reset button, but that's no use, and unplugging it didn't work either. How do I get them back to showing accurately?
legend90 is offline
Old 03-02-2013, 11:42 PM
waynetolson's Avatar
i was wondering how to fix the blinking display on the monster hts2000 mkii.
thanks, wayne
waynetolson is offline
Old 06-08-2013, 04:17 AM
Hello, I have the exact problem that you described. My MKII is blinking 080 instead of the normal amp/volt indicator. Should I call Monster about this problem? Will it damage my electronics if I don't replace the MKII? Thanks for your help!
atomiconnection is offline
Old 07-13-2013, 12:21 PM
Steve Alexander's Avatar
What is your advice about fixing the Monster ower supply blinking 80 on the voltage?
Steve Alexander is offline
Old 09-15-2013, 07:50 AM
vig1116's Avatar
I know most of this thread is old, but can someone tell me how to fix this 080 flashing. I called monster 2 times and because i lost receipt they won't do anything. I understand their side, but if it's a major issue with this fairly expensive power strip I would expect better than "sorry"......
vig1116 is offline
Old 01-03-2014, 08:02 PM
MatthewW's Avatar
Quoted: 20 Post(s)
I also have the 080 flashing issue on my HTS 2000. Any help is appreciated. smile.gif
MatthewW is offline
Old 04-08-2014, 06:25 PM
mustangdaren's Avatar
Did anyone figure out how to fix the blinking display? I found a bad capacitor on the switchable audio outlets. I haven't replaced it yet but with it out of the circuit I do have a number on the display instead of dash marks but the display still is blinking slightly.
mustangdaren is offline
Old 10-25-2014, 09:11 AM
Liked: 1
Same 080 flashing issue on my HTS 2000. Haven't seen any repsonses. PLEASE HELP!!!!!!!!!!!!
Dealio likes this.
smooothdee is offline
Old 11-21-2014, 06:17 PM
Liked: 0
Help!
Hello can u please help me with blinking lights?
Majik515 is offline
Old 11-20-2015, 10:29 AM
Rob4226's Avatar
Quoted: 16 Post(s)
On my HTS 2000 I have the same blinking 080 blinking on the input and 000 blinking on the amps can you please post the fix??
Rob4226 is offline
Old 02-21-2016, 02:31 PM
unspun01's Avatar
Hi Everyone:
If you have a Monster HTS 2000 power strip, with "080" blinking on the input and "000" blinking on the amps, this unit requires simple disassembly and repair (soldering). You will replace one or more of the poor quality capacitors that have likely failed.
1) Disconnect the HTS 2000 from power and let sit for 15 minutes.
2) Remove the 4 rubber feet on bottom to expose 4 screws, then remove the screws.
3) Remove 2 additional screws from the plastic end cap (the opposite end cap of the power cord end cap).
4) Slide the bottom metal cover off to the side to expose two circuit boards.
5) Remove 2 screws from the bottom of the SMALLER circuit board and pull out far enough to work on.
On the smaller circuit board, test the 4 electrolytic capacitors for high ESR and replace any that are bad (1x10uF/50V, 1x22uF/50V, 2x47uF/50V). In my case, I had to replace the rightmost 47uF/50V capacitor that was off by itself. These capacitors may be bad without looking visibly bad. If you do not have a ESR meter, try replacing the same capacitor I did (47uF/50V) and see if you have success. Do not change the specs of the capacitor.
Reassembly steps are reverse of disassembly.
I hope this helps anyone who has this issue. Good luck.
unspun01 is offline
Old Today, 03:04 AM
Liked: 0
Arrow Replacing Capacitor fixed HTS2000 blinking "080 000"!
Originally Posted by unspun01 View Post
Hi Everyone:
MANY THANKS!
This recommendation to replace that 47uF Capacitor worked for me!
I actually replaced ALL four electrolytic CAPS and measured their actual capacitance with an LCR meter
10uF measured 7.6uF
22uF measured 18.3uF
47uF measured 44.4uF
47uF measured 0.3uF !!! (the "lone" CAP off by itself)
Sure enough, that lone capacitor had failed in my unit as well. This seems to be a problem as these HTS2000 units age, as many have seen this blinking "080 000" after their units are more than 5 years old (and just out of warranty).
Before discarding your vintage HTS2000 that is blinking "080 000", you should consider this simple Capacitor Replacement FIX
It worked for me!
SeattleSM is online now
Monster
