Family Room / HT in Siberia (well, in MN) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 37 Old 03-19-2011, 10:24 PM - Thread Starter
i_want_that's Avatar
Hello all.
We DYI'd a small (12x18) dedicated HT in our Columbia, MD house ~ 4 yrs ago. We moved back home to MN in Oct09. Unfortunately, we don't have space for a dedicated HT in this house. So I sold/CL'd much of my gear (100" Carada screen, Mits PJ, Denon 3806 Receiver, and PSB Image Speakers & Subs), only keeping the PS3.
The new MN house:
We'll be finishing the entire basement (~1000 sq ft):
(1) Great Room
- TV area with corner fireplace
- Pool Table area (or kids play area if my wife has her way)
- Small Bar area
(2) Bedroom
(3) Bath
(4) Small workout room
Goal is to get more sq ft for kids to play in, add a guest suite, and also build a better movie/sports experience vs our lil 42" in our main floor family room. Lastly, builder is throwing in basements basically for free now, so by doing myself, I should add to resale.
The plan for the TV area will be:
- 60-70" LCD/Plasma
- Marantz or Denon Receiver
- JBL in-ceiling LCRs and in-wall sides/rears
- sub(HSU?)
- misc other electronics.
- Potential build/wire for future drop down screen PJ
- Build out wall so there's a recessed area for TV
- Corner fireplace
I will no doubt have many questions, so many thanks in advance for your help.
I'll post pics with plan / progress.
Thanks, Brad
i_want_that is offline
post #2 of 37 Old 03-19-2011, 10:39 PM - Thread Starter
Log
pre - HVAC rough-in complete
pre - 4 circuits run from main panel (garage)
pre - much of outlet rough-in complete
3/19 - Installed some of the 20 6" Recessed Lighting (cans) and began to rough-in wire them
3/27 - Framed out corner fireplace. I made to wide, so I'll need to redo.
3/28 - Installed 5 4" cans for the bar area (90 min)
3/29 - Wired another 4 6" cans for pool table area (60 min)
4/3 - wired 8 6" cans for HT area (2.5 hrs)
In Progress:
- Electrical Rough-in
- Framing corner Fireplace and TV Wall
Next / To Do:
- Run A/V wiring (conduit to TV?)
- Rough-in Plumbing for bath & bar
- Fix framing in bath
To Buy:
- Order HDMI cable (30 or 35')
- Order Wall Plates for A/V cabinet drop
Bought/Ordered:
3/23 - JBL in-wall & in-ceilings ordered
3/23 - Monoprice 12g CL2 ordered/received & Sub RCA CL2 ordered/Received
3/24 - 100' of Carlon orange 2" raceway
3/22 - Monoprice 35' HDMI cable
post #3 of 37 Old 03-19-2011, 11:08 PM - Thread Starter
Here's the floor plan. (I used floorplanner.com)
post #4 of 37 Old 03-19-2011, 11:14 PM - Thread Starter
Here's my handdrawn plan for TV area
post #5 of 37 Old 03-21-2011, 05:45 AM
imjay's Avatar
IMO - if you were using a projector and screen downsizing to a small, 60in tv just won't deliver a theater experience. PJ and screen works fine in a multi-purpose room.
If you going to the expense of in-ceiling mounted speakers why not a pull down screen when you want genuine "at the movies" theater and a TV behind it for watching television.
We have a very nice 60in HDTV but it's way too small for HT expectations.
imjay is offline
post #6 of 37 Old 03-21-2011, 07:42 AM
mayhem13's Avatar
Quoted: 43 Post(s)
Considering a good projector and DIY screen is less than the cost of 60" HDTV, there's no reason NOT to do a PJ setup.
mayhem13 is offline
post #7 of 37 Old 03-21-2011, 01:20 PM - Thread Starter
I agree with the input on PJ/Screen vs 60" TV. My wife is pushing for a more general family room vs theater. Hence, we're likely starting w/ TV. Plus, there's a bunch of light.
I'm planning to wire/conduit for proj and motorized drop down screen so I can add later.
post #8 of 37 Old 03-23-2011, 01:19 PM
Scout's staff's Avatar
Regarding the wiring of HDMI to the TV - make sure you run conduit for future upgrades. When I had my house built in 2007, I added HDMI at the last minute since it was relatively new (no conduit). At the time everyone told me that HDMI was the best it would get, now there is v1.4 a few years later if you want 3D
Scout's staff is offline
post #9 of 37 Old 03-24-2011, 05:49 PM - Thread Starter
Just dropped $90 (delivered) on 100' of carlon 2" orange raceway. This will be enough for me to run to TV and also to a drop for future projector as well.
- Brad
post #10 of 37 Old 03-27-2011, 09:32 PM
Brian1080P's Avatar
- Brad
Menards sells 2" (sump tube) 50' for $15.00.......works good for conduit.
Brian1080P is offline
post #11 of 37 Old 03-28-2011, 09:14 AM - Thread Starter
Brian, where were you a couple days ago before I dropped the $90
With the price of carlin on the web (smart home.com), I should be able to recoup some/much of my $ by selling the leftover length on CL.
Brad
post #12 of 37 Old 03-28-2011, 09:01 PM
Fuzzybear50's Avatar
I used the same product in my basement, it's basically the same thing as Carlon but thinner.
Beer is the answer! What is the question?
Fuzzybear50 is offline
post #13 of 37 Old 03-28-2011, 09:55 PM - Thread Starter
Recessed lighting takes quite a while to do:
25 cans total and chunking away at 'em with an hour'ish each night. I knocked out the 5 4" bar cans tonight. My 4" cans are halo. My 6" cans are HD's consumer electric. The Halos are so much easier to work with. Unfortunately, the 20 6" cans are nailed up. I hope to finish up the wiring on the 6" cans by end of week.
- Brad
post #14 of 37 Old 03-28-2011, 09:56 PM - Thread Starter
Fuzzy, are you just using wire tires to hold your conduit in place?
- Brad
post #15 of 37 Old 03-29-2011, 12:55 AM
- Brad
Yes....just to keep them in place until insulation and drywall.
post #16 of 37 Old 03-29-2011, 11:00 AM
BllDo's Avatar
Quoted: 572 Post(s)
Liked: 372
Subscribed, should be fun to watch, but we need pictures, pictures and more pictures.
BllDo is offline
post #17 of 37 Old 03-29-2011, 11:06 AM - Thread Starter
I'll get some pics going. It's such a dumping ground for storage stuff and kids stuff that I'm embarrassed to post pics. I need to clean up and get some pics posted. Progress has been pretty boring (electrical and framing).
post #18 of 37 Old 03-29-2011, 11:21 AM
hanesian's Avatar
Quoted: 36 Post(s)
Liked: 81
When in doubt, remember ...
The Un-Theater Un-Build
hanesian is offline
post #19 of 37 Old 03-29-2011, 11:42 AM - Thread Starter
Good to see the folks from MN commenting.
post #20 of 37 Old 03-29-2011, 01:39 PM
BllDo's Avatar
Quoted: 572 Post(s)
Liked: 372
You say that now...
BllDo is offline
post #21 of 37 Old 03-29-2011, 10:03 PM - Thread Starter
I need a solid 1/2 day so I can wire the cans (8) in the HT area. This 90 minute/night thing is disheartening.
Here's the pic of the "TV" area. The framing for fireplace is too big, so I'll need to redo.
post #22 of 37 Old 03-29-2011, 10:06 PM - Thread Starter
For the fireplace, i'm looking at the Heat&Glo 6000 Modern. My plan is to keep the bottom of the LCD/Plasma lined up w/ the bottom of the fireplace to keep lines consistent.
pic of fireplace:
post #23 of 37 Old 03-30-2011, 08:06 AM
BllDo's Avatar
Quoted: 572 Post(s)
Liked: 372
How did you get a picture of my living room?
Think that will look pretty good.
BllDo is offline
post #24 of 37 Old 03-31-2011, 10:27 PM
FusionRx's Avatar
Nice space. Now that hanes is here, progress will slow to nothing....
What part of town you in? Down in Prescott, Wi (by Hastings) here.
FusionRx is offline
post #25 of 37 Old 03-31-2011, 11:53 PM
Killer's Avatar
[quote=i_want_that;20228467]For the fireplace, i'm looking at the Heat&Glo 6000 Modern. My plan is to keep the bottom of the LCD/Plasma lined up w/ the bottom of the fireplace to keep lines consistent.
I stopped by Fireside in EP yesterday for the Slim 550/Soho/ and for giggles the Red series, quote says no dice though. Although I will frame and plumb for the sl550, you can catch where in my thread.
Killer is online now
post #26 of 37 Old 03-31-2011, 11:54 PM
Killer's Avatar
[quote=i_want_that;20228453]I need a solid 1/2 day so I can wire the cans (8) in the HT area. This 90 minute/night thing is disheartening.
I SO know what you are referring to. Half the time I just stand in the space visualizing rather than doing anything,,,,oh yea thats right, i can't hammer or drill past 10......
post #27 of 37 Old 04-01-2011, 07:18 AM - Thread Starter
I'm out in Plymouth.
We looked at the SoHo as well and really liked it, but wanted a bigger presence. With the space crudely framed, I think it may be too big. I'm going to get hte framing right and then paint some cardboard to size to get a feel for how big the 5000 really is.
Funny comment on visualizing. When I come up from downstairs, my wife always ask, "what were you down there looking at" instead of what were you working on. I just pound away at night now. It drives my wife crazy, but doesn't seem to affect the 5 yr old or 5 mo old.
I'm going to find some time this weekend to finish the cans and wiring. Next up is finish the framing (a few hrs) and then determine me vs sub for rough plumbing.
post #28 of 37 Old 04-01-2011, 08:13 AM
hanesian's Avatar
Quoted: 36 Post(s)
Liked: 81
I've reformed. Honest. Now I only slow progress on the build thread, not on the actual build.
hanesian is offline
post #29 of 37 Old 04-01-2011, 04:58 PM - Thread Starter
ok, i see where you're coming from.
post #30 of 37 Old 04-03-2011, 02:04 PM - Thread Starter
Had my dad over to help w rough wiring for cans. What a difference it makes to have someone feed the romex. 8 cans rough wired in an hour and I should have them finished tonight w another hour.
Another 1 hr and the 8 cans are wired.
